Hi there,
I’m using Nextcloud on my RPi3 since a couple of days, which is working very good!
After last update I got a message to upgrade from PHP7.0 to a newer version.
So last weekend I tried to upgrade my installation to PHP7.3 but I could get it to work :-/
First my system;
RPi3 with Raspbian 9
NGinx 1.10.3
PHP7.0 (working)
PHP7.3 (not working)
I’ve “uploaded” my Nginx-Config to https://pastebin.com/Rus79GaT
If I replace both “php7.0-fpm.sock” settings with “php7.3-fpm.sock” and restart my server, I got following situation:
My “phpinfo();” in the webserver root is working correctly and php7.3 is shown
But if I open Nextcloud, I got following error:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
As far as I can see, all php-settings are transfered from 7.0 to 7.3 after installation of it.
Maybe someone has a hint, what is wrong?
Thanks for your help
