Hello. I’m trying to install Nextcloud AIO. The master container is running, though It took a few hours to start all other containers. It seems the problem is with the Nextcloud container. This is what’s written in that container logs:
2023-01-22 12:41:50.994781+03:30
(1 row)
+ '[' -n '' ']'
+ set +x
Enabling Imagick...
WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.16/main: Permission denied
WARNING: Ignoring https://dl-cdn.alpinelinux.org/alpine/v3.16/community: Permission denied
ERROR: unable to select packages:
Could not install PHP extension imagick!
. Also whenever I try to enter into the dashboard to check the containers, it still takes a very long time to load the page, stop, and restart the containers.
In addition, there are a bunch of errors in the log of the nextcloud-aio-mastercontainer:
{"level":"error","ts":1674369685.6714115,"logger":"tls.obtain","msg":"will retry","error":"[172.17.0.2] Obtain: subject does not qualify for a public certificate: 172.17.0.2","attempt":2,"retrying_in":120,"elapsed":60.006828997,"max_duration":2592000}
[Sun Jan 22 06:42:28.349276 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get image nextcloud/aio-imaginary:latest from docker hub. Probably due to rate limits. Server error: POST http://localhost/v1.41/images/create?fromImage=nextcloud%2Faio-imaginary%3Alatest resulted in a 500 Internal Server Error response:\n{"message":"error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: \\"<html><body><h (truncated...)\n, referer: https://194.5.195.31:8080/containers
{"level":"info","ts":1674369805.6198835,"logger":"tls.obtain","msg":"releasing lock","identifier":"172.17.0.2"}
[Sun Jan 22 06:43:51.332758 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get image nextcloud/aio-nextcloud:latest from docker hub. Probably due to rate limits. Server error: POST http://localhost/v1.41/images/create?fromImage=nextcloud%2Faio-nextcloud%3Alatest resulted in a 500 Internal Server Error response:\n{"message":"error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: \\"<html><body><h (truncated...)\n, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:45:14.500575 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get image nextcloud/aio-apache:latest from docker hub. Probably due to rate limits. Server error: POST http://localhost/v1.41/images/create?fromImage=nextcloud%2Faio-apache%3Alatest resulted in a 500 Internal Server Error response:\n{"message":"error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: \\"<html><body><h (truncated...)\n, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:45:56.643377 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/all-in-one:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/all-in-one/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:46:38.459670 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-apache:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-apache/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:47:19.386789 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-collabora:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-collabora/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:47:59.731106 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-talk:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-talk/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:48:39.877659 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-nextcloud:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-nextcloud/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:49:21.065514 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-postgresql:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-postgresql/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:50:01.974374 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-redis:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-redis/manifests/latest, referer: https://194.5.195.31:8080/containers
[Sun Jan 22 06:50:42.604422 2023] [php:notice] [pid 1314] [client 127.0.0.1:40912] Could not get digest of container nextcloud/aio-imaginary:latest cURL error 52: Empty reply from server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://registry-1.docker.io/v2/nextcloud/aio-imaginary/manifests/latest, referer: https://194.5.195.31:8080/containers
Where’s the problem? Is there any solution for it?
