example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.2.10
Operating system and version (eg, Ubuntu 20.04): raspbian 10 (buster)
Apache or nginx version (eg, Apache 2.4.25): Server version: Apache/2.4.38 (Raspbian) Server built: 2022-06-20T19:03:00
PHP version (eg, 7.4): PHP 7.3.31-1~deb10u1 (cli) (built: Oct 24 2021 15:18:08) ( NTS )
There is a problem with files that are not passing integrity check. Log here: https://pastebin.com/d32fBEtY
Also the system is terribly slow at times - logging in can take minutes, but let’s ignore it for now.
I think the clue what’s wrong lies in that behaviour:
- When I run the integrity check with foobar (or anything) it gets added to the list and stays there. I assume that’s not normal? Trying to rescan produces "Access forbidden. CSRF check failed" page. There is a background task problem as well - it might be related. I tried to configure all 3 options - but there is always error message coming back that the background tasks were not executed for hours/months/years (!)
root@raspberrypi:/var/www/html/nextcloud# sudo -u www-data php ./occ integrity:check-app foobar
- EXCEPTION:
- class: Exception
- message: App not found
Sorry, unknown. I did overdue upgrades from 19 to 20 to 21 to 22
The log at error level is massive (sounds bad...). Last few lines:
Error index Exception: The requested uri(/.well-known/nodeinfo) cannot be processed by the script '/nextcloud/index.php')
2022-12-27T16:21:12+0000
Error public Exception: The requested uri(/.well-known/webfinger) cannot be processed by the script '/nextcloud/public.php')
2022-12-27T16:19:22+0000
'instanceid' => 'XXX',
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'XXX',
'datadirectory' => '/var/www/html/nextcloud/data',
'dbtype' => 'sqlite3',
'version' => '22.2.10.2',
'overwrite.cli.url' => 'https://XXX.eu',
'theme' => '',
'loglevel' => 0,
'app_install_overwrite' =>
0 => 'occweb',
'mail_domain' => 'XXX.eu',
'mail_from_address' => 'XXX',
'mail_smtpmode' => 'smtp',
'updater.secret' => 'XXX',
'data-fingerprint' => 'XXX',
The output of your Apache log in /var/log/apache2/error.log
Interesting that might be another reason for my problems
[Tue Dec 27 00:00:03.708923 2022] [mpm_prefork:notice] [pid 5275] AH00163: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1n configured -- resuming normal operations
[Tue Dec 27 00:00:03.876274 2022] [core:notice] [pid 5275] AH00094: Command line: '/usr/sbin/apache2'
[Tue Dec 27 04:46:42.340357 2022] [php7:error] [pid 25620] [client [MASKED]] script '/var/www/html/remote.php' not found or unable to stat
[Tue Dec 27 14:43:39.435726 2022] [php7:error] [pid 25619] [client [MASKED]] script '/var/www/html/remote.php' not found or unable to stat
[Tue Dec 27 15:21:02.873883 2022] [access_compat:error] [pid 25622] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:21:33.066622 2022] [access_compat:error] [pid 461] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:47:05.283478 2022] [access_compat:error] [pid 29074] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:54:38.852592 2022] [access_compat:error] [pid 817] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:55:08.894383 2022] [access_compat:error] [pid 860] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:55:20.930692 2022] [access_compat:error] [pid 860] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 15:58:29.697885 2022] [access_compat:error] [pid 817] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 16:11:03.076214 2022] [access_compat:error] [pid 921] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 16:11:17.106571 2022] [access_compat:error] [pid 924] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 16:16:06.420191 2022] [access_compat:error] [pid 924] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 16:19:22.866156 2022] [access_compat:error] [pid 1121] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
[Tue Dec 27 16:21:12.667242 2022] [access_compat:error] [pid 1122] [client [MASKED]] AH01797: client denied by server configuration: /var/www/html/nextcloud/data/.ocdata
The log is massive, but it seems to be mostly repeats of those:
https://pastebin.com/b9C7d9NH
Any help is appreciated - with my current knowledge it looks like FUBAR, but I hope for the forum gurus it’s just another mangled configuration challenge, not FUBAR. If I missed any important info - I’ll be happy to provide it.
