Hello, I’m facing a strange problem that I can’t seem to find the source of the problem. I’m running nextcloud in FreeNAS, on a FreeBSD Jail. I have
Apache
Server version: Apache/2.4.29 (FreeBSD)
Server built: unknown
PHP
PHP Warning:  Module 'session' already loaded in Unknown on line 0
PHP Warning:  Module 'redis' already loaded in Unknown on line 0
PHP 7.1.11 (cli) (built: Oct 28 2017 01:16:36) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.1.0, Copyright (c) 1998-2017 Zend Technologies
   with Zend OPcache v7.1.11, Copyright (c) 1999-2017, by Zend Technologies
Out of nower I started getting the system very slow, and lost connection, this was the output from:
sockstat -4 -l
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS
www httpd 15120 5 tcp4 *:80 *:*
www httpd 15120 7 tcp4 *:443 *:*
www httpd 14998 5 tcp4 *:80 *:*
www httpd 14998 7 tcp4 *:443 *:*
www httpd 14770 5 tcp4 *:80 *:*
www httpd 14770 7 tcp4 *:443 *:*
www httpd 14769 5 tcp4 *:80 *:*
www httpd 14769 7 tcp4 *:443 *:*
www httpd 14768 5 tcp4 *:80 *:*
www httpd 14768 7 tcp4 *:443 *:*
www httpd 14661 5 tcp4 *:80 *:*
www httpd 14661 7 tcp4 *:443 *:*
www httpd 14660 5 tcp4 *:80 *:*
www httpd 14660 7 tcp4 *:443 *:*
www httpd 14659 5 tcp4 *:80 *:*
www httpd 14659 7 tcp4 *:443 *:*
www httpd 14658 5 tcp4 *:80 *:*
www httpd 14658 7 tcp4 *:443 *:*
www httpd 14656 5 tcp4 *:80 *:*
www httpd 14656 7 tcp4 *:443 *:*
www httpd 14655 5 tcp4 *:80 *:*
www httpd 14655 7 tcp4 *:443 *:*
www httpd 14654 5 tcp4 *:80 *:*
www httpd 14654 7 tcp4 *:443 *:*
www httpd 14653 5 tcp4 *:80 *:*
www httpd 14653 7 tcp4 *:443 *:*
www httpd 14652 5 tcp4 *:80 *:*
www httpd 14652 7 tcp4 *:443 *:*
www httpd 14651 5 tcp4 *:80 *:*
www httpd 14651 7 tcp4 *:443 *:*
www httpd 14650 5 tcp4 *:80 *:*
www httpd 14650 7 tcp4 *:443 *:*
www httpd 14648 5 tcp4 *:80 *:*
www httpd 14648 7 tcp4 *:443 *:*
www httpd 14647 5 tcp4 *:80 *:*
www httpd 14647 7 tcp4 *:443 *:*
www httpd 14646 5 tcp4 *:80 *:*
www httpd 14646 7 tcp4 *:443 *:*
www httpd 14643 5 tcp4 *:80 *:*
www httpd 14643 7 tcp4 *:443 *:*
www httpd 14642 5 tcp4 *:80 *:*
www httpd 14642 7 tcp4 *:443 *:*
www httpd 14641 5 tcp4 *:80 *:*
www httpd 14641 7 tcp4 *:443 *:*
www httpd 14640 5 tcp4 *:80 *:*
www httpd 14640 7 tcp4 *:443 *:*
www httpd 14639 5 tcp4 *:80 *:*
www httpd 14639 7 tcp4 *:443 *:*
www httpd 14638 5 tcp4 *:80 *:*
www httpd 14638 7 tcp4 *:443 *:*
www httpd 14629 5 tcp4 *:80 *:*
www httpd 14629 7 tcp4 *:443 *:*
www httpd 14600 5 tcp4 *:80 *:*
www httpd 14600 7 tcp4 *:443 *:*
www httpd 14599 5 tcp4 *:80 *:*
www httpd 14599 7 tcp4 *:443 *:*
www httpd 14598 5 tcp4 *:80 *:*
www httpd 14598 7 tcp4 *:443 *:*
www httpd 14597 5 tcp4 *:80 *:*
www httpd 14597 7 tcp4 *:443 *:*
www httpd 14595 5 tcp4 *:80 *:*
www httpd 14595 7 tcp4 *:443 *:*
www httpd 14594 5 tcp4 *:80 *:*
www httpd 14594 7 tcp4 *:443 *:*
www httpd 14585 5 tcp4 *:80 *:*
www httpd 14585 7 tcp4 *:443 *:*
www httpd 14558 5 tcp4 *:80 *:*
www httpd 14558 7 tcp4 *:443 *:*
www httpd 14557 5 tcp4 *:80 *:*
www httpd 14557 7 tcp4 *:443 *:*
www httpd 14556 5 tcp4 *:80 *:*
www httpd 14556 7 tcp4 *:443 *:*
www httpd 14555 5 tcp4 *:80 *:*
www httpd 14555 7 tcp4 *:443 *:*
www httpd 14554 5 tcp4 *:80 *:*
www httpd 14554 7 tcp4 *:443 *:*
www httpd 14553 5 tcp4 *:80 *:*
www httpd 14553 7 tcp4 *:443 *:*
www httpd 14552 5 tcp4 *:80 *:*
www httpd 14552 7 tcp4 *:443 *:*
