Nextcloud version: 30.0.2
When I attempt to open/edit a document on any web browser nextcloud will remain on the loading window until I press cancel
However, this will not happen for some reason when I use the nextcloud app on Android. I will be able to open and edit documents just fine.
When I goto the DevTools window in chrome I will get an error on the console: proxy.php?status error with collabora.js:40 being the initiator.
As far as WOPI requests go, I have my reverse proxy, localhost, and nextclouds IP addresses listed.
If I go to my logs in Nextcloud, I also see an error related to code/richdocuments:
Client error: `POST http://cloud.address.ddns.net/custom_apps/richdocumentscode/proxy.php?req=/cool/convert-to/png` resulted in a `400 Bad Request` response```
"reqId": "HvCzO66qICpK4PgjenU2",
"level": 3,
"time": "2024-12-02T20:09:41+00:00",
"remoteAddr": "10.0.0.90",
"user": "Hellman_x",
"app": "richdocuments",
"method": "GET",
"url": "/core/preview?fileId=37984&x=3440&y=1440&a=true&v=a68307",
"message": "Failed to convert preview: Client error: `POST http://cloud.address.ddns.net/custom_apps/richdocumentscode/proxy.php?req=/cool/convert-to/png` resulted in a `400 Bad Request` response",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36",
"version": "30.0.2.2",
"exception": {
"Exception": "GuzzleHttp\\Exception\\ClientException",
"Message": "Client error: `POST http://cloud.address.ddns.net/custom_apps/richdocumentscode/proxy.php?req=/cool/convert-to/png` resulted in a `400 Bad Request` response",
"Code": 400,
"Trace": [
"file": "/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php",
"line": 72,
"function": "create",
"class": "GuzzleHttp\\Exception\\RequestException",
"type": "::",
"args": [
"*** sensitive parameters replaced ***"
"file": "/var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php",
"line": 209,
"function": "GuzzleHttp\\{closure}",
"class": "GuzzleHttp\\Middleware",
"type": "::",
"args": [
"line": 158,
"function": "callHandler",
"class": "GuzzleHttp\\Promise\\Promise",
"type": "::",
"args": [
1,
"*** sensitive parameters replaced ***",
"file": "/var/www/html/3rdparty/guzzlehttp/promises/src/TaskQueue.php",
"line": 52,
"function": "GuzzleHttp\\Promise\\{closure}",
"type": "::",
"args": [
"line": 251,
"function": "run",
"class": "GuzzleHttp\\Promise\\TaskQueue",
"type": "->",
"args": [
true
"line": 227,
"function": "invokeWaitFn",
"type": "->",
"args": []
"line": 272,
"function": "waitIfPending",
"type": "->",
"args": []
"line": 229,
"function": "invokeWaitList",
"type": "->",
"args": []
"line": 69,
"type": "->",
"args": []
"file": "/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php",
"line": 189,
"function": "wait",
"type": "->",
"args": []
"file": "/var/www/html/lib/private/Http/Client/Client.php",
"line": 276,
"function": "request",
"class": "GuzzleHttp\\Client",
"type": "->",
"args": [
"post",
"0": "And 2 more entries, set log level to debug to see all entries",
"verify": "/var/www/html/resources/config/ca-bundle.crt",
"timeout": 5,
"nextcloud": {
"allow_local_address": true
"expect": false,
"multipart": [
"name": "Test.docx",
"contents": null
"file": "/var/www/html/custom_apps/richdocuments/lib/Service/RemoteService.php",
"line": 92,
"function": "post",
"class": "OC\\Http\\Client\\Client",
"type": "->",
"args": [
"line": 72,
"function": "convertTo",
"class": "OCA\\Richdocuments\\Service\\RemoteService",
"type": "->",
"args": [
"Test.docx",
null,
"png"
"file": "/var/www/html/custom_apps/richdocuments/lib/Preview/Office.php",
"line": 41,
"function": "convertFileTo",
"type": "->",
"args": [
"__class__": "OC\\Files\\Node\\File"
"png"
"file": "/var/www/html/lib/private/Preview/GeneratorHelper.php",
"line": 44,
"function": "getThumbnail",
"class": "OCA\\Richdocuments\\Preview\\Office",
"type": "->",
"args": [
4096,
4096
"file": "/var/www/html/lib/private/Preview/Generator.php",
"line": 337,
"class": "OC\\Preview\\GeneratorHelper",
"type": "->",
"args": [
"__class__": "OCA\\Richdocuments\\Preview\\OOXML"
4096,
4096
