Hello i have my nextcloud site in /var/www/nextcloud, with user and group www-data.
Using: ubuntu 18.04 with nginx 1.14 server.
I created local virtual host nextcloud,aaron.com
But when i go in browser to that address i get
Also my nginx in conf.d is empty.
My nginx/sites-avalaible config file:
server {
listen 80;
server_name nextcloud.aaron.com;
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
#I found this header is needed on Ubuntu, but not on Arch Linux.
add_header X-Frame-Options "SAMEORIGIN";
root /var/www/nextcloud;
access_log /var/log/nginx/nextcloud.access;
error_log /var/log/nginx/nextcloud.error;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location ~ /.well-known/acme-challenge {
#location ^~ /.well-known/acme-challenge/
allow all;
default_type "text/plain";
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_pass unix:/run/php/php7.2-fpm.sock;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
access_log off;
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
Also just in case my /ect/hosts:
|127.0.0.1|localhost|
|127.0.0.1|nextcloud.aaron.com|
|127.0.1.1|aaron-VirtualBox|
I think everythig is ok, and i dont know the error …
Also made a ln from /etc/nginx/sites-enabled/nextcloud.aaron.com to the config file in /etc/nginx/sites-avalaible
Any help would be apreciated…
