Problem with memcache distributed Redis
I’m using the last version of Nextcloud, installed with the Plesk’s extension.
It works good (I’ve a problem with the indexing from search engine for shared files but this is another “story”) but when I try to set the cache the application crash, stop to works.
'memcache.distributed' => '\OC\Memcache\Redis',
'memcache.locking' => '\OC\Memcache\Redis',
'memcache.local' => '\OC\Memcache\APCu',
  'redis' => array(
    'host' => 'localhost',
    'port' => 6379,
In the logs I see this error:
no app in context
RedisException: Connection refused
If I remove:
It works good again.
I’ve Redis installed on the server as extension of the handler PHP 7.4 FPM.
Is there some extra configuration to do?
If I don’t use the memcache (distributed, local, locking) is a problem for Nextcloud or can I remove the above code and continue to work quietly?
Thanks.
I do not use Redis. But i think you can test “redis.sock” instead of the socket “localhost.6379”.
Read
Problems with config.php and Redis
For other settings search “redis.sock” in this forum.
https://help.nextcloud.com/search?q=redis.sock%20order%3Alatest
Additional:
Have you activated PHP Caching?
Search “Enable PHP OPcache” in https://docs.nextcloud.com/server/19/admin_manual/installation/server_tuning.html
Read also
https://docs.nextcloud.com/server/19/admin_manual/configuration_server/caching_configuration.html?highlight=redis
If I remove:
I also used Redis as caching backend. For me my configuration looks like this:
  'redis' =>
    'host' => '127.0.0.1',
    'port' => '6379',
    'timeout' => '0.0',
Can you connect to redis with redis-cli?
Unfortunately Redis Server is currently not supported on Plesk.
Is available a workaround with Redis Docker but Plesk Team suggest me don’t use APCu for local cache, because it’s old and no more supported, so I think it’s better wait for the moment.
I hope to see in the next versions of Nextcloud a more simple and modern way to manage the cache.
This is how it’s done in the Nextcloud VM:
My hosting provider has suggest not to use memcache but only enable Opcache on PHP (he told me that APCu should be used with great caution, it can generate a lot of problems on the server, is a cache technology outdate):
https://support.plesk.com/hc/en-us/articles/115000935049-How-to-ensure-that-Opcache-is-enabled-
In the Nextcloud documentation is indicated:
There are two types of caches to use: a PHP opcode cache, which is commonly called opcache, and data caching for your Web server. If you do not install and enable a local memcache you will see a warning on your Nextcloud admin page. A memcache is not required and you may safely ignore the warning if you prefer.
Did he tell you why, or is it just a lazy hosting provider that doesn’t care to much about installing the best for the customers? :smiley:
You’re right, I’ve insisted and they installed “Redis server”, now it works good.
Thanks.
