Problem with Passwords App
i ave this issue Content type mismatch: Expected application/json, got text/html; charset=utf-8
anyone could help!?
btw after installing it i added some passwords normally but after refreshing the page this error occourd, tried to log out and re login and same thing, tried to remove the app and re install it and same problem!
anyone could help pls
thanks in advanc!!
I have not seen an HTTP error code of 499 before. It’s not standard and not used by the app itself.
Can you press F12, open the network tab and then check which request gets that error code?
Can you also check for any errors logged in your nextclouds log as described here: App Debugging · Wiki · nextcloud / passwords · GitLab
Solved! after the kaspersky was blocking the connection to the server.
