I am pretty new to networking and I am having trouble updating PHP in my TrueNAS jail.
I went the plugin route and by default it installed PHP 8.0.30, which it recommends to upgrade in the admin settings.
I have tried to follow other forum guides and even tried ChatGPT to help me install the newer PHP, but I keep running into errors. A lot of the guides are old and just end up not recommending the update, or go through the process of downgrading after breaking something. What is the best way to upgrade this?
I am using:
FreeBSD Nextcloud 13.1-RELEASE-p9 FreeBSD 13.1-RELEASE-p9 n245429-296d095698e TRUENAS amd64
Message from Nextcloud:
- You are currently running PHP 8.0.30. PHP 8.0 is now deprecated in Nextcloud 27. Nextcloud 28 may require at least PHP 8.1. Please upgrade to one of the officially supported PHP versions provided by the PHP Group as soon as possible. For more details see the documentation
Using pkg install php82 gives a 404 error on the Nextcloud domain
Thanks!
