Problem: Office window is shifted downwards
Hello all,
For a long time I have the problem that the Office window is always displayed shifted downwards (Collabora CODE Server). Whether it is my own CODE server or the build-in CODE does not matter. The problem occurs with all three applications.
The problem is that the buttons at the bottom of the Office window are no longer visible. For example, in a spreadsheet I can’t switch between worksheets because I don’t see the buttons for them.
Reinstalling/deleting the addins did nothing.
Does anyone have a tip for this?
Somehow I haven’t found anything about this problem…
best regards
Otto
I have been able to eliminate the problem. It only occurs when the addin “CADViewer” is installed and active. After uninstalling “CADViewer” the CODE window is displayed correctly again.
regards
Otto
