Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 20.0.5): Space 24.0.1
Operating system and version (eg, Ubuntu 20.04): NAME=âUbuntuâ VERSION=â20.04.3 LTS (Focal Fossa)â
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 8.0.20
DB Type: mysql: Version: 8.0.29
snap list
Name Version Rev Tracking Publisher Notes
core18 20220428 2409 latest/stable canonicalâ base
nextcloud 24.0.1snap1 31033 latest/stable nextcloudâ -
snapd 2.56 16010 latest/stable canonicalâ snapd
Error on command /snap/bin/nextcloud.occ files:transfer-ownership
Is this the first time youâve seen this error? (Y/N): Y
- do command /snap/bin/nextcloud.occ files:transfer-ownership
root@nextcloud1z1:~# /snap/bin/nextcloud.occ files:transfer-ownership olga.kim oksana.shevchenko
Validating quota
Analysing files of olga.kim âŚ
2194 [============================]
Collecting all share information for files and folders of olga.kim âŚ
77 [============================]
Transferring files to oksana.shevchenko/files/transferred from Kim, Olga on 2022-06-16 10-34-57 âŚ
Restoring shares âŚ
70/77 [=========================>â] 90%Could not restore share with id 50025:Could not get proper share mount for 1522103. Failing since else the next calls are called with null : #0 /snap/nextcloud/31033/htdocs/lib/private/Share20/Manager.php(992): OC\Share20\Manager->generalCreateChecks()
#1 /snap/nextcloud/31033/htdocs/apps/files/lib/Service/OwnershipTransferService.php(421): OC\Share20\Manager->updateShare()
#2 /snap/nextcloud/31033/htdocs/apps/files/lib/Service/OwnershipTransferService.php(185): OCA\Files\Service\OwnershipTransferService->restoreShares()
#3 /snap/nextcloud/31033/htdocs/apps/files/lib/Command/TransferOwnership.php(150): OCA\Files\Service\OwnershipTransferService->transfer()
#4 /snap/nextcloud/31033/htdocs/3rdparty/symfony/console/Command/Command.php(255): OCA\Files\Command\TransferOwnership->execute()
#5 /snap/nextcloud/31033/htdocs/3rdparty/symfony/console/Application.php(1009): Symfony\Component\Console\Command\Command->run()
#6 /snap/nextcloud/31033/htdocs/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand()
#7 /snap/nextcloud/31033/htdocs/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun()
#8 /snap/nextcloud/31033/htdocs/lib/private/Console/Application.php(211): Symfony\Component\Console\Application->run()
#9 /snap/nextcloud/31033/htdocs/console.php(99): OC\Console\Application->run()
#10 /snap/nextcloud/31033/htdocs/occ(11): require_once(ââŚâ)
#11 {main}
77/77 [============================] 100%
