Problem to connect external resources in nextcloud SMB / CIFS
I have a problem to connect external resources in nextcloud.
Nextcloud 13 and Ubuntu server 17.10.
From Nextcloud, I do not connect to resources via smb.
From the command line it connects to smb without any problem.
You can see both of them in the picture.
Do you know what a problem can be?
I had a similar problem and have filled in the domain name field the ubuntu computer name. After that it worked.
Super, it helped.
Thank you
Hi, this may help for connecting a SMB shared folder on a Synology NAS in an Ipv4 SOHO network :
For example : for the ā€œdocā€ DSM shared folder
  • NAS IPv4 192.168.1.10
  • Domain MYWORKGROUP : Samba/SMB is enabled by default on Synology NAS.
    Log into the diskstation manager and go to ā€œFile Sharing SMB/AFP/NFSā€ there you should see ā€œEnable Windows File Serviceā€ and if its ticked then SMB is enabled. Then file the workgroup name.
konki
