Hello
I installed nextcloud on a server all is well
but in the mobil application ans computer application I have the domain name next to login
how to leave that the email address
My domain nextcloud.abc.fr
login login@abcdef.com
in applciaition I have login@abcdef.com@nextcloud.abc.fr
I’m sorry if I misunderstand your question:
As far as Nextcloud is concerned login@abd.com
is your username so it should display as login@abd.com@nextcloud.abc.com
Are you using the IMAP authentication backend to login using your email address? If so you can hide the @abd.com
Thanks,
but it’s not for IMAP but I use local accounts and OpenLdap
for example
my website http: /nextcloud.aaaaaaaaa.fr
my login login@bbbbbbbbbbb.com
but on the app shows me login @ bbbbbbbbbbb.com @ nextcloud.aaaaaaaaa.fr
