Good day,
I wanted to upgrade my Nextcloud from an old (25.x.x) version to the current one. However, when I click on Update only comes:
Step 5 is currently in process. Please reload this page later.
This has been there for almost 2 weeks. So really only the text as text. There is no HTML, no CSS and nothing else. Do you have an idea ?
Thanks in advance
ernolf
2
Try this:
Step 1
Delete this folder:
nextcloud/data/updater-$instanceid
(instanceid is defined in your config/config.php)
Step 2
Run the updater by commandline, this way:
sudo -u www-data /usr/bin/php -d memory_limit=512M -f /var/www/nextcloud/updater/updater.phar
(Adjust the paths and web server user to your circumstances)
Much luck.
