I am running nextcloud in a docker container, and I use nginx to redirect all the traffic from my subdomain ‘cloud.mydomain.com’ to the container that is listening at localhost:8081. My trusted domains array in the config looks like this:
0 => 'localhost:8081',
1 => 'cloud.mydomain.com',
'trusted_proxies' =>
0 => 'localhost',
1 => '127.0.0.1',
2 => '192.168.0.12',
This works, but some images will be broken since nextcloud links them using the localhost:8081 address, because to nextcloud it looks as if the client was requesting the page from localhost (because nginx resides on localhost). If I forward the host address with nginx by putting
server_name cloud.mydomain.com;
location / {
proxy_set_header Host $host;
proxy_pass http://localhost:8081;
into the nginx config for the site, then nextcloud will show an “Access through untrusted domain” error when I access the site through “cloud.mydomain.com”. Anyone have any suggestion on how to debug this further? Or a guide for setting nginx up as a reverse proxy with nextcloud?
P.S.: Why does nextcloud not tell me WHAT untrusted domain I am supposedly accessing it from? That would probably give me a huge hint on what is wrong. I checked the nextcloud log but couldn’t find anything on that.
