I hit a problem with this:
System Nextcloud 18 - docker-fpm
If you upload a file that contains the word “javascript” in its filename you can’t share it.
Hitting the share symbol just leads to an Error reading file data.
Reproducing is simple just name a file Testfile_javascript.txt and try to share it.
I didn’t investigate further as the simple workaround is to rename the file.
But I think it a little spooky, as if filenames are not treated with enough separation from the code. I don’t hope a lovingly crafted filename could be used to execute code.
btw. Thanks for Nextcloud
Dirk
