Problem with cron jobs
    • 32.0.1
    • Linux localhost 4.18.0-553.53.1.el8_10.x86_64 #1 SMP
    • Apache/2.4.65 (Unix)
    • none
    • 8.2.29
    • no
    • 2 or 3 releases back
    • hosting at strato
    • no
In administration overview is a message “Last background job ran 3 months ago. Something seems to be wrong. Check the background job settings.”
I tested it with ajax, webcron, cron - all the same error
Webocc gives after background-job:list a list from 2 to 11229!
Webocc maintance:repair output is attached - also setupcheck
How can I start or delete jobs that have not been run via webocc?
Why are neither ajax, webcron, nor cron working?
I only have very limited access to the environment at Strato, either via FTP or SSH. I can’t schedule a cron job or similar. crontab -l returns “command not found.”
- Repair MySQL collation
     - All tables already have the correct collation -> nothing to do
 - Clean tags and favorites
     - 0 tags of deleted users have been removed.
     - 0 tags for delete files have been removed.
     - 0 tag entries for deleted tags have been removed.
     - 0 tags with no entries have been removed.
 - Repair invalid shares
 - Move .step file of updater to backup location
 - Add move avatar background job
     - Repair step already executed
 - Add preview cleanup background jobs
 - Migrate oc_properties table to nextcloud schema
     - oc_properties table does not exist.
 - Migrate oauth2_clients table to nextcloud schema
     - Update the oauth2_access_tokens table schema.
     - Update the oauth2_clients table schema.
     - Delete clients (and their related access tokens) with the redirect_uri starting with oc:// or ending with *
 - Repair language codes
 - Add log rotate job
 - Clear frontend caches
     - Image cache cleared
     - JS cache cleared
 - Clear every generated avatar
 - Add preview background cleanup job
 - Queue a one-time job to cleanup old backups of the updater
 - Cleanup invalid photocache files for carddav
 - Add background job to cleanup login flow v2 tokens
 - Remove potentially over exposing share links
     - No need to remove link shares.
 - Clear access cache of projects
 - Reset generated avatar flag
 - Keep legacy encryption enabled
 - Check encryption key format
 - Remove old dashboard app config data
 - Add job to cleanup the bruteforce entries
 - Queue a one-time job to check for user uploaded certificates
 - Repair DAV shares
 - Add background job to set the lookup server share state for users
 - Add token cleanup job
 - Clean up abandoned apps
 - Add possibly missing system config
 - Add AI tasks cleanup jobs
 - Queue a job to generate metadata
 - Cache logo dimension to fix size in emails on Outlook
     - Theming is not used to provide a logo
 - Remove legacy ".ocdata" file
 - Add cleanup-deleted-users background job
 - Validate account properties and store phone numbers in a known format for search
     - Queued background to validate account properties.
 - Migrate config keys
 - AppAPI Daemons configuration GPU params update
     - Daemons configuration GPU params updated: 0
 - Fix component of birthday calendars
     - 0 birthday calendars updated.
 - Regenerating birthday calendars to use new icons and fix old birthday events without year
 - Fix broken values of calendar objects
    0 [>---------------------------    0 [->--------------------------]
] - Registering building of calendar search index as background job
 - Register building of social profile search index as background job
 - Registering background jobs to update cache for webcal calendars
     - Added 0 background jobs to update webcal calendars
 - Registering building of calendar reminder index as background job
 - Register a background job to update rooms and resources
 - Queue jobs to clean up orphan event and contact data
 - Remove activity entries of private events
     - Removed 0 activity entries
 - Clean up old calendar subscriptions from deleted users that were not cleaned-up
    0 [--->------------------------    0 [----->----------------------]
]     - 0 calendar subscriptions without an user have been cleaned up
 - Write default encryption module configuration to the database
 - Fix the share type of guest shares when migrating from ownCloud
 - Copy the share password into the dedicated column
 - Set existing shares as accepted
 - Converts owncloud guests to nextcloud guests
 - Reset the email of all guest accounts
 - Update OAuth token expiration times
 - Force-reset all Text document sessions
 - Initialize migration of background images from dashboard to theming app
 - Add background job to check for backup codes
 - Populating added database structures for workflows
    system:
        ✗ AppAPI-Bereitstellungs-Daemon: Der Standard-Deploy-Daemon von AppAPI ist nicht eingerichtet. Bitte in den Einstellungen einen Stand
ard-Deploy-Daemon registrieren, um externe Apps (Ex-Apps) zu installieren.
