example
longer
example
here
Nextcloud version (eg, 12.0.2): 18
Operating system and version (eg, Ubuntu 17.04): centos 7.7
Apache or nginx version (eg, Apache 2.4.25): 2.4
PHP version (eg, 7.1): 7.2
When I try to upload file from android app to nextcloud server I get this error
{“reqId”:“Xnmyz62F8xCRDTK2CKgAPwAAAMQ”,“level”:3,“time”:“2020-03-24T07:13:30+00:00”,“remoteAddr”:“192.168.0.27”,“user”:“dennis”,“app”:“no app in context”,“method”:“PUT”,“url”:"/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999",“message”:{“Exception”:“Sabre\DAV\Exception\BadRequest”,“Message”:“Expected filesize of 10240000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.”,“Code”:0,“Trace”:[{“file”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php",“line”:156,“function”:“put”,“class”:“OCA\DAV\Connector\Sabre\File”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php",“line”:47,“function”:“createFile”,“class”:“OCA\DAV\Connector\Sabre\Directory”,“type”:"->",“args”:[“0000000000000000-0000000010239999”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:1096,“function”:“createFile”,“class”:“OCA\DAV\Upload\UploadFolder”,“type”:"->",“args”:[“0000000000000000-0000000010239999”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",“line”:525,“function”:“createFile”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[“uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999”,null,null]},{“function”:“httpPut”,“class”:“Sabre\DAV\CorePlugin”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php",“line”:105,“function”:“call_user_func_array”,“args”:[[{“class”:“Sabre\DAV\CorePlugin”},“httpPut”],[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:479,“function”:“emit”,“class”:“Sabre\Event\EventEmitter”,“type”:"->",“args”:[“method:PUT”,[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:254,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Server.php",“line”:319,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/remote.php",“line”:165,“args”:["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php",“Line”:229,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Android) Nextcloud-android/3.10.1”,“version”:“18.0.0.10”}
{“reqId”:“Xnmyz62F8xCRDTK2CKgAPwAAAMQ”,“level”:4,“time”:“2020-03-24T07:13:30+00:00”,“remoteAddr”:“192.168.0.27”,“user”:“dennis”,“app”:“webdav”,“method”:“PUT”,“url”:"/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999",“message”:{“Exception”:“Sabre\DAV\Exception\BadRequest”,“Message”:“Expected filesize of 10240000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.”,“Code”:0,“Trace”:[{“file”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php",“line”:156,“function”:“put”,“class”:“OCA\DAV\Connector\Sabre\File”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php",“line”:47,“function”:“createFile”,“class”:“OCA\DAV\Connector\Sabre\Directory”,“type”:"->",“args”:[“0000000000000000-0000000010239999”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:1096,“function”:“createFile”,“class”:“OCA\DAV\Upload\UploadFolder”,“type”:"->",“args”:[“0000000000000000-0000000010239999”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",“line”:525,“function”:“createFile”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[“uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999”,null,null]},{“function”:“httpPut”,“class”:“Sabre\DAV\CorePlugin”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php",“line”:105,“function”:“call_user_func_array”,“args”:[[{“class”:“Sabre\DAV\CorePlugin”},“httpPut”],[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:479,“function”:“emit”,“class”:“Sabre\Event\EventEmitter”,“type”:"->",“args”:[“method:PUT”,[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:254,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Server.php",“line”:319,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/remote.php",“line”:165,“args”:["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php",“Line”:229,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Android) Nextcloud-android/3.10.1”,“version”:“18.0.0.10”}
{“reqId”:“XnmzROXH4@1gmTzCJ5dNQwAAAFQ”,“level”:3,“time”:“2020-03-24T07:15:07+00:00”,“remoteAddr”:“192.168.0.27”,“user”:“dennis”,“app”:“no app in context”,“method”:“PUT”,“url”:"/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272",“message”:{“Exception”:“Sabre\DAV\Exception\BadRequest”,“Message”:“Expected filesize of 3125272 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 32768 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.”,“Code”:0,“Trace”:[{“file”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php",“line”:156,“function”:“put”,“class”:“OCA\DAV\Connector\Sabre\File”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php",“line”:47,“function”:“createFile”,“class”:“OCA\DAV\Connector\Sabre\Directory”,“type”:"->",“args”:[“0000000000000000-0000000003125272”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:1096,“function”:“createFile”,“class”:“OCA\DAV\Upload\UploadFolder”,“type”:"->",“args”:[“0000000000000000-0000000003125272”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",“line”:525,“function”:“createFile”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[“uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272”,null,null]},{“function”:“httpPut”,“class”:“Sabre\DAV\CorePlugin”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php",“line”:105,“function”:“call_user_func_array”,“args”:[[{“class”:“Sabre\DAV\CorePlugin”},“httpPut”],[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:479,“function”:“emit”,“class”:“Sabre\Event\EventEmitter”,“type”:"->",“args”:[“method:PUT”,[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:254,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Server.php",“line”:319,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/remote.php",“line”:165,“args”:["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php",“Line”:229,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Android) Nextcloud-android/3.10.1”,“version”:“18.0.0.10”}
