horst
September 21, 2021, 7:49am
1
we are using NC v. 21.0.3 with the group folders app v. 9.0.3 and have some questions about this app:
where is the thrasbin of the group folder, when files are deleted?
how do I get the groupfolder name to a respective ID under /datastore/__groupfolders/ ?
I tried to delete the trasbins of all group folders with “occ groupfolders:trashbin:cleanup”, but one trash folder does not to be cleared;
horst
September 22, 2021, 7:59am
2
the problem regarding to the IDs and the corresponding groupfolder name could be solved via search in the mysql database;
now I´m trying to delete the group folder trashbins via cron job:
sudo -u www-data php -f /var/www/html/occ groupfolders:trashbin:cleanup -n
sadly this does not clear the trash bins;
when I try sudo -u www-data php -f /var/www/html/occ groupfolders:trashbin:cleanup
and acknowledgde the following question manually with y
the trashbins get cleared;
wwe
September 22, 2021, 7:53pm
3
occ groupfolders:list
should work. see group folder command line config with occ for full reference. little extract below for better searching in this forum:
Group folders can be configured on the command line (cli) using the occ
command:
occ groupfolders:create <name>
→ create a group folder
occ groupfolders:delete <folder_id> [-f|--force]
→ delete a group folder and all its contents
occ groupfolders:expire
→ trigger file version expiration (see Nextcloud docs for details)
occ groupfolders:group <folder_id> <group_id> [-d|--delete] [write|share|delete]
→ assign groups and their rights to a group folder
→ list configured group folders
occ groupfolders:permissions
→ configure advanced permissions (see below for details)
occ groupfolders:quota <folder_id> [<quota>|unlimited]
→ set a quota for a group folder
occ groupfolders:rename <folder_id> <name>
→ rename a group folder
occ groupfolders:scan <folder_id>
→ trigger a filescan for a group folder
→ empty the trashbin of all group folders
