Problem with Nextcloud Repository
example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2
I have configured Nextcloud repository in Moodle as follows:
And I can see ClassRafiee repository in the list. It asked me to log in, I did and I granted the access to my Nextcloud, However, my files in Nextcloud are not visible in Moodle to choose them:
Would you please let me know where the issue is?
Thanks
[no app in context] Info: Deprecated event type for OCP\IDBConnection::CHECK_MISSING_COLUMNS: Symfony\Component\EventDispatcher\GenericEvent is used
GET /index.php/settings/ajax/checksetup
from 2.177.144.0 by admin at 2023-01-13T14:13:27+00:00
[no app in context] Info: Symfony\Component\Routing\Exception\RouteNotFoundException: Unable to generate a URL for the named route "contacts.contacts.directcircle" as such route does not exist. at <<closure>>
 0. /home/atwozico/cloud.rafiee.net/lib/private/Route/Router.php line 361
    Symfony\Component\Routing\Generator\UrlGenerator->generate("contacts.contacts.directcircle", ["eveBbHyOWcz8Gk1amTtugkgd5mZ76sc"], 1)
 1. /home/atwozico/cloud.rafiee.net/lib/private/URLGenerator.php line 103
    OC\Route\Router->generate("contacts.contacts.directcircle", ["eveBbHyOWcz8Gk1amTtugkgd5mZ76sc"])
 2. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Model/ModelManager.php line 561
    OC\URLGenerator->linkToRoute("contacts.contacts.directcircle", ["eveBbHyOWcz8Gk1amTtugkgd5mZ76sc"])
 3. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Model/Circle.php line 733
    OCA\Circles\Model\ModelManager->generateLinkToCircle("eveBbHyOWcz8Gk1amTtugkgd5mZ76sc")
 4. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Model/Circle.php line 855
    OCA\Circles\Model\Circle->getUrl()
 5. <<closure>>
    OCA\Circles\Model\Circle->jsonSerialize()
 6. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Service/FederatedUserService.php line 1293
    json_encode(OCA\Circles\Model\Circle {})
 7. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Service/FederatedUserService.php line 1067
    OCA\Circles\Service\FederatedUserService->cacheSingleCircle(OCA\Circles\Model\FederatedUser {}, OCA\Circles\Model\Circle {})
 8. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Service/FederatedUserService.php line 979
    OCA\Circles\Service\FederatedUserService->getSingleCircle(OCA\Circles\Model\FederatedUser {}, true)
 9. /home/atwozico/cloud.rafiee.net/apps/circles/lib/Service/FederatedUserService.php line 533
    OCA\Circles\Service\FederatedUserService->fillSingleCircleId(OCA\Circles\Model\FederatedUser {}, true)
10. /home/atwozico/cloud.rafiee.net/apps/circles/lib/ShareByCircleProvider.php line 565
    OCA\Circles\Service\FederatedUserService->getLocalFederatedUser("admin")
11. /home/atwozico/cloud.rafiee.net/lib/private/Share20/Manager.php line 1406
    OCA\Circles\ShareByCircleProvider->getSharedWith("admin", 7, null, -1, 0)
12. /home/atwozico/cloud.rafiee.net/apps/files_sharing/lib/MountProvider.php line 97
    OC\Share20\Manager->getSharedWith("admin", 7, null, -1)
13. /home/atwozico/cloud.rafiee.net/lib/private/Files/Config/MountProviderCollection.php line 134
    OCA\Files_Sharing\MountProvider->getMountsForUser(OC\User\User {}, OC\Files\Storage\StorageFactory {})
14. /home/atwozico/cloud.rafiee.net/lib/private/Files/SetupManager.php line 226
    OC\Files\Config\MountProviderCollection->addMountForUser(OC\User\User {}, OC\Files\Mount\Manager {}, Closure {})
15. /home/atwozico/cloud.rafiee.net/lib/private/Files/SetupManager.php line 318
    OC\Files\SetupManager->OC\Files\{closure}("*** sensitive parameters replaced ***")
16. /home/atwozico/cloud.rafiee.net/lib/private/Files/SetupManager.php line 227
    OC\Files\SetupManager->setupForUserWith(OC\User\User {}, Closure {})
17. /home/atwozico/cloud.rafiee.net/lib/private/Files/SetupManager.php line 389
    OC\Files\SetupManager->setupForUser(OC\User\User {})
18. /home/atwozico/cloud.rafiee.net/lib/private/Files/Mount/Manager.php line 95
