Problem to update Nextcloud 20.x (poll module do errors)
I had a notice that some applications are ready to update. So I go in GUI interface and select all the module, and update them.
But the site go itself in maintenance mode. So I try to understand more with CLI.
Here are the two commands I entered:
$ php occ maintenance:mode --on
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
Maintenance mode already enabled
$ php occ upgrade
Setting log level to debug
Updating database schema
Updated database
Updating <polls> ...
ArgumentCountError: Too few arguments to function OCA\Polls\Migration\FixVotes::__construct(), 0 passed in /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Repair.php on line 129 and exactly 4 expected in /home/clients/blablabla/sites/cloud.mydomain.fr/apps/polls/lib/Migration/FixVotes.php:50
Stack trace:
#0 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Repair.php(129): OCA\Polls\Migration\FixVotes->__construct()
#1 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/legacy/OC_App.php(1043): OC\Repair->addStep('OCA\\Polls\\Migra...')
#2 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/legacy/OC_App.php(978): OC_App::executeRepairSteps('polls', Array)
#3 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Updater.php(379): OC_App::updateApp('polls')
#4 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Updater.php(258): OC\Updater->doAppUpgrade()
#5 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Updater.php(130): OC\Updater->doUpgrade('20.0.11.1', '20.0.11.1')
#6 /home/clients/blablabla/sites/cloud.mydomain.fr/core/Command/Upgrade.php(255): OC\Updater->upgrade()
#7 /home/clients/blablabla/sites/cloud.mydomain.fr/3rdparty/symfony/console/Command/Command.php(255): OC\Core\Command\Upgrade->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#8 /home/clients/blablabla/sites/cloud.mydomain.fr/3rdparty/symfony/console/Application.php(1000): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#9 /home/clients/blablabla/sites/cloud.mydomain.fr/3rdparty/symfony/console/Application.php(271): Symfony\Component\Console\Application->doRunCommand(Object(OC\Core\Command\Upgrade), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#10 /home/clients/blablabla/sites/cloud.mydomain.fr/3rdparty/symfony/console/Application.php(147): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#11 /home/clients/blablabla/sites/cloud.mydomain.fr/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /home/clients/blablabla/sites/cloud.mydomain.fr/console.php(100): OC\Console\Application->run()
#13 /home/clients/blablabla/sites/cloud.mydomain.fr/occ(11): require_once('/home/clients/8...')
What can I do now to have my Nextcloud back?
Thanks
php occ app:disable polls
php occ maintenance:mode --off
Thank you Jimmy. Perfect.
