example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.0.4*
Operating system and version (eg, Ubuntu 17.04): * CENTOS 7.6 virtuozzo [vps] * [ v78.0.11 ]
Apache or nginx version (eg, Apache 2.4.25): EasyApache 4.0, Apache/2.4.38, Nginx Version: 1.9.14
PHP version (eg, 7.1): 7.2.15
When I try to upload a file larger than 8-10MB browser displays “Processing files …” and remains on that forever.
When I try the desktop app to sync with server I get error: Server replied “405 Method Not Allowed” to “MOVE https://domain.com/index.php/apps/files” (… filename
If I use WebDav on my mac using finder I end up with files that are 0bytes.
- Upload any file larger than 10MB (I am trying a 20MB file)
- Same using desktop app sync
- And ditto Webdav
There is nothing in the logs except my earlier failed login attempts while testing
'instanceid' => 'ocsadxkubslk',
'passwordsalt' => '2pu08nmeeodjm8dtxkjdq9awfcurh5',
'secret' => 'ebn086v5gypafsmgslowphs8lcri9cxazl0uvxen8gk07cfo',
0 => 'behavior-intelligence.com',
'datadirectory' => '/home/kanboard/biclouddata',
'version' => '15.0.4.0',
'overwrite.cli.url' => 'https://behavior-intelligence.com/bicloud',
'dbname' => 'kanboard_next750',
'dbhost' => 'localhost',
'dbuser' => 'myusername',
'dbpassword' => 'apassword',
I am not seeing anything in the logs.
