I have installed Nextcloud on my NUC with Ubuntu and it works fine, however I have problems with the LetsEncrypt certifacte renewal by having nextcloud and my homepage hosted on the same installation
homepage dir is /var/www/html
Nexctloud dir is /var /www/html/nextclud
I have the config as follows (my server address is replaced with “MyServer”)
Problem:
Certificate renewal only works if I uncomment the first rows from currently commented out with # tag.
But homepage & nextcloud are only available when having them commented out.
Its obvious that I have not completely understood the system … but I do not find any example for a configuration with port 80 for homepage and port 443 for secured access for nextcloud.
Any hints ?? Thank you very much in advance.
Best regards
Holger
#<VirtualHost *:80>
#ServerName MyServer.com
#ErrorLog ${APACHE_LOG_DIR}/error.log
#CustomLog ${APACHE_LOG_DIR}/access.log combined
#Redirect permanent / https://myserver.com
#DocumentRoot /var/www.html
#</VirtualHost>
<IfModule mod_ssl.c>
SSLStaplingCache shmcb:/tmp/stapling_cache(128000)
<VirtualHost *:443>
DocumentRoot /var/www/html/nextcloud
# SSL Konfiguration
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/myserver.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/myserver.com/privkey.pem
SSLProtocol All -SSLv2 -SSLv3 -TLSv1.1
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
#Nextcloud Konfiguration
<Directory /var/www/html/nextcloud/>
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/html/nextcloud
SetEnv HTTP_HOME /var/www/html/nextcloud
</Directory>
</VirtualHost>
</IfModule>
