Hi i tried to setup my docker-compose from this example
https://github.com/nextcloud/docker/tree/master/.examples/docker-compose/with-nginx-proxy/mariadb/apache
When i run this retrieving of the certificated failed. What i have done:
- I clone the example
- add in the db.env MYSQL_PASSWORD=mysupersecretpassword
- editing in docker-compose.yml in the mariadb image section the MYSQL_ROOT_PASSWORD=mysupersecretrootpassword
- in the nextcloud image section i edit the VIRTUAL_HOST and LETSENCRYPT_HOST to mydomainname.duckdns.org and put LETSENCRYPT_EMAIL to mymail@provider.org
- editing the volume section to volumes:
db:
driver_opts:
type: none
device: /sharedfolders/Docker/210829NextcloudDB
o: bind
nextcloud:
driver_opts:
type: none
device: /sharedfolders/Docker/210829Nextcloud/data
o: bind
certs:
driver_opts:
type: none
device: /sharedfolders/Docker/210829Nextcloud/proxy/certs
o: bind
acme:
driver_opts:
type: none
device: /sharedfolders/Docker/210829Nextcloud/proxy/acme
o: bind
vhost.d:
driver_opts:
type: none
device: /sharedfolders/Docker/210829Nextcloud/proxy/vhost.d
o: bind
html:
driver_opts:
type: none
device: /sharedfolders/Docker/210829Nextcloud/proxy/html
o: bind
What is going wrond?
generation of the certificate failed with following log messages
[Sun Aug 29 09:00:18 UTC 2021] The domain key is here: /etc/acme.sh/mymail@provider.org/mydomainname.duckdns.org/mydomainname.duckdns.org.key
[Sun Aug 29 09:00:18 UTC 2021] Single domain='mydomainname.duckdns.org'
[Sun Aug 29 09:00:18 UTC 2021] Getting domain auth token for each domain
[Sun Aug 29 09:00:20 UTC 2021] Getting webroot for domain='mydomainname.duckdns.org'
[Sun Aug 29 09:00:20 UTC 2021] Verifying: mydomainname.duckdns.org
[Sun Aug 29 09:00:24 UTC 2021] mydomainname.duckdns.org:Verify error:No valid IP addresses found for mydomainname.duckdns.org
What i did to find to problem:
I can visit the http version of mydomainname… so the message seems to be not suitable because the ip is valid any other ideas what actually goes wrong? (and really seeing my nextcloud side and see in proxy log the access to the side).
If i visit the https version i get an 500 which fits to the generated default.conf i guess this would be updated when the certificate generation was successfully.
https part of the generated default.conf
server {
server_name mydomainname.duckdns.org;
listen 443 ssl http2 ;
access_log /var/log/nginx/access.log vhost;
return 500;
ssl_certificate /etc/nginx/certs/default.crt;
ssl_certificate_key /etc/nginx/certs/default.key;
has any one an idea what this invalid ip could cause? (since to problems of my provider i only have a ipv4 addresse not a ipv6)
