Problem with cron.php since data-restore
    • 29.0.13
    • Debian 12.10
    • Apache 2.4.62
    • 8.2.28
    • Yes
    • After data restoration today
    • BAre
After massive accidentally data deletion today, I had to restore the data.
Therefore I restored both, the data-directory and the database
Everything worked fine afterwards, except the Cronjob.
In the settings, I always get the message:
"Some jobs have not been executed since vor einem Tag. Please consider increasing the execution frequency. "
After setting the logging to “debug” and running cron.php manually, I get many of these errors:
(I had to shorten the logs…)
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Activity\\BackgroundJob\\EmailNotification (id: 2, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\Activity\\BackgroundJob\\EmailNotification (id: 2, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\Activity\\BackgroundJob\\EmailNotification (id: 2, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"29.0.13.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","Code":0,"Trace":[{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":208,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/cron.php","line":163,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\NextcloudAnnouncements\\Cron\\Crawler (id: 4, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\ServerInfo\\Jobs\\UpdateStorageStats (id: 20642, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\UserStatus\\BackgroundJob\\ClearOldStatusesBackgroundJob (id: 20644, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\UserStatus\\BackgroundJob\\ClearOldStatusesBackgroundJob (id: 20644, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\UserStatus\\BackgroundJob\\ClearOldStatusesBackgroundJob (id: 20644, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"29.0.13.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","Code":0,"Trace":[{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":208,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/cron.php","line":163,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_user_status"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\DAV\\BackgroundJob\\CalendarRetentionJob (id: 23009, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Circles\\Cron\\Maintenance (id: 23011, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\Circles\\Cron\\Maintenance (id: 23011, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"","method":"","url":"--","message":"[debug] running maintenance (3)","userAgent":"--","version":"29.0.13.2","data":{"app":""}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"","method":"","url":"--","message":"[debug] running maintenance (2)","userAgent":"--","version":"29.0.13.2","data":{"app":""}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\Circles\\Cron\\Maintenance (id: 23011, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Notifications\\BackgroundJob\\GenerateUserSettings (id: 27826, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Notifications\\BackgroundJob\\SendNotificationMails (id: 27827, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\Notifications\\BackgroundJob\\SendNotificationMails (id: 27827, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\Notifications\\BackgroundJob\\SendNotificationMails (id: 27827, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"29.0.13.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","Code":0,"Trace":[{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":208,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/cron.php","line":163,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_user_status","oc_notifications_settings"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\DAV\\BackgroundJob\\RefreshWebcalJob (id: 31877, arguments: {\"principaluri\":\"principals\\/users\\/Honey\",\"uri\":\"apidivvydiarycom-1\"})","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:13+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\DAV\\BackgroundJob\\RefreshWebcalJob (id: 31877, arguments: {\"principaluri\":\"principals\\/users\\/Honey\",\"uri\":\"apidivvydiarycom-1\"})","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\DAV\\BackgroundJob\\RefreshWebcalJob (id: 31877, arguments: {\"principaluri\":\"principals\\/users\\/Honey\",\"uri\":\"apidivvydiarycom-1\"}) in 1 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","userAgent":"--","version":"29.0.13.2","exception":{"Exception":"Exception","Message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","Code":0,"Trace":[{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":344,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":384,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":293,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":208,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/home/users/princessandhoney/www/nextcloud/cron.php","line":163,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/home/users/princessandhoney/www/nextcloud/lib/private/DB/Connection.php","Line":320,"message":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1","tables":["oc_appconfig","oc_jobs","oc_user_status","oc_notifications_settings","oc_calendarobjects","oc_calendarchanges","oc_calendarobjects_props","oc_calendarsubscriptions"],"reads":["oc_jobs"],"exception":{},"CustomMessage":"dirty table reads: SELECT * FROM `*PREFIX*jobs` WHERE (`reserved_at` <= :dcValue1) AND (`last_checked` <= :dcValue2) AND (`time_sensitive` = :dcValue3) ORDER BY `last_checked` ASC LIMIT 1"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\FilesReminders\\BackgroundJob\\ScheduledNotifications (id: 41942, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\FilesReminders\\BackgroundJob\\ScheduledNotifications (id: 41942, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\FilesReminders\\BackgroundJob\\ScheduledNotifications (id: 41942, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Files_Trashbin\\BackgroundJob\\ExpireTrash (id: 58375, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Polls\\Cron\\NotificationCron (id: 84824, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\Polls\\Cron\\NotificationCron (id: 84824, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\Polls\\Cron\\NotificationCron (id: 84824, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Polls\\Cron\\JanitorCron (id: 84825, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Polls\\Cron\\AutoReminderCron (id: 