Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): replace me
Operating system and version: Ubuntu Server 22.04.2
PHP version: 8.1.16
After adding new external local storage I cannot upload any file. A message is displayed after each attempt is “Forbidden”.
I gave permissions using commands:
sudo chown -R www-data:www-data /media/hdd_zew
sudo chmod -R 0750 /media/hdd_zew
Whole error log from system I’ve pasted below.
Thanks in advance for your help.
{"reqId":"0jev9m66tH2TWDKegYEE","level":3,"time":"2023-04-24T19:51:06+00:00","remoteAddr":"80.68.231.252","user":"wijako","app":"PHP","method":"PUT","url":"/remote.php/webdav/HDD/rufus-3.22.exe","message":"file_put_contents(/media/hdd_zew/rufus-3.22.exe.ocTransferId1418734440.part): Failed to open stream: Permission denied at /snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Local.php#312","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Error","Message":"file_put_contents(/media/hdd_zew/rufus-3.22.exe.ocTransferId1418734440.part): Failed to open stream: Permission denied at /snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Local.php#312","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Local.php","line":312,"function":"file_put_contents"},{"file":"/snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Local.php","line":621,"function":"file_put_contents","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/lib/private/Files/Storage/Wrapper/Wrapper.php","line":647,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/apps/dav/lib/Connector/Sabre/File.php","line":248,"function":"writeStream","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/remote.php","line":171,"args":["/snap/nextcloud/34372/htdocs/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/snap/nextcloud/34372/htdocs/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"},"id":"6446e5654b9fd"}
{"reqId":"0jev9m66tH2TWDKegYEE","level":3,"time":"2023-04-24T19:51:06+00:00","remoteAddr":"80.68.231.252","user":"wijako","app":"webdav","method":"PUT","url":"/remote.php/webdav/HDD/rufus-3.22.exe","message":"Błąd podczas kopiowania pliku do lokalizacji docelowej (skopiowany: -1 bajt, oczekiwany rozmiar pliku: 1419336 bajtów)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/112.0","version":"25.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception","Message":"Błąd podczas kopiowania pliku do lokalizacji docelowej (skopiowany: -1 bajt, oczekiwany rozmiar pliku: 1419336 bajtów)","Code":0,"Trace":[{"file":"/snap/nextcloud/34372/htdocs/apps/dav/lib/Connector/Sabre/Directory.php","line":151,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/apps/dav/appinfo/v1/webdav.php","line":85,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/snap/nextcloud/34372/htdocs/remote.php","line":171,"args":["/snap/nextcloud/34372/htdocs/apps/dav/appinfo/v1/webdav.php"],"function":"require_once"}],"File":"/snap/nextcloud/34372/htdocs/apps/dav/lib/Connector/Sabre/File.php","Line":279,"message":"Błąd podczas kopiowania pliku do lokalizacji docelowej (skopiowany: -1 bajt, oczekiwany rozmiar pliku: 1419336 bajtów)","exception":[],"CustomMessage":"Błąd podczas kopiowania pliku do lokalizacji docelowej (skopiowany: -1 bajt, oczekiwany rozmiar pliku: 1419336 bajtów)"},"id":"6446e5654b951"}
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
