Hello, I’m new to using NextCloudPi.
I have the following question:
- My computer is a Raspberry 4B;
- I installed NextCloudPi 17.0.3;
- In the External Storages option, I used SMB / CIFS:
- Configuration: My IP on NextCloudPi
- Shared: media
- User: ncp
- I am getting the error below.
Can someone help me?
Thanks.
[no app in context] Error: Icewind\SMB\Exception\ConnectionRefusedException: / at <>
- /data/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 62
Icewind\SMB\Exception\Exception::fromMap({1: "Icewind\SM … "}, 111, “/”) - /data/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 74
Icewind\SMB\Native\NativeState->handleError("/") - /data/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php line 184
Icewind\SMB\Native\NativeState->testResult("*** sensitive parameter replaced ***", “smb://192.168.1.201/media/”) - /data/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 133
Icewind\SMB\Native\NativeState->stat(“smb://192.168.1.201/media/”) - /data/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 112
Icewind\SMB\Native\NativeShare->getStat("/") - /data/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 178
Icewind\SMB\Native\NativeShare->stat("/") - /data/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 296
OCA\Files_External\Lib\Storage\SMB->getFileInfo("/") - /data/nextcloud/lib/private/Files/Storage/Common.php line 454
OCA\Files_External\Lib\Storage\SMB->stat("") - /data/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 612
OC\Files\Storage\Common->test() - /data/nextcloud/apps/files_external/lib/config.php line 274
OCA\Files_External\Lib\Storage\SMB->test("*** sensitive parameter replaced ", " sensitive parameter replaced ***") - /data/nextcloud/apps/files_external/lib/Controller/StoragesController.php line 253
OC_Mount_Config::getBackendStatus("*** sensitive parameters replaced ***") - /data/nextcloud/apps/files_external/lib/Controller/GlobalStoragesController.php line 112
OCA\Files_External\Controller\StoragesController->updateStorageStatus("*** sensitive parameters replaced ***") - /data/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 170
OCA\Files_External\Controller\GlobalStoragesController->create(“smb”, “smb”, “password::password”, {host: "192.168. … "}, {encrypt: "*** s … "}, [], [], 100) - /data/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 99
OC\AppFramework\Http\Dispatcher->executeController(OCA\Files_Extern … {}, “create”) - /data/nextcloud/lib/private/AppFramework/App.php line 126
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Files_Extern … {}, “create”) - /data/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php line 47
OC\AppFramework\App::main(“OCA\Files_Exte … r”, “create”, OC\AppFramework\ … {}, {route: "files … "}) - <>
OC\AppFramework\Routing\RouteActionHandler->__invoke({route: "files … "}) - /data/nextcloud/lib/private/Route/Router.php line 297
undefinedundefinedcall_user_func(OC\AppFramework\ … {}, {route: "files … "}) - /data/nextcloud/lib/base.php line 997
OC\Route\Router->match("/apps/files_external/globalstorages") - /data/nextcloud/index.php line 42
OC::handleRequest()
POST /index.php/apps/files_external/globalstorages
from 192.168.1.108 by ncp at 2020-02-24T16:16:12+00:00
