1 - On Iphone, Ipad, We should automatically log in at the end of the registration of “nextcloud talk” with the app “registration” (GitHub - nextcloud/registration: User registration app for Nextcloud) installed on the server (via regular apps install).
2 - on iphone / ipad, The registration process stay blocked at the “loading” page (end of the registration). We have to kill the “nextcloud Talk” app and load again (then, it can take 1-2 min before the log menu appear ! )
The team of the registration app (Closed issue #297) tell me that it doesn’t come from their application.
The registration process work via firefox on iphone ! it is really a problem with the “nextcloud talk” iphone / ipad app.
It limits the capability to invite peoples and to create a community.
Do you have an idea of the reason of this bug ?
3 - Nextcloud 20.0.8; MySQL version “5.7.33”; behind a NAT livebox (port 443 + 80 open); installed with snap on ubuntu 20. + Turn server working (I tryed with and without the Turn server)
Does it come form the snap configuration (old Mysql version)?
Here are the logs I found:
Warning:
{“reqId”:“VCWB373BAQ3z8RTKeMmq”,“level”:2,“time”:“2021-04-14T19:43:16+00:00”,“remoteAddr”:“86.229.57.136”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/index.php/csrftoken",“message”:“Renewing session token failed”,“userAgent”:“iPhone (Nextcloud Talk)”,“version”:“20.0.8.1”,“id”:“607b0d2140283”}
Fatal:
{“reqId”:“XsUt3h43ezrz5GhUYanu”,“level”:4,“time”:“2021-04-12T18:00:56+00:00”,“remoteAddr”:“86.229.57.100”,“user”:“herve”,“app”:“webdav”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/herve/",“message”:{“Exception”:“Sabre\DAV\Exception\ServiceUnavailable”,“Message”:“Système en mode maintenance.”,“Code”:0,“Trace”:[{“file”:"/snap/nextcloud/27089/htdocs/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",“line”:89,“function”:“checkMaintenanceMode”,“class”:“OCA\DAV\Connector\Sabre\MaintenancePlugin”,“type”:"->",“args”:[{“class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/snap/nextcloud/27089/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:458,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[“beforeMethod:PROPFIND”,[{“class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]]},{“file”:"/snap/nextcloud/27089/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:251,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[{“class”:“Sabre\HTTP\Request”},{“class”:“Sabre\HTTP\Response”}]},{“file”:"/snap/nextcloud/27089/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:319,“function”:“start”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/snap/nextcloud/27089/htdocs/apps/dav/lib/Server.php",“line”:332,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/snap/nextcloud/27089/htdocs/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:"->",“args”:[]},{“file”:"/snap/nextcloud/27089/htdocs/remote.php",“line”:167,“args”:["/snap/nextcloud/27089/htdocs/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/snap/nextcloud/27089/htdocs/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php",“Line”:85,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Macintosh) mirall/3.1.3git (build 4850) (Nextcloud)”,“version”:“20.0.8.1”,“id”:“607b0d21402e2”}
Error:
{“reqId”:“SfuOcj7813COM7vzAjRT”,“level”:3,“time”:“2021-04-11T15:46:50+00:00”,“remoteAddr”:“86.229.57.100”,“user”:“Celine”,“app”:“index”,“method”:“GET”,“url”:"/index.php/login/v2/grant",“message”:{“Exception”:“Exception”,“Message”:“Argument 1 passed to OC\Core\Controller\ClientFlowLoginV2Controller::grantPage() must be of the type string, null given, called in /snap/nextcloud/27089/htdocs/lib/private/AppFramework/Http/Dispatcher.php on line 169”,“Code”:0,“Trace”:[{“file”:"/snap/nextcloud/27089/htdocs/lib/private/AppFramework/App.php",“line”:152,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”},“grantPage”]},{“file”:"/snap/nextcloud/27089/htdocs/lib/private/Route/Router.php",“line”:309,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“OC\Core\Controller\ClientFlowLoginV2Controller”,“grantPage”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{"_route":“core.ClientFlowLoginV2.grantPage”}]},{“file”:"/snap/nextcloud/27089/htdocs/lib/base.php",“line”:1008,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/login/v2/grant"]},{“file”:"/snap/nextcloud/27089/htdocs/index.php",“line”:37,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/snap/nextcloud/27089/htdocs/lib/private/AppFramework/Http/Dispatcher.php",“Line”:110,“Previous”:{“Exception”:“TypeError”,“Message”:“Argument 1 passed to OC\Core\Controller\ClientFlowLoginV2Controller::grantPage() must be of the type string, null given, called in /snap/nextcloud/27089/htdocs/lib/private/AppFramework/Http/Dispatcher.php on line 169”,“Code”:0,“Trace”:[{“file”:"/snap/nextcloud/27089/htdocs/lib/private/AppFramework/Http/Dispatcher.php",“line”:169,“function”:“grantPage”,“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”,“type”:"->",“args”:[null]},{“file”:"/snap/nextcloud/27089/htdocs/lib/private/AppFramework/Http/Dispatcher.php",“line”:100,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”},“grantPage”]},{“file”:"/snap/nextcloud/27089/htdocs/lib/private/AppFramework/App.php",“line”:152,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\ClientFlowLoginV2Controller”},“grantPage”]},{“file”:"/snap/nextcloud/27089/htdocs/lib/private/Route/Router.php",“line”:309,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“OC\Core\Controller\ClientFlowLoginV2Controller”,“grantPage”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{"_route":“core.ClientFlowLoginV2.grantPage”}]},{“file”:"/snap/nextcloud/27089/htdocs/lib/base.php",“line”:1008,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/login/v2/grant"]},{“file”:"/snap/nextcloud/27089/htdocs/index.php",“line”:37,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/snap/nextcloud/27089/htdocs/core/Controller/ClientFlowLoginV2Controller.php",“Line”:153},“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:87.0) Gecko/20100101 Firefox/87.0”,“version”:“20.0.8.1”,“id”:“607b0d21408c0”}
