Problems migrating from owncloud 10.15.0 (stable)
I would like to migrate from owncloud 10.15.0 (stable) to nextcloud, I followed this guide:
but when I enter ip/updater/index.php in my address bar, I get this error:
Not Found
The requested URL was not found on this server.
Apache/2.4.62 (Debian) Server at 192.168.1.5 Port 443
I use a Raspberry Pi 5, 8GB RAM, php version 8.4 installed, previously running 7.4
Can you tell me how I should do it?
Isn’t that guide for owncloud 10.13?
The problem is that this is the only guide I’ve found
Well are you trying to migrate to the Nextcloud version mentioned in the guide?
If I recall when reading the guide it was Nextcloud 27.
yes, I followed all the steps in the guide, I went to /var/www/owncloud and downloaded the version with: https://download.nextcloud.com/server/installer/migrator/index.php
mv index.php.1 updater/index.php
then I typed url with /updater/index.php and I get the error mentioned above
I unfortunately haven’t used owncloud. So my assumption is the following:
A) the owncloud version you use isnt supported by the migration script.
Or
B) you installed/configured something wrong.
The error you posted implies something is installed wrong although it’s not definitive enough on its own to say so.
I reinstalled owncloud from scratch (version 10.13.0 stable), at the same time reinstalled nextcloud and followed the steps in the guide… when I type myIP/updater/index.php I always get the same error message…
same thing by typing myIP/nextcloud
