Problem with Logging into NextCloud on Kuberbetes on Raspberrypi Stack
I am trying to log into my secured Nextcloud instance from outside my local network. I am using a url that is pointing to my IP address and all of this works fine. I get this page:
Access through untrusted domain
Please contact your administrator. If you are an administrator, edit the “trusted_domains” setting in config/config.php like the example in config.sample.php.
The problem is that I can’t seem to find this config.php on a Kubernetes installation. I am using Helm to connect to it and an Ubuntu 20.04 local machine. Everything is running properly with the exception that I do not know where the config file is to add a trusted domain.
Has anyone dealt with this issue?
Thank you
Did you add a Trusted Domain?
Thank you, but the files are not located in the places that the documentation tells me to find the.
This setup uses a yaml file. I have checked many times to be sure it is accurate. Still no success.
Got it. Check kubernetes documentation and figure out where /var/www nextcloud related directories are actually stored on your filesystem. Then you can adjust the commands to run properly