"line": 313,
"function": "generateProviderPreview",
"class": "OC\\Preview\\Generator",
"type": "->",
"args": [
"__class__": "OC\\Files\\SimpleFS\\SimpleFolder"
4096,
4096,
false,
true,
"application/vnd.openxmlformats-officedocument.wordprocessingml.document",
"line": 119,
"function": "getMaxPreview",
"type": "->",
"args": [
"line": 86,
"function": "generatePreviews",
"type": "->",
"args": [
"width": 3440,
"height": 1440,
"crop": false,
"mode": "fill"
"file": "/var/www/html/lib/private/PreviewManager.php",
"line": 167,
"function": "getPreview",
"type": "->",
"args": [
3440,
1440,
false,
"fill",
"file": "/var/www/html/core/Controller/PreviewController.php",
"line": 159,
"class": "OC\\PreviewManager",
"type": "->",
"args": [
3440,
1440,
false,
"fill"
"line": 123,
"function": "fetchPreview",
"class": "OC\\Core\\Controller\\PreviewController",
"type": "->",
"args": [
3440,
1440,
true,
true,
"fill",
false
"file": "/var/www/html/lib/private/AppFramework/Http/Dispatcher.php",
"line": 208,
"function": "getPreviewByFileId",
"type": "->",
"args": [
37984,
3440,
1440,
true,
true,
"fill",
false
"line": 114,
"function": "executeController",
"class": "OC\\AppFramework\\Http\\Dispatcher",
"type": "->",
"args": [
"__class__": "OC\\Core\\Controller\\PreviewController"
"file": "/var/www/html/lib/private/AppFramework/App.php",
"line": 161,
"function": "dispatch",
"type": "->",
"args": [
"file": "/var/www/html/lib/private/Route/Router.php",
"line": 302,
"function": "main",
"class": "OC\\AppFramework\\App",
"type": "::",
"args": [
"__class__": "OC\\AppFramework\\DependencyInjection\\DIContainer"
"_route": "core.preview.getpreviewbyfileid"
"file": "/var/www/html/lib/base.php",
"line": 1001,
"function": "match",
"class": "OC\\Route\\Router",
"type": "->",
"args": [
"/core/preview"
"file": "/var/www/html/index.php",
"line": 24,
"function": "handleRequest",
"class": "OC",
"type": "::",
"args": []
"File": "/var/www/html/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php",
"Line": 113,
"exception": [],
"CustomMessage": "Failed to convert preview: Client error: `POST http://cloud.address.ddns.net/custom_apps/richdocumentscode/proxy.php?req=/cool/convert-to/png` resulted in a `400 Bad Request` response"
"id": "674e1407dc4fd"
Operating system
Debian/Ubuntu
PHP engine version
PHP 8.2
Web server
Apache (supported)
Database engine version
SQlite
Is this bug present after an update or on a fresh install?
Fresh Nextcloud Server install
Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
What user-backends are you using?
- Default user-backend (database)
Configuration:
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"upgrade.disable-web": true,
"cloud.address.ddns.net",
"10.0.0.90"
"dbtype": "sqlite3",
"overwrite.cli.url": "http:\/\/cloud.address.ddns.net",
"overwriteprotocol": "https",
"loglevel": 2
App List:
- activity: 3.0.0
- app_api: 4.0.0
- bruteforcesettings: 3.0.0
- calendar: 5.0.6
- circles: 30.0.0
- comments: 1.20.1
- contacts: 6.1.1
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- firstrunwizard: 3.0.0
- logreader: 3.0.0
- mail: 4.0.7
- notes: 4.11.0
- notifications: 3.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recognize: 8.1.1
- recommendations: 3.0.0
- related_resources: 1.5.0
- richdocuments: 8.5.2
- richdocumentscode: 24.4.902
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- spreed: 20.0.2
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.5.0
- updatenotification: 1.20.0
- user_status: 1.10.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
- admin_audit: 1.20.0
- encryption: 2.18.0
- files_external: 1.22.0
- suspicious_login: 8.0.0
- twofactor_totp: 12.0.0-dev
- user_ldap: 1.21.0
Signing Status:
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- core
- EXTRA_FILE
- nextcloud-init-sync.lock
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[nextcloud-init-sync.lock] => Array
[expected] =>
[current] => cf83e1357eefb8bdf1542850d66d8007d620e4050b5715dc83f4a921d36ce9ce47d0d13c5d85f2b0ff8318d2877eec2f63b931bd47417a81a538327af927da3e
