Problem macOS 27.0.1 – "Keep Always Offline" fails on top-level folders, but works on subfolders (Nextcloud Desktop 34.0.5)
Environment:
  • macOS: 27.0.1
  • Nextcloud Desktop Client: 34.0.5
  • Nextcloud Server: Self-hosted
  • Two separate Nextcloud accounts
  • File Provider integration enabled
Problem:
I am experiencing an issue with the “Keep Always Offline” feature in Finder on macOS.
I have two separate self-hosted Nextcloud accounts configured in the Nextcloud Desktop Client.
When I try to enable “Keep Always Offline” on the top-level folder of either account, macOS displays the following error:
Couldn’t communicate with a helper application.
Try your operation again. If that fails, quit and relaunch the application and try again.
Steps to reproduce:
  1. Open Finder on macOS.
  2. Navigate to a Nextcloud account using the File Provider integration.
  3. Right-click the top-level folder (e.g., first company or second company).
  4. Select “Keep Always Offline”.
  5. The error message appears.
  6. Navigate into the same folder.
  7. Right-click any subfolder and select “Keep Always Offline”.
  8. The operation works correctly.
Expected behavior:
Selecting “Keep Always Offline” on the top-level folder should recursively download all files and subfolders and keep them available offline.
Actual behavior:
The operation fails on the top-level folder with the helper application error.
However, selecting “Keep Always Offline” on individual subfolders works correctly.
Additional information:
  • The issue occurs with both Nextcloud accounts.
  • Both accounts are connected to different self-hosted Nextcloud servers.
  • The issue appears to be specific to top-level folders.
  • Subfolders can be marked as permanently available offline without problems.
  • This may be related to the macOS File Provider integration.
Question:
Is this a known limitation or bug in the Nextcloud Desktop Client’s macOS File Provider integration?
Is there a workaround to mark the entire top-level folder as permanently available offline without manually selecting every subfolder?
Thank you for your help!
Hi! This is not a known issue yet. The error message itself indicates that there is not something wrong with the feature but apparently the communication (“XPC”, interprocess communication) between the file provider extension (the integration into macOS and Finder) and our main app in general. This hints an issue specific to the local environment. I cannot reproduce the issue and “Always keep available offline” even on the root (Finder sidebar item “Nextcloud”) itself. :thinking:
  1. Did you restart your Mac?
  2. Do you have multiple Nextcloud client bundles laying around on your file system (macOS might mix them up and use the wrong extension with a mismatching app)?
  3. What does the Terminal command pluginkit -mvvvi com.nextcloud.desktopclient.FileProviderExt print?
Thank you for your response!
I have checked all three points you mentioned:
  1. Restarting my Mac:
    Yes, I have already restarted my Mac, but unfortunately the issue still persists.
  2. Multiple Nextcloud installations:
    I checked my applications and could only find one Nextcloud installation. I have attached a screenshot showing this.
  3. Terminal command:
    I executed the command:
    Here is the output:
    com.nextcloud.desktopclient.FileProviderExt(34.0.5)
        Path = /Applications/Nextcloud.app/Contents/PlugIns/FileProviderExt.appex
        UUID = 2E0436DA-51C7-4A6C-8531-2F0B9CDC5577
        Timestamp = 2026-10-07 10:24:38 +0000
        SDK = com.apple.fileprovider-nonui
        Parent Bundle = /Applications/Nextcloud.app
        Display Name = Nextcloud File Provider
        Short Name = Nextcloud File Provider
        Parent Name = Nextcloud
        Platform = macOS
    (1 plug-in)
I have also attached screenshots of the Terminal output and my Nextcloud installation.
As far as I can tell, macOS recognizes the Nextcloud File Provider extension correctly, and there does not appear to be a duplicate installation.
However, the problem with “Always Keep Available Offline” still persists.
Do you have any suggestions on what I could try next?
Could this be related to the communication between the File Provider extension and the main Nextcloud application, even though the extension appears to be registered correctly?
Thank you very much for your help!
  1. The output looks fine and as I hoped it to be.
  2. Was this a fresh installation and configuration or did you update your client only recently from a previous version and had the accounts already setup?
  3. You could also try to reset the file provider domain in the app settings. This is equal to a graceful remove (unsynched data will be preserved locally) and creation from scratch. If you have a previous history with this deployment, it might be that your client or macOS state is not correct.
This was not a completely fresh installation.
I originally had an older version of the Nextcloud desktop client installed on my Mac. I then updated the client to the newer version and configured two different Nextcloud server accounts.
The important thing is that the “Always Keep Available Offline” error occurs with both Nextcloud server accounts, not just one.
Both accounts are connected to the same Nextcloud desktop client.
Since the issue affects both accounts, I suspect it might be related to the macOS File Provider integration or some remaining configuration from the previous Nextcloud version.
Regarding your suggestion to reset the File Provider domain, I would be willing to try this.
However, before proceeding, I would like to clarify a few things:
  1. Is it safe to reset the File Provider domain when two Nextcloud accounts are connected?
  2. Will my existing files and account configurations be preserved?
  3. Will I need to download all my files again after the reset?
  4. Could you please provide the recommended steps to perform the reset safely?
I am sorry for the late response and I will be irresponsive for a few more days.
This depends on whether your changes are fully synchronized between client and server. If so, then yes. Reset happens per file provider domain.
  1. Will my existing files and account configurations be preserved?
The account configurations on your device remain. A file provider domain reset implicates a wipe of the local state, though. It does not affect what is on the server!
  1. Will I need to download all my files again after the reset?
If you have downloaded files or marked them to be kept available offline, you unfortunately need to repeat that step. This is the trade-off for this procedure. Resetting a file provider domain is like setting up a sync folder from scratch.
I hope this is enough information for now to decide whether you actually want to go that way.
I have already followed all the recommended troubleshooting steps, but unfortunately, the issue still persists.
Whenever I try to make my entire Nextcloud account available offline on my Mac, I receive the following error message:
“Couldn’t communicate with a helper application.”
This error occurs when I attempt to download and store all files and folders from my Nextcloud account locally on my Mac so that they are accessible without an internet connection.
I have tried several times, but the problem remains unresolved.
I have attached a screenshot of the error message for your reference.
Could you please investigate what is causing this issue and provide a permanent solution?
My goal is to have all files and folders from my entire Nextcloud account fully downloaded and available locally on my Mac, even without an internet connection.
I would appreciate a solution that addresses the root cause of this issue, as I have already tried the previously recommended steps without success.
Thank you in advance for your assistance.
Best regards,
Then why not simply use traditional sync instead of the File Provider (Virtual Files)?