    OC\Files\SetupManager->setupForPath("/admin/files/")
19. /home/atwozico/cloud.rafiee.net/lib/private/Files/View.php line 215
    OC\Files\Mount\Manager->find("/admin/files/")
20. /home/atwozico/cloud.rafiee.net/lib/private/Files/View.php line 1446
    OC\Files\View->getMount("/")
21. /home/atwozico/cloud.rafiee.net/lib/private/Files/Node/Folder.php line 101
    OC\Files\View->getDirectoryContent("/", "", OC\Files\Node\LazyUserFolder {})
22. /home/atwozico/cloud.rafiee.net/apps/dav/lib/Connector/Sabre/Directory.php line 260
    OC\Files\Node\Folder->getDirectoryListing()
23. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Tree.php line 200
    OCA\DAV\Connector\Sabre\Directory->getChildren()
24. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 900
    Sabre\DAV\Tree->getChildren("")
25. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 982
    Sabre\DAV\Server->generatePathNodes(Sabre\DAV\PropFind {}, [Sabre\DAV\PropF ... }])
26. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 1662
    Sabre\DAV\Server->getPropertiesIteratorForPath("", ["{DAV:}resourcetype"], 1)
27. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 1647
    Sabre\DAV\Server->writeMultiStatus(Sabre\Xml\Writer ... ]}, Generator {}, false)
28. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
    Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
29. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
    Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
30. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 472
    Sabre\DAV\Server->emit("method:PROPFIND", [Sabre\HTTP\Requ ... }])
31. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 253
    Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
32. /home/atwozico/cloud.rafiee.net/3rdparty/sabre/dav/lib/DAV/Server.php line 321
    Sabre\DAV\Server->start()
33. /home/atwozico/cloud.rafiee.net/apps/dav/appinfo/v1/webdav.php line 85
    Sabre\DAV\Server->exec()
34. /home/atwozico/cloud.rafiee.net/remote.php line 171
    require_once("/home/atwozico/ ... p")
PROPFIND /remote.php/webdav
from 2.177.144.0 by admin at 2023-01-13T14:13:26+00:00
[no app in context] Debug: OC\AppFramework\Middleware\Security\Exceptions\NotLoggedInException: Current user is not logged in at <<closure>>
0. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/Middleware/MiddlewareDispatcher.php line 97
   OC\AppFramework\Middleware\Security\SecurityMiddleware->beforeController(OC\Core\Controll ... {}, "grantPage")
1. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/Http/Dispatcher.php line 125
   OC\AppFramework\Middleware\MiddlewareDispatcher->beforeController(OC\Core\Controll ... {}, "grantPage")
2. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/App.php line 172
   OC\AppFramework\Http\Dispatcher->dispatch(OC\Core\Controll ... {}, "grantPage")
3. /home/atwozico/cloud.rafiee.net/lib/private/Route/Router.php line 298
   OC\AppFramework\App::main("OC\\Core\\Contr ... r", "grantPage", OC\AppFramework\ ... {}, ["core.ClientFlowLogin.grantPage"])
4. /home/atwozico/cloud.rafiee.net/lib/base.php line 1047
   OC\Route\Router->match("/login/flow/grant")
5. /home/atwozico/cloud.rafiee.net/index.php line 36
   OC::handleRequest()
GET /index.php/login/flow/grant?stateToken=yNy991gVRsTANy3CevhCFyEHcHM0IDpQ83qy5YxFw9ha9rEUVfjHNyy011adD4R4&clientIdentifier=XOYtXZGqDrRU25HWDDAsABX7mREG8Careh6Ifa8iyEK4P7paS9WdHYiO9qErEMK2&oauthState=/repository/repository_callback.php?callback%3Dyes%26repo_id%3D9%26sesskey%3D1564sKWazx&user=&direct=0
from 2.177.144.0 at 2023-01-13T14:12:35+00:00
[no app in context] Debug: OC\AppFramework\Middleware\Security\Exceptions\CrossSiteRequestForgeryException: CSRF check failed at <<closure>>
   OC\AppFramework\Middleware\Security\SecurityMiddleware->beforeController(OCA\UserStatus\C ... {}, "heartbeat")
   OC\AppFramework\Middleware\MiddlewareDispatcher->beforeController(OCA\UserStatus\C ... {}, "heartbeat")
