I installed nextcloud on ubuntu 20.04, webservers is nginx version 1.17.10php, php 7.4-fpm, nextcloud version is 18.04. The problem is that in the top of the site it keep showing reloading icon and it keeps reloading. Screen shot of erro: https://prnt.sc/sc6upc (this is in directory: all files).Any idea?
Can you :
try to use php7.3 instead of php7.4 (php7.4 seems to be a source of errors : Ugrade to PHP7.4 )
give your nginx configuration
display your nginx log
Thanks,
Good luck
I had the same with 19 Beta on 20.04 Ubuntu…
Click Settings on the bottom left and uncheck “Show rich workspaces”…
It (probably) does not fix the root of the problem, but I don’t want it shown anyway…
similar like this one is my nextcloud config page. I have installed php7.3-fpm and it is still the sanem. Probably problem with my config file.
server {
listen 80;
listen [::]:80;
server_name nextcloud.your-domain.com;
add_header X-Robots-Tag none;
add_header Referrer-Policy no-referrer;
#I found this header is needed on Ubuntu, but not on Arch Linux.
add_header X-Frame-Options "SAMEORIGIN";
root /usr/share/nginx/nextcloud/;
access_log /var/log/nginx/nextcloud.access;
error_log /var/log/nginx/nextcloud.error;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location ~ /.well-known/acme-challenge {
allow all;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_pass unix:/run/php/php7.3-fpm.sock;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
access_log off;
location ~* .(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don’t log access to other assets
access_log off;
It’s not the official config file. The official is here :
https://docs.nextcloud.com/server/16/admin_manual/installation/nginx.html
The official config uses 443 as port but you can edit in order to change for 80.
You have changed your config in order to use php7.3-fpm.sock, right ?
So, You cannot see your folders and files ?
Can you display the result of “ls /var/run/php” ?
I can see my folders and files. Problem is like this : https://prnt.sc/scz6rg.
