You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead. at /var/www/nextcloud/3rdparty/patchwork/utf8/src/Patchwork/Utf8/Bootup/intl.php#18
install php-intl as per your Linux distro. Mine is running on Debian, so I did:
apt-get install php-intl
You need to reset the scan, this can be done on the site
This one might be a bit tricky, as these are DNS srv records, for auto-condiguring e.g. iOS devices. If you don’t run your own DNS server and you don’t have access to your DNS zone, you might be out of luck here.
This one is actually a peace of cake. Just issue a
sudo -u <web server user> php occ db:add-missing-indices
You need to configure your NC web server accordingly. I am running Apache and I am having this in my virtual host config for NC:
<IfModule mod_headers.c>
Header set Strict-Transport-Security “max-age=15768000; includeSubDomains; preload”
Header set X-Frame-Options “SAMEORIGIN”
Header set X-XSS-Protection “1; mode=block”
Header set X-Content-Type-Options “nosniff”
Header append Referrer-Policy “no-referrer”
Header append Content-Security-Policy “default-src https: data: ‘unsafe-inline’ ‘unsafe-eval’”
Header set X-Download-Options “noopen”
Header set X-Permitted-Cross-Domain-Policies “none”
</IfModule>
Errors in log stopped! thnx!
2.
Not clear to me how to
and on which site…
Most curious: why does the scan report Running Nextcloud 11.0.3.2 where the server self reports: 14.0.3.
The returned rating is a green capital A
3. still trying to create a correct .htaccess file in the right place…
the command that worked for me:
sudo -u www-data php /var/www/nextcloud/occ db:add-missing-indices
thanks for pointing me in the right direction
Before experimenting with my Apache2 config I better need to understand what this referral is about…
On the site, where the result of the old scan is displayed, click on the litte two arrows right of the last line of the scan result. This will trigger a new scan.
