example
longer
example
here
Nextcloud version 20.0.9
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
IBM offers 25 Gigs of free S3 compatible cloud, which I’d like to use as external (non-critical) storage for my nextcloud installation. I have been able to access my IBM storage with “rclone”. Using the same setup with nextcloud, I can’t get the external storage to nextcloud.
Based on the error message, it appears as after setting up the config in nextcloud, Nc tries to create the bucket. That command fails, perhaps because the bucket already exists or what not.
IBM cloud should be S3 compatible, but dang, no go. I triws with the “path style” enabled and disabled, but no difference.
As for other S3 compatible providers, I got BackBlaze s3 configured just fine without issues.
Is there anything I could still try or is this something that requires fixing in the way nextcloud communicates with s3 storage when new configuration is initialized? (Ie am I out of luck and need to wait for update to NC?)
Below is screenshot showing some of the error message that I get when trying to configure IBM S3.
