after upgrading vom owncloud 8 to nextcloud 9 there is an error about the code integrity.
checking the files there is the following result:
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- core
- EXTRA_FILE
- tmp/oc_tmp_82Ce2X-folder/.htaccess
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[tmp/oc_tmp_82Ce2X-folder/.htaccess] => Array
[expected] =>
[current] => 8a7dbece25e682d31437d522b80eaf5325b618078cbc9f00bb7f3f066a01cb4b054c82ee8538b1732d514528e7fc2dc89e6e08eb64cc071b7c39417ad5a2f879
haha,
these file is not in the desired folder, it seems to be a temoprary file.
It removed the TMP path from the config.php as a workaround.
problem with code integrity after updating from 9.0.50 to 9.0.51
them.
Results
- core
- INVALID_HASH
- 3rdparty/symfony/console/Helper/ProgressHelper.php
- core/doc/admin/configuration_server/security_setup_warnings.html
- core/doc/user/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.ttf
- gallery
- INVALID_HASH
- js/vendor/dompurify/LICENSE
- calendar
- INVALID_HASH
- core/vendor/moment/locale/id.js
- core/vendor/fullcalendar/dist/fullcalendar.min.js
- files_pdfviewer
- INVALID_HASH
- vendor/pdfjs/web/cmaps/Adobe-Japan1-UCS2.bcmap
Raw output
Array
[core] => Array
[INVALID_HASH] => Array
[3rdparty/symfony/console/Helper/ProgressHelper.php] => Array
[expected] => eac0ae99a9e9381388252321f45c22bde1fa5dc84cf4fd24494f180acf5dd3aa43b198ae678046c64933d029065946095ca2da5d921f4239b2d2538ebfc00102
[current] => c4b314075e0343be658c7ccbf0474b8c101b017964f0a392e0099a8f2ceeae2d4df81fd2d171cc54cbc78c4dbadbbe1479ad3444ee2acb2da61972c6d8db6227
[core/doc/admin/configuration_server/security_setup_warnings.html] => Array
[expected] => e26038a0385c552fc204ab7132fc12968a9ab90e1c9164374e6862a75de747344db3a61b5c0022af15c96945ac4b7b9d48b71d348410e43222ba32d143651ef4
[current] => 0b3fa2fbb5c9256121db06b96199524d41964ffba74e734828dc991d8583ffc5a825e03007fd3624d952ba2d7c20e871c6e893dc2e9947c35c98222492ae7c01
[core/doc/user/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.ttf] => Array
[expected] => d2962cd2d2b2d081f8880688ff0ad05d01bf5def9c7669e483fae5d1aa4159a5d9b6f1f3da90b536cfb22b664e9fbb0d9f3ccd2a4a0fa85ec0d624d0b865b1ae
[current] => 044f81d401b4853e4ecf0a705f7611069e3e11fb364cf949f4ed5bf6844ccb65a79429f7491ba2e23446e0826be822a81b58cce3e8b21369490450ec948b56cb
[gallery] => Array
[js/vendor/dompurify/LICENSE] => Array
[expected] => b0cd3a6247f4239d99c76d225c331a4e744700a2f1d9b1f8a1ed5f30cde95fb5112b8d79cb9e14defc0d8db2c5d58769b84045268ea39e3dda74c961716b9936
[current] => 2d66469f83c72b3e4f92dcb66c9453018a8bbe4c0da2bb041acb0d790460f1ddb9e14fc3762de81fcaeba5ca8a727bf2953899ae563b95cafedf9837fa209f63
[calendar] => Array
[core/vendor/moment/locale/id.js] => Array
[expected] => 92241f3d9df8c69bd89598554bb9bc2aefacfc4823faffcc50c4aba294e93d1dbc6b655a816349da9501ea8bc348bd99743e57ebdd8179d8415647e9955f7953
[current] => 28c442f1703cb8f720c3d8cf23cdf99e547d526ca5fb9ff95949c1b8aecc1ed0ff155a89056f2324cad41fff358c93ac2f58461aa57daf135cecd05e6bac5bf9
[core/vendor/fullcalendar/dist/fullcalendar.min.js] => Array
[expected] => 7565fd202dcb0e35710a3c4f892adfa26d1b737dd9eae09ba9ba25ea52869e4e7e9b0d6c3d481e61f12c41a21df1fa4f7642d991cc81cbae298617514974542d
[current] => 85a304ecdf48f6d8de0fc683ce2e3e79854e8f0e2f86f442374b3b1a86982a7050c8abdfcfd12292340c557480591697a2d4d3463054180f000c369b3e87ec82
[files_pdfviewer] => Array
[vendor/pdfjs/web/cmaps/Adobe-Japan1-UCS2.bcmap] => Array
[expected] => d0711b8e37d8be245984956492e245447ab4c3875a569c6f1475f1c116aa51916c773faeb7e09630875a0bb085fa0284ef5c7f82a574392fd4b85a8cd4b34737
[current] => 048c0e6e2f642a7b17f7ed6fbeebb076e7541e1e8cc79675b6ba8a16cb8f2f60da399cb6642c461271057e4a8e559b0c1f42a947ddf6f8170ff433e2e49067e5
@cybero2912 how did you upload these files? FTP?
no - I used wget and then extracted directly on server
How exactly did you upgrade
renamed old nextcloud folder
copied new into /var/www
copied config.php /data from renamed folder into new
set permissions:
#!/bin/bash
ncpath='/var/www/nextcloud'
htuser='www-data'
htgroup='www-data'
rootuser='root'
printf "Creating possible missing Directories\n"
mkdir -p $ncpath/data
mkdir -p $ncpath/assets
mkdir -p $ncpath/updater
printf "chmod Files and Directories\n"
find ${ncpath}/ -type f -print0 | xargs -0 chmod 0640
find ${ncpath}/ -type d -print0 | xargs -0 chmod 0750
printf "chown Directories\n"
chown -R ${rootuser}:${htgroup} ${ncpath}/
chown -R ${htuser}:${htgroup} ${ncpath}/apps/
chown -R ${htuser}:${htgroup} ${ncpath}/assets/
chown -R ${htuser}:${htgroup} ${ncpath}/config/
chown -R ${htuser}:${htgroup} ${ncpath}/data/
chown -R ${htuser}:${htgroup} ${ncpath}/themes/
chown -R ${htuser}:${htgroup} ${ncpath}/updater/
chmod +x ${ncpath}/occ
printf "chmod/chown .htaccess\n"
if [ -f ${ncpath}/.htaccess ]
then
chmod 0644 ${ncpath}/.htaccess
chown ${rootuser}:${htgroup} ${ncpath}/.htaccess
fi
if [ -f ${ncpath}/data/.htaccess ]
then
chmod 0644 ${ncpath}/data/.htaccess
chown ${rootuser}:${htgroup} ${ncpath}/data/.htaccess
fi
done
@cybero2912 Can you ZIP the files that the integrity checker complains about and upload somewhere? Would be awesome if I could have a look. Thanks a lot!
Hello Lukas,
I sent you a mail with the files attached
Hello Lukas,
any news on that?
