Problem with Nextcloud
Hello everyone,
I’m getting into Nextcloud for the first time and have installed it on my server with an Ubuntu VM. I followed these instructions (see commands below).
I did the following differently than described in the instructions:
  1. I entered my IP address for the server name. I only use it locally.
  2. My data is located under /mnt/nextcloud and not under /var.
Everything worked and I was able to use Nextcloud. However, after restarting the VM machine, I get the following error message (see unter) and therefore cannot use Nextcloud.
The data directory is invalid
Please ensure that a “.ncdata” file exists in the root directory of the data directory. It should have the following content: “# Nextcloud data directory”
The data directory is write-protected.
Permissions can usually be corrected by granting the web server write access to the root directory. See also Introduction — Nextcloud latest Administration Manual latest documentation
What do I have to do or which commands do I have to execute to get information that will help you?
Commands:
updating
apt update && apt upgrade -y
Installing apache
apt install apache2 -y
Install PHP 8.3
apt install software-properties-common
add-apt-repository ppa:ondrej/php
apt update
Install PHP 8.3 & Moduls
apt install php8.3 libapache2-mod-php8.3 php8.3-zip php8.3-xml php8.3-mbstring php8.3-gd php8.3-curl php8.3-imagick libmagickcore-6.q16-6-extra php8.3-intl php8.3-bcmath php8.3-gmp php8.3-cli php8.3-mysql php8.3-zip php8.3-gd php8.3-mbstring php8.3-curl php8.3-xml php-pear unzip nano php8.3-apcu redis-server ufw php8.3-redis php8.3-smbclient php8.3-ldap php8.3-bz2 php8.3-sqlite3
adjust PHP.ini file
nano /etc/php/8.3/apache2/php.ini
memory_limit = 4096M
upload_max_filesize = 20G
post_max_size = 20G
date.timezone = Europe/Berlin
output_buffering = Off
opcache.enable=1
opcache.enable_cli=1
opcache.interned_strings_buffer=8
opcache.max_accelerated_files=10000
opcache.memory_consumption=128
opcache.save_comments=1
opcache.revalidate_freq=1
Install Databse Server
apt install mariadb-server
Maria DB Server Konfiguration
mysql_secure_installation
open SQL dialoge
mysql
create database calles nextcloud
CREATE DATABASE nextcloud;
create database user with password
CREATE USER ‘nextclouduser’@‘localhost’ IDENTIFIED BY ‘password_here’;
#grant accesss to databse
GRANT ALL PRIVILEGES ON nextcloud.* TO ‘nextclouduser’@‘localhost’;
#save changes and exit
FLUSH PRIVILEGES;
EXIT;
Download lastest nextcloud version
cd /tmp && wget https://download.nextcloud.com/server/releases/latest.zip
unzip latest.zip
mv nextcloud /var/www/
#create new conf
nano /etc/apache2/sites-available/nextcloud.conf
<VirtualHost *:80>
ServerAdmin master@domain.com
DocumentRoot /var/www/nextcloud/
ServerName
Options +FollowSymlinks
AllowOverride All
Require all granted
Dav off
Enable the NextCloud and Rewrite Module
a2ensite nextcloud.conf
a2enmod rewrite
a2enmod headers
a2enmod env
a2enmod dir
a2enmod mime
restart apache
service apache2 restart
prepare data folder
mkdir /home/data/
chown -R www-data:www-data /home/data/
chown -R www-data:www-data /var/www/nextcloud/
chmod -R 755 /var/www/nextcloud/
Best regards
Berto
change owner and user of /mnt/nextcloud make sure that you have the .ncdata file in that directory.
Could you write the commands to check if I have the .ncdata file in that directory, and explain how to change the owner and user of /mnt/nextcloud?
Could you also write the commands?
chown -R www-data:www-data /mnt/nextcloud
ls -l /mnt/nextcloud/.ncdata
If .ncdata is missing
touch /mnt/nextcloud/.ncdata
Your error happens because Nextcloud needs a .ncdata file in your data directory and proper permissions. To fix:
Create the .ncdata file inside /mnt/nextcloud with this content:
Set ownership and permissions:
sudo chown -R www-data:www-data /mnt/nextcloud
sudo chmod -R 750 /mnt/nextcloud
Ensure your Nextcloud config (config.php) points to /mnt/nextcloud as the data directory.
Then restart Apache (sudo systemctl restart apache2). This should resolve the issue.