84826, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Forms\\BackgroundJob\\CleanupUploadedFilesJob (id: 94170, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Starting job OCA\\Forms\\BackgroundJob\\CleanupUploadedFilesJob (id: 94170, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":1,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"forms","method":"","url":"--","message":"Deleting files that were uploaded before 2025-03-19T14:10:14+00:00 and still not submitted.","userAgent":"--","version":"29.0.13.2","data":{"app":"forms"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":1,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"forms","method":"","url":"--","message":"Deleted 0 uploaded files.","userAgent":"--","version":"29.0.13.2","data":{"app":"forms"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":1,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"forms","method":"","url":"--","message":"Deleted 0 folders.","userAgent":"--","version":"29.0.13.2","data":{"app":"forms"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Finished job OCA\\Forms\\BackgroundJob\\CleanupUploadedFilesJob (id: 94170, arguments: null) in 0 seconds","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\Activity\\BackgroundJob\\RemoveFormerActivitySettings (id: 104820, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"jcBS5JoVeI5LfxKFQ24X","level":0,"time":"2025-03-19T15:10:14+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"CLI cron call has selected job OCA\\UpdateNotification\\BackgroundJob\\ResetToken (id: 104857, arguments: null)","userAgent":"--","version":"29.0.13.2","data":{"app":"cron"}}
{"reqId":"lAA5boLa9G5OLHCZWMhF","level":0,"time":"2025-03-19T15:10:23+00:00","remoteAddr":"81.10.245.56","user":"Honey","app":"logreader","method":"PUT","url":"/index.php/apps/logreader/api/settings","message":"Updating AppConfig: logLevel => 2","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:136.0) Gecko/20100101 Firefox/136.0","version":"29.0.13.2","data":{"app":"logreader"}}
            "princessandhoney.at",
            "www.princessandhoney.at"
        "dbtype": "mysql",
        "version": "29.0.13.2",
        "overwrite.cli.url": "http:\/\/princessandhoney.at",
        "dbport": "",
        "remember_login_cookie_lifetime": 15552000,
        "session_lifetime": 86400,
        "session_keepalive": true,
        "auto_logout": false,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "theme": "",
        "loglevel": 2,
        "redis": {
            "port": 6379
        "has_rebuilt_cache": true,
        "app_install_overwrite": [
            "bookmarks"
        "default_phone_region": "AT",
        "mysql.utf8mb4": true,
        "memories.exiftool": "\/home\/users\/princessandhoney\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
        "memories.vod.path": "\/home\/users\/princessandhoney\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "mail_smtpport": "25",
        "mail_smtpauth": 1,
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "memories.gis_type": 1
  - activity: 2.21.1
  - bookmarks: 14.2.7
  - bruteforcesettings: 2.9.0
  - calendar: 4.7.16
  - circles: 29.0.0-dev
  - cloud_federation_api: 1.12.0
  - comments: 1.19.0
  - contacts: 6.0.4
  - contactsinteraction: 1.10.0
  - cookbook: 0.11.3
  - cospend: 1.6.1
  - dashboard: 7.9.0
  - dav: 1.30.1
  - external: 5.4.1
  - federatedfilesharing: 1.19.0
  - federation: 1.19.0
  - files: 2.1.1
  - files_downloadlimit: 2.0.0
  - files_external: 1.21.0
  - files_pdfviewer: 2.10.0
  - files_reminders: 1.2.0
  - files_sharing: 1.21.0
  - files_trashbin: 1.19.0
  - files_versions: 1.22.0
  - firstrunwizard: 2.18.0
  - forms: 4.3.10
  - keeweb: 0.6.20
  - logreader: 2.14.0
  - lookup_server_connector: 1.17.0
  - metadata: 0.22.0
  - nextcloud_announcements: 1.18.0
  - notifications: 2.17.0
  - oauth2: 1.17.1
  - password_policy: 1.19.0
  - polls: 7.4.1
  - privacy: 1.13.0
  - provisioning_api: 1.19.0
  - recommendations: 2.1.0
  - related_resources: 1.4.0
  - serverinfo: 1.19.0
  - settings: 1.12.0
  - sharebymail: 1.19.0
  - support: 1.12.0
  - survey_client: 1.17.0
  - systemtags: 1.19.0
  - tasks: 0.16.1
  - theming: 2.4.0
  - twofactor_backupcodes: 1.18.0
  - twofactor_totp: 11.0.0-dev
  - updatenotification: 1.19.1
  - user_status: 1.9.0
  - viewer: 2.3.0
  - weather_status: 1.9.0
  - workflowengine: 2.11.0
  - admin_audit: 1.19.0
  - deck: 1.11.4 (installed 1.11.4)
  - encryption: 2.17.0
  - notes: 4.9.4 (installed 4.9.4)
  - photos: 2.5.0 (installed 2.5.0)
  - previewgenerator: 5.8.0 (installed 5.8.0)
  - quicknotes: 0.8.10 (installed 0.8.10)
  - suspicious_login: 7.0.0
  - text: 3.10.1 (installed 1.1.1)
  - user_ldap: 1.20.0
I hope you can help me, so that I get this working again…
Many thanks in advance!!
Andi
How are you triggering cron normally?
For what it’s worth, those aren’t errors. They’re just visible since you have debug level logging on. I don’t see anything too odd about them.
You said you did a restore… perhaps the crontab entry you previously had was removed? See the Admin Manual section Cron jobs to see the different run methods.
thanks for your fast response here.
I’m running the cron from the crontab, and I already checked it:
Output of “crontab -e -u princessandhoney”
*/5 * * * * keyhelp-php81 --define apc.enable_cli=1 -f /home/users/princessandhoney/www/nextcloud/cron.php > /dev/null
And for testing now, I’m running this command manually from the commandline.
When you look into the log in my first post, you see, that cron is actually executing.
Although it’s running, the Admin-Interface is showing, that it hasn’t run for over a day.
How does this cronjob run-detection work in detail?
Maybe there is an issue due to my restore.
Andi
PS: I looked after the “lastcron” value in the database,
and I see, that the time gets updated there.
(see attached Screenshot)
Bildschirmfoto vom 2025-03-19 20-54-16
Hello!
OMG… since today morning, it starts working again.
Don’t know why, but the problem is gone, and it shows
the run of cron correct now.
Many thanks!
Andi
@mills1975 It’s now working after a day because of the maintenance window. If you just start cron via cli, not all jobs are executed. You can manually adjust the maintenance_window_start to 100 to ignore it (e.g. for your manual cron run).
Thanks for this information… I looked after this parameter in my config… it’s set to “1”.
I really think, this is the point.
Maybe because the time, the restored backup was taken, was 3am.
And the restore has been around 10am.
