Hi, since this afternoon, i encounter a serious problem with my nextcloud install. when i tried to connect, instead of my usual login screen, i got the first install and setup screen.
Then, i connected it through SSH, and check the MariaDB access with : systemctl status mariadb.service
then, i got that :
● mariadb.service - MariaDB database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2017-10-16 16:07:16 UTC; 3min 50s ago
Process: 1236 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
Process: 1233 ExecStartPre=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Process: 1135 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=/usr/bin/galera_recovery
; [ $? -eq 0 ] && systemctl set-environmen
Process: 1131 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1128 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Main PID: 1236 (code=exited, status=1/FAILURE)
Status: “MariaDB server is down”
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1988952064 [Note] InnoDB: Percona XtraDB (http://www.percona.com) 5.6.35-80.0 started; log sequenc
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1420911424 [Note] InnoDB: Dumping buffer pool(s) not yet started
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1988952064 [Note] Plugin ‘FEEDBACK’ is disabled.
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1988952064 [Note] Recovering after a crash using tc.log
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1988952064 [ERROR] Can’t init tc log
Oct 16 16:07:13 raspberrypi mysqld[1236]: 2017-10-16 16:07:13 1988952064 [ERROR] Aborting
Oct 16 16:07:16 raspberrypi systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 16 16:07:16 raspberrypi systemd[1]: Failed to start MariaDB database server.
Oct 16 16:07:16 raspberrypi systemd[1]: mariadb.service: Unit entered failed state.
Oct 16 16:07:16 raspberrypi systemd[1]: mariadb.service: Failed with result ‘exit-code’.
I’m not very comfortable with Linux system, as i’m using windows server usually, so, can you help me ? it seems that MariaDB crashed and won’t restart correctly.
