Dear NCP users,
I was using NCP on a raspberry 3 for a few months now and was quite happy. However, since two days I cannot login via the webinterface anymore, and my calendar apps (phone, pc,…) tell me they cannot sync because of a wrong/outdated security certificate.
Thus I tried to run the letsencrypt command to get a new one. However, I always received the error, that the verification process of the certificate did fail and I should check my A/AAAA configuration. I do have port forwarding for 80 and 443 set up on my router.
After some googling, I could renew the certificate by deactivating the “httpsonly” functionality in ncp. But still, I can’t access the webinterface of nc, nor can I sync my calendars - independent if I switch the “httpsonly” on or off.
I can access the raspberry via ssh or the RASPBERRYIPADRESS:4443 from within the network though (how I could apply the above mentioned changes).
The info panel gives the following output:
System Info
| NextCloudPi version | v1.10.9 |
| NextCloudPi image | NextCloudPi_11-22-18 |
| distribution | Raspbian GNU/Linux 9 \n \l |
| automount | yes |
| USB devices | sda |
| datadir | /media/USBdrive/ncdata |
| data in SD | no |
| data filesystem | btrfs |
| data disk usage | 931G/932G |
| rootfs usage | 2.0G/15G |
| swapfile | /var/swap |
| dbdir | /var/lib/mysql |
| Nextcloud check | ok |
| Nextcloud version | 15.0.5.3 |
| HTTPD service | up |
| PHP service | up |
| MariaDB service | up |
| Redis service | up |
| Postfix service | up |
| internet check | ok |
| port check 80 | open |
| port check 443 | open |
| IP | 192.168.178.2 |
| gateway | 192.168.178.1 |
| interface | eth0 |
| certificates | XXXXXXXXX.myfritz.net |
| NAT loopback | no |
| uptime | 11min |
What else could I check/do?
Thank you