        ⚠ Fehler im Protokoll: 1 Warnungen in den Protokollen seit 18. Oktober 2025, 23:20:55
        ✓ Zulässige Administrations-IP-Bereiche: IP-Filterung durch Administration ist nicht aktiv.
        ✓ Brute-Force-Drosselung: Deine Remote-Adresse "2003:fb:…….." ist nicht durch die Brute-Force-Erkennung gedrosselt.
        ✓ Cron-Fehler: Der letzte Cron-Job wurde ohne Fehler ausgeführt.
        ✗ Cron zuletzt ausgeführt: Letzte Hintergrundaufgaben-Ausführung lief Vor 3 Monaten. Etwas scheint nicht in Ordnung zu sein. Check the background job settings.
        ✓ Debug-Modus: Debug-Modus ist deaktiviert.
        ℹ Transaktionale Dateisperre: Die Datenbank wird für transaktionale Dateisperren verwendet. Um die Leistung zu verbessern, konfiguriere bitte Memcache, falls verfügbar.
        ✓ Beginn des Wartungsfensters: Wartungsfenster zur Ausführung von umfangreichen Hintergrundaufgaben liegt zwischen 1:00 UTC und 7:00 UTC
        ℹ Memcache: Es wurde kein Speichercache konfiguriert. Um die Leistung zu verbessern, sofern verfügbar, bitte Memcache konfigurieren.
        ✓ MIME-Type-Migrationen verfügbar: None
        ✓ Architektur: 64-bit
        ✓ Temporärer Platz verfügbar: Das temporäre Verzeichnis ist korrekt konfiguriert:
- 3.9 GiB verfügbar in /tmp (PHP temporäres Verzeichnis)
- 5595.9 GiB verfügbar in /…../nextcloud/tmp (Nextcloud temporäres Verzeichnis)
        ✓ Push-Dienst: Kostenloser Push-Dienst
    dav:
        ✓ DAV-Systemadressbuch: Keine ausstehende Synchronisierung des DAV-Systemadressbuchs
    network:
        ✓ WebDAV-Endpunkt: Der Webserver ist ordnungsgemäß eingerichtet um Dateisynchronisation über WebDAV zu ermöglichen.
        ✓ Datenverzeichnis geschützt
        ✓ Internetverbindung
        ✓ Unterstützung für JavaScript-Quellkarten
        ✓ JavaScript-Modulunterstützung
        ✓ OCS Anbieter-Auflösung
        ✓ .well-known URLs: Der Server ist korrekt für die Bereitstellung von `.well-known`-URLs konfiguriert.
        ✓ Laden der Schriftartdatei
    notifications:
        ✓ Push-Benachrichtigungen – Fair-Use-Richtlinie
    security:
        ✓ Besitzer der App-Ordner: App-Ordner haben den richtigen Besitzenden ""
        ✓ Alte, von der Administration importierte Zertifikate
        ✓ Codeintegrität: Keine veränderten Dateien
        ✓ Für Header weitergeleitet
        ✓ HTTPS-Zugriff und URLs: Du greifst über eine sichere Verbindung auf deine Instanz zu, und deine Instanz erstellt sichere URLs.
        ✓ Alte serverseitige Verschlüsselung: Deaktiviert
        ✓ PHP-Version: Es wird aktuell PHP 8.2.29 verwendet.