{“reqId”:“XnmzROXH4@1gmTzCJ5dNQwAAAFQ”,“level”:4,“time”:“2020-03-24T07:15:07+00:00”,“remoteAddr”:“192.168.0.27”,“user”:“dennis”,“app”:“webdav”,“method”:“PUT”,“url”:"/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272",“message”:{“Exception”:“Sabre\DAV\Exception\BadRequest”,“Message”:“Expected filesize of 3125272 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 32768 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.”,“Code”:0,“Trace”:[{“file”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php",“line”:156,“function”:“put”,“class”:“OCA\DAV\Connector\Sabre\File”,“type”:"->",“args”:[null]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php",“line”:47,“function”:“createFile”,“class”:“OCA\DAV\Connector\Sabre\Directory”,“type”:"->",“args”:[“0000000000000000-0000000003125272”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:1096,“function”:“createFile”,“class”:“OCA\DAV\Upload\UploadFolder”,“type”:"->",“args”:[“0000000000000000-0000000003125272”,null]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",“line”:525,“function”:“createFile”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[“uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272”,null,null]},{“function”:“httpPut”,“class”:“Sabre\DAV\CorePlugin”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php",“line”:105,“function”:“call_user_func_array”,“args”:[[{“class”:“Sabre\DAV\CorePlugin”},“httpPut”],[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:479,“function”:“emit”,“class”:“Sabre\Event\EventEmitter”,“type”:"->",“args”:[“method:PUT”,[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:254,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[{“absoluteUrl”:“https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/var/www/html/nextcloud/apps/dav/lib/Server.php",“line”:319,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/var/www/html/nextcloud/remote.php",“line”:165,“args”:["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php",“Line”:229,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Android) Nextcloud-android/3.10.1”,“version”:“18.0.0.10”}
- upload file from android
{"reqId":"Xnmyz62F8xCRDTK2CKgAPwAAAMQ","level":3,"time":"2020-03-24T07:13:30+00:00","remoteAddr":"192.168.0.27","user":"dennis","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 10240000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":47,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["0000000000000000-0000000010239999",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["0000000000000000-0000000010239999",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":319,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/remote.php","line":165,"args":["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":229,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.10.1","version":"18.0.0.10"}
{"reqId":"Xnmyz62F8xCRDTK2CKgAPwAAAMQ","level":4,"time":"2020-03-24T07:13:30+00:00","remoteAddr":"192.168.0.27","user":"dennis","app":"webdav","method":"PUT","url":"/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 10240000 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 385024 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":47,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["0000000000000000-0000000010239999",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["0000000000000000-0000000010239999",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/04b8023cb3d26350b7cdcd3c008bb7a7/0000000000000000-0000000010239999","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":319,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/remote.php","line":165,"args":["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":229,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.10.1","version":"18.0.0.10"}
{"reqId":"XnmzROXH4@1gmTzCJ5dNQwAAAFQ","level":3,"time":"2020-03-24T07:15:07+00:00","remoteAddr":"192.168.0.27","user":"dennis","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 3125272 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 32768 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":47,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["0000000000000000-0000000003125272",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["0000000000000000-0000000003125272",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":319,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/remote.php","line":165,"args":["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":229,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.10.1","version":"18.0.0.10"}
{"reqId":"XnmzROXH4@1gmTzCJ5dNQwAAAFQ","level":4,"time":"2020-03-24T07:15:07+00:00","remoteAddr":"192.168.0.27","user":"dennis","app":"webdav","method":"PUT","url":"/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","message":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 3125272 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 32768 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":156,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":[null]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Upload/UploadFolder.php","line":47,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["0000000000000000-0000000003125272",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1096,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["0000000000000000-0000000003125272",null]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":525,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272",null,null]},{"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php","line":105,"function":"call_user_func_array","args":[[{"__class__":"Sabre\\DAV\\CorePlugin"},"httpPut"],[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":479,"function":"emit","class":"Sabre\\Event\\EventEmitter","type":"->","args":["method:PUT",[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":254,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"absoluteUrl":"https://nextcloud.myweb.com/remote.php/dav/uploads/dennis/2f9259d80da84638f86bbc03c1e300bf/0000000000000000-0000000003125272","__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":319,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/nextcloud/remote.php","line":165,"args":["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php","Line":229,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.10.1","version":"18.0.0.10"}
PASTE HERE
PASTE HERE