   OC\AppFramework\Http\Dispatcher->dispatch(OCA\UserStatus\C ... {}, "heartbeat")
   OC\AppFramework\App::main("OCA\\UserStatus ... r", "heartbeat", OC\AppFramework\ ... {}, ["ocs.user_status.Heartbeat.heartbeat"])
4. /home/atwozico/cloud.rafiee.net/ocs/v1.php line 63
   OC\Route\Router->match("/ocsapp/apps/us ... t")
5. /home/atwozico/cloud.rafiee.net/ocs/v2.php line 23
PUT /ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json
from 2.177.144.0 by admin at 2023-01-13T14:15:03+00:00
   OC::handleRequest()
    Symfony\Component\Routing\Generator\UrlGenerator->generate("contacts.contacts.directcircle", ["TT1WEMiyFfBVHelx7IHVvH46uq1FMa2"], 1)
    OC\Route\Router->generate("contacts.contacts.directcircle", ["TT1WEMiyFfBVHelx7IHVvH46uq1FMa2"])
    OC\URLGenerator->linkToRoute("contacts.contacts.directcircle", ["TT1WEMiyFfBVHelx7IHVvH46uq1FMa2"])
    OCA\Circles\Model\ModelManager->generateLinkToCircle("TT1WEMiyFfBVHelx7IHVvH46uq1FMa2")
 5. <<closure>>
    OCA\Circles\Service\FederatedUserService->getLocalFederatedUser("moodleclass")
    OCA\Circles\ShareByCircleProvider->getSharedWith("moodleclass", 7, null, -1, 0)
    OC\Share20\Manager->getSharedWith("moodleclass", 7, null, -1)
    OC\Files\SetupManager->setupForPath("/moodleclass/files")
19. /home/atwozico/cloud.rafiee.net/lib/private/Files/View.php line 1390
    OC\Files\Mount\Manager->find("/moodleclass/files")
20. /home/atwozico/cloud.rafiee.net/lib/private/Files/Node/Root.php line 205
    OC\Files\View->getFileInfo("/moodleclass/files")
21. /home/atwozico/cloud.rafiee.net/lib/private/Files/Node/LazyUserFolder.php line 43
    OC\Files\Node\Root->get("/moodleclass/files")
22. <<closure>>
    OC\Files\Node\LazyUserFolder->OC\Files\Node\{closure}("*** sensitive parameters replaced ***")
23. /home/atwozico/cloud.rafiee.net/lib/private/Files/Node/LazyFolder.php line 69
    call_user_func(Closure {})
24. /home/atwozico/cloud.rafiee.net/lib/private/Files/Node/LazyFolder.php line 510
    OC\Files\Node\LazyFolder->__call("getRecent", [7])
25. /home/atwozico/cloud.rafiee.net/apps/recommendations/lib/Service/RecentlyEditedFilesSource.php line 68
    OC\Files\Node\LazyFolder->getRecent(7)
26. /home/atwozico/cloud.rafiee.net/apps/recommendations/lib/Service/RecommendationService.php line 88
    OCA\Recommendations\Service\RecentlyEditedFilesSource->getMostRecentRecommendation(OC\User\User {}, 7)
27. <<closure>>
    OCA\Recommendations\Service\RecommendationService->OCA\Recommendations\Service\{closure}("*** sensitive parameters replaced ***")
28. /home/atwozico/cloud.rafiee.net/apps/recommendations/lib/Service/RecommendationService.php line 89
    array_reduce([OCA\Recommendat ... }], Closure {}, "*** sensitive parameters replaced ***")
29. /home/atwozico/cloud.rafiee.net/apps/recommendations/lib/Controller/RecommendationController.php line 82
    OCA\Recommendations\Service\RecommendationService->getRecommendations(OC\User\User {})
30. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/Http/Dispatcher.php line 225
    OCA\Recommendations\Controller\RecommendationController->always()
31. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/Http/Dispatcher.php line 133
    OC\AppFramework\Http\Dispatcher->executeController(OCA\Recommendati ... {}, "always")
32. /home/atwozico/cloud.rafiee.net/lib/private/AppFramework/App.php line 172
    OC\AppFramework\Http\Dispatcher->dispatch(OCA\Recommendati ... {}, "always")
33. /home/atwozico/cloud.rafiee.net/lib/private/Route/Router.php line 298
    OC\AppFramework\App::main("OCA\\Recommenda ... r", "always", OC\AppFramework\ ... {}, ["recommendations.recommendation.always"])
34. /home/atwozico/cloud.rafiee.net/lib/base.php line 1047
    OC\Route\Router->match("/apps/recommend ... s")
35. /home/atwozico/cloud.rafiee.net/index.php line 36
    OC::handleRequest()
GET /index.php/apps/recommendations/api/recommendations/always
from 2.177.144.0 by moodleclass at 2023-01-13T14:13:07+00:00
I have the same problem. Did you find a solution?
Thanks
Andreas