        ✓ Zufallsgenerator: Sicher
        ✓ HTTP-Header: Der Server ist korrekt für das Senden von Sicherheitsheadern konfiguriert.
    database:
        ✓ In der Datenbank fehlen Spalten: None
        ✓ In der Datenbank fehlen Indizes: None
        ✓ In der Datenbank fehlen Primärschlüssel: None
        ✓ Datenbank mit ausstehenden Bigint-Migrationen: None
        ✓ MySQL-Zeilenformat: Keine deiner Tabellen verwendet ROW_FORMAT=Compressed
        ✓ MySQL Unicode-Unterstützung: MySQL wird als Datenbank verwendet und unterstützt 4-Byte-Zeichen
        ✓ Größe der Planungsobjekttabelle: Die Größe der Planungsobjekttabelle liegt im akzeptablen Bereich.
        ✓ Datenbankversion: 8.0.36
        ✓ Isolationsstufe der Datenbanktransaktion: Read committed
    config:
        ✓ Standard-Telefonregion: DE
        ✓ E-Mail-Test: Die Test-E-Mail wurde versandt
        ✓ CLI-URL überschreiben: Die Option "overwrite.cli.url" in deiner config.php ist korrekt auf "https://myurl/nextcloud" festgelegt.
        ✓ Zugriffsrechte für die Konfigurationsdatei: Die Nextcloud-Konfigurationsdatei ist beschreibbar
    php:
        ✓ PHP-Standardzeichensatz: UTF-8
        ✓ PHP set_time_limit: Die Funktion ist verfügbar.
        ✓ Freetype: Unterstützt
        ✓ PHP APCu-Konfiguration
        ✓ PHP getenv
        ✓ PHP-Speicherlimit: 512 MB
        ℹ PHP-Module: Dieser Instanz fehlen einige empfohlene PHP-Module. Für eine verbesserte Leistung und bessere Kompatibilität wird dring
end empfohlen, diese zu installieren:
- sysvsem
        ✓ PHP OPcache: Korrekt konfiguriert
        ✓ PHP-Option "output_buffering": Deaktiviert
        ✓ PHP Imagick-Modul
    ai:
        ✓ Abholgeschwindigkeit für Aufgabenverarbeitung: Keine geplanten Aufgaben in den letzten 14 Tagen.
PASTE
PASTE HERE
  - activity: 5.0.0-dev.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0
  - calendar: 6.0.2
  - contacts: 8.0.4
  - dashboard: 7.12.0
  - dav: 1.34.2
  - encryption: 2.20.0
  - files: 2.4.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - guests: 4.6.0
  - logreader: 5.0.0-dev.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - occweb: 0.2.3
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - circles: 32.0.0 (installed 22.1.1)
  - comments: 1.22.0 (installed 1.12.0)
  - contactsinteraction: 1.13.1 (installed 1.3.0)
  - federation: 1.22.0 (installed 1.12.0)
  - files_downloadlimit: 5.0.0-dev.0 (installed 3.0.0)
  - files_external: 1.24.0
  - files_pdfviewer: 5.0.0-dev.0 (installed 3.0.0)
  - files_reminders: 1.5.0 (installed 1.4.0)
  - files_versions: 1.25.0 (installed 1.15.0)
  - firstrunwizard: 5.0.0-dev.0 (installed 2.11.0)
  - nextcloud_announcements: 4.0.0-dev.0 (installed 1.11.0)
  - photos: 5.0.0-dev.1 (installed 4.0.0-dev.1)
  - recommendations: 5.0.0-dev.0 (installed 1.1.0)
  - related_resources: 3.0.0-dev.0 (installed 1.5.0)
  - sharebymail: 1.22.0 (installed 1.12.0)
  - support: 4.0.0-dev.0 (installed 1.5.0)
  - survey_client: 4.0.0-dev.0 (installed 2.0.0)
  - systemtags: 1.22.0 (installed 1.12.0)
  - user_ldap: 1.23.0
  - weather_status: 1.12.0 (installed 1.10.0)
How did you set up the cron job?
What happens, when you run the job manually in a console?
