Problem with building full docker image from example nextcloud:31.0.8-apache
I’m having trouble creating my own Docker image. Every time a new version of Nextcloud comes out, I create my own Docker image.
I use the Docker file from the examples directory.
docker/.examples/dockerfiles/full/apache
I only change the FROM line to the latest one: nextcloud:31.0.8-apache
Something has changed, because in previous versions I had no problems creating a Docker image.
When I try to build it I got an error regarding libmagickcore.
docker build -t majherek/nextcloud:31.0.8 --network host .
DEPRECATED: The legacy builder is deprecated and will be removed in a future release.
            Install the buildx component to build images with BuildKit:
            https://docs.docker.com/go/buildx/
Sending build context to Docker daemon   7.68kB
Step 1/7 : FROM nextcloud:31.0.8-apache
 ---> b5fcb9799d0d
Step 2/7 : RUN set -ex;         apt-get update;     apt-get install -y --no-install-recommends         ffmpeg         ghostscript         libmagickcore-6.q16-6-extra         procps         smbclient         supervisor        libreoffice     ;     rm -rf /var/lib/apt/lists/*
 ---> Running in e9e44a34d4db
+ apt-get update
Hit:1 http://deb.debian.org/debian trixie InRelease
Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
Get:3 http://deb.debian.org/debian-security trixie-security InRelease [43.4 kB]
Get:4 http://deb.debian.org/debian trixie/main amd64 Packages [9668 kB]
Get:5 http://deb.debian.org/debian trixie-updates/main amd64 Packages [2432 B]
Get:6 http://deb.debian.org/debian-security trixie-security/main amd64 Packages [11.6 kB]
Fetched 9772 kB in 2s (5940 kB/s)
Reading package lists...
+ apt-get install -y --no-install-recommends ffmpeg ghostscript libmagickcore-6.q16-6-extra procps smbclient supervisor libreoffice
Building dependency tree...
Reading state information...
E: Unable to locate package libmagickcore-6.q16-6-extra
E: Couldn't find any package by glob 'libmagickcore-6.q16-6-extra'
E: Couldn't find any package by regex 'libmagickcore-6.q16-6-extra'
The command '/bin/sh -c set -ex;         apt-get update;     apt-get install -y --no-install-recommends         ffmpeg         ghostscript         libmagickcore-6.q16-6-extra         procps         smbclient         supervisor        libreoffice     ;     rm -rf /var/lib/apt/lists/*' returned a non-zero code: 100
I change libmagickcore-6.q16-6-extra to libmagickcore-7.q16-10-extra.
Then I got an error regarding libc-client-dev:
+ apt-get install -y --no-install-recommends libbz2-dev libc-client-dev libkrb5-dev libsmbclient-dev
E: Unable to locate package libc-client-dev
The command '/bin/sh -c set -ex;         savedAptMark="$(apt-mark showmanual)";         apt-get update;     apt-get install -y --no-install-recommends         libbz2-dev         libc-client-dev         libkrb5-dev         libsmbclient-dev     ;         docker-php-ext-configure imap --with-kerberos --with-imap-ssl;     docker-php-ext-install         bz2         imap     ;     pecl install smbclient;     docker-php-ext-enable smbclient;         apt-mark auto '.*' > /dev/null;     apt-mark manual $savedAptMark;     ldd "$(php -r 'echo ini_get("extension_dir");')"/*.so         | awk '/=>/ { so = $(NF-1); if (index(so, "/usr/local/") == 1) { next }; gsub("^/(usr/)?", "", so); print so }'         | sort -u         | xargs -r dpkg-query --search         | cut -d: -f1         | sort -u         | xargs -rt apt-mark manual;         apt-get purge -y --auto-remove -o APT::AutoRemove::RecommendsImportant=false;     rm -rf /var/lib/apt/lists/*' returned a non-zero code: 100
Is it about the linux-libc-dev package?
I can’t find it anywhere: Debian -- Package Search Results -- libc-client-dev
I got the same error and issue. With just removing it from the Dockerfile, my version was built successfully, and I haven’t got any error shown in the admin overview. Not sure if It’s still needed for NC 31.0.8
The image was recently bumped from Debian Bookworm to Debian Trixie.
I believe it’s because the package was bumped in Debian and has a hardcoded version (it’s a bit of an oddball):
I thought it was only me. I’m using nextcloud:fpm, but it’s the exact same behavior with the same errors.
Even after commenting libmagickcore-6.q16-6-extra and also libc-client-dev it leads to other errors.
The same problem here! Could someone share an example of working Dockerfile or fix docker/.examples/dockerfiles/full/apache ?
Even updating to the new package it still fails with exit code 100. Damn.
My working Dockerfile for now based on this comment:
FROM nextcloud:apache
RUN set -ex; \
    apt-get update; \
    apt-get install -y --no-install-recommends \
        ffmpeg \
        ghostscript \
        libmagickcore-7.q16-10-extra \
        imagemagick \
        procps \
        smbclient \
        supervisor \
RUN set -ex; \
    savedAptMark="$(apt-mark showmanual)"; \
    apt-get update; \
        libbz2-dev \
#        libc-client-dev \ # Throws error with Trixie
        libkrb5-dev \
        libsmbclient-dev \
# # # Workaround: libc-client-dev is installed from buster image
# Add Buster repository for libc-client-dev only
RUN echo "deb [signed-by=/usr/share/keyrings/debian-archive-keyring.gpg] http://archive.debian.org/debian/ buster main" > /etc/apt/sources.list.d/buster.list
# Install libc-client-dev package from Buster repository
RUN apt-get update && apt-get install -y libc-client-dev
# Clean up the added repository and pin file
RUN rm /etc/apt/sources.list.d/buster.list && apt-get update;
RUN set -ex; \
    docker-php-ext-configure imap --with-kerberos --with-imap-ssl; \
    docker-php-ext-install \
        bz2 \
        imap \
    pecl install smbclient; \
    docker-php-ext-enable smbclient; \
# reset apt-mark's "manual" list so that "purge --auto-remove" will remove all build dependencies
#    apt-mark auto '.*' > /dev/null; \
#    apt-mark manual $savedAptMark; \
#    ldd "$(php -r 'echo ini_get("extension_dir");')"/*.so \
#        | awk '/=>/ { so = $(NF-1); if (index(so, "/usr/local/") == 1) { next }; gsub("^/(usr/)?", "", so); print so }' \
#        | sort -u \
#        | xargs -r dpkg-query --search \
#        | cut -d: -f1 \
#        | sort -u \
#        | xargs -rt apt-mark manual; \
#    apt-get purge -y --auto-remove -o APT::AutoRemove::RecommendsImportant=false; \
RUN mkdir -p \
    /var/log/supervisord \
    /var/run/supervisord \
COPY supervisord.conf /
ENV NEXTCLOUD_UPDATE=1
CMD ["/usr/bin/supervisord", "-c", "/supervisord.conf"]
What is the reason the libmagickcore package is needed in the first place again? I have it in my build, but I forgot why. Is it needed any more at all?
Edit: It seems like libmagickcore-6.q16-10-extra (and now 7) has been included in the base image at least since v30.
SVG support (mostly icon generation).
Different versions of it have been in the image for several years.
