Hello
I have problem with request to add row i table. After POST reuest /index.php/apps/tables/api/1/tables/10/rows the response is:
“message”: “Column with id 0 is not part of table with id 10”
What’s wrong?
Hello
What’s wrong?
I also get this message trying to add a new row via POST-Request.
The message is referring to
“colum with id 0”
allthough id 0 isn’t part of my request.
My data structure looks like this:
data ={
"tableId": 11,
"createdBy": "user",
"createdAt": "2023-04-01 09:20:42",
"lastEditBy": "user",
"lastEditAt": "2023-04-01 09:20:42",
"data":
"columnId": 101,
"value": {"Col1": "Tiger"}
Is there an error in my structure or could this be an API internal related issue?
I checked tableId and columnId. They are correct. GET request work just fine.
Maybe API documentation differs from actual requirements? Could 0 be used as default columnId value?
I am running tables V0.7 beta2 and used OCS API Viewer and Python for testing. Both ways leading to the same result.
Did others run into this message as well?
I got the same error, too.
I did manage to perform all CRUD operations on Tables API from python. ![]()
Creation and Update data format is not so well documented on APIv1. ![]()
« Data as key - value store »
How make it work in OCS API Viewer?
May be the Tables app is too joung?
The actual accepted data JSON to send format is: (mapped column id ==> data
data ={
"data":
"23": "Ivan",
"24": "Dutest",
"25": "ivan@invalid.email"
php code also duplicated here (Create/insert)
Seem joung code to me…
I’m currently developping a PoC on this Tables API for a project.
I could publish the python wrapper library under LGPL would you be intersted?
full working code:
EDIT :
import requests
import json
from dotenv import load_dotenv
import os
load_dotenv() # take environment variables from .env.
username = "admin"
password = os.getenv('ADMIN_PASSWORD')
nextcloud_url = os.getenv('NEXTCLOUD_URL')
data ={
"data":
"23": "Ivan",
"24": "Dutest",
tableId = 4
url_path = f"/index.php/apps/tables/api/1/tables/{tableId}/rows"
response = requests.post(
f"{nextcloud_url}{url_path}",
headers={
"OCS-APIRequest": "true",
'accept': 'application/json',
auth=(username, password),
json=data,
print(json.dumps(response.json(), indent=2))
thank You @Sylvain2 .
Your post helped me a lot.
It could figure out how to make this work in OCS API Viewer:
The data field has to be structured like this:
{"314":"2024-05-28","101":"A123", "316":"https://nextcloud.com"}
This is equal to the structure of @Sylvain2 :
Date columnns have to be added with format “yyyy-mm-dd”
You can put simple hyperlinks in to that structure. See column ID 316.
In this case column 316 ist of type “link”.
If You want to have a proper hyperlink with custom title, You would have to nest the keys and values like this:
{"314":"2024-05-28","101":"A123","316":"{"title":"Link","providerId":"url","value":"https:\/\/nextcloud.com","subline":"URL"}"}
This would put a Hyperlink with title “Link” pointing to https://nextcloud.com into the new row for column with id 316.
Great it helped you @wunu
I stopped using Tables for my purpose. The code is definitively too young for production. But still under active development. Follow the git repos.
Advise: perform backup of your database. Plugin update did loose some development data. But you probably do that already, right? ![]()
Note: the JSON code sample you posted contains invalid UTF-8 chars…