www httpd 14550 5 tcp4 *:80 *:*
www httpd 14550 7 tcp4 *:443 *:*
www httpd 14549 5 tcp4 *:80 *:*
www httpd 14549 7 tcp4 *:443 *:*
www httpd 14548 5 tcp4 *:80 *:*
www httpd 14548 7 tcp4 *:443 *:*
www httpd 14547 5 tcp4 *:80 *:*
www httpd 14547 7 tcp4 *:443 *:*
www httpd 14546 5 tcp4 *:80 *:*
www httpd 14546 7 tcp4 *:443 *:*
www httpd 14545 5 tcp4 *:80 *:*
www httpd 14545 7 tcp4 *:443 *:*
www httpd 14544 5 tcp4 *:80 *:*
www httpd 14544 7 tcp4 *:443 *:*
www httpd 14542 5 tcp4 *:80 *:*
www httpd 14542 7 tcp4 *:443 *:*
www httpd 14540 5 tcp4 *:80 *:*
www httpd 14540 7 tcp4 *:443 *:*
www httpd 14539 5 tcp4 *:80 *:*
www httpd 14539 7 tcp4 *:443 *:*
www httpd 14538 5 tcp4 *:80 *:*
www httpd 14538 7 tcp4 *:443 *:*
www httpd 14537 5 tcp4 *:80 *:*
www httpd 14537 7 tcp4 *:443 *:*
www httpd 14536 5 tcp4 *:80 *:*
www httpd 14536 7 tcp4 *:443 *:*
root httpd 14360 5 tcp4 *:80 *:*
root httpd 14360 7 tcp4 *:443 *:*
mysql mysqld 47892 111 tcp46 *:3306 *:*
root syslogd 46667 7 udp4 *:514 *:*
top
last pid: 16045; load averages: 0.21, 0.50, 0.57 up 0+06:52:23 08:30:21
80 processes: 1 running, 79 sleeping
CPU: 1.5% user, 0.0% nice, 7.7% system, 0.0% interrupt, 90.8% idle
Mem: 2584M Active, 1760M Inact, 9297M Wired, 951M Free
ARC: 6623M Total, 1569M MFU, 4618M MRU, 16M Anon, 89M Header, 331M Other
Swap: 4096M Total, 26M Used, 4070M Free
PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND
14544 www 1 20 0 617M 50532K vlruwk 3 0:00 0.10% httpd
15957 root 1 20 0 20120K 2564K CPU3 3 0:00 0.04% top
46958 redis 3 20 0 26368K 8752K kqread 0 0:08 0.04% redis-server
14599 www 1 20 0 621M 56948K vlruwk 6 0:00 0.04% httpd
65448 smmsp 1 20 0 26732K 12104K vlruwk 0 0:06 0.03% sendmail
14595 www 1 20 0 615M 44816K select 0 0:00 0.03% httpd
14540 www 1 20 0 621M 56364K vlruwk 6 0:00 0.02% httpd
14554 www 1 20 0 615M 44816K select 0 0:00 0.02% httpd
14550 www 1 20 0 615M 44828K select 4 0:00 0.02% httpd
14552 www 1 20 0 615M 44816K select 6 0:00 0.02% httpd
47892 mysql 37 20 0 556M 153M select 4 0:27 0.02% mysqld
14598 www 1 20 0 617M 50548K vlruwk 6 0:00 0.01% httpd
14546 www 1 20 0 615M 44816K select 3 0:00 0.01% httpd
65449 root 1 20 0 8292K 1448K piperd 0 0:00 0.01% tee
15883 www 1 20 0 615M 44816K select 4 0:00 0.01% httpd
14594 www 1 20 0 615M 44816K select 3 0:00 0.01% httpd
15999 root 1 20 0 320K 216K vlruwk 3 0:00 0.01% atrun
16041 www 1 20 0 452K 336K vlruwk 5 0:00 0.01% sh
14653 www 1 20 0 617M 50280K vlruwk 4 0:00 0.01% httpd
14661 www 1 20 0 619M 52616K vlruwk 0 0:00 0.01% httpd
14557 www 1 20 0 615M 44816K select 3 0:00 0.01% httpd
14360 root 1 20 0 615M 44712K select 7 0:00 0.00% httpd
14558 www 1 20 0 615M 44816K lockf 0 0:00 0.00% httpd
65450 root 1 20 0 14796K 1860K piperd 6 0:00 0.00% egrep
14556 www 1 20 0 619M 56180K lockf 7 0:00 0.00% httpd
14549 www 1 20 0 615M 44828K lockf 5 0:00 0.00% httpd
15998 root 1 20 0 12564K 1828K piperd 0 0:00 0.00% cron
14647 www 1 20 0 619M 56256K lockf 1 0:00 0.00% httpd
14555 www 1 20 0 615M 44816K kqread 3 0:00 0.00% httpd
14537 www 1 20 0 621M 60144K lockf 4 0:00 0.00% httpd
14652 www 1 20 0 621M 58756K select 6 0:00 0.00% httpd
14658 www 1 20 0 619M 56252K select 6 0:00 0.00% httpd
48849 root 1 20 0 12564K 1736K nanslp 0 0:00 0.00% cron
46667 root 1 20 0 10464K 1600K select 1 0:00 0.00% syslogd
13557 root 1 20 0 19676K 3132K pause 3 0:00 0.00% csh
65451 root 1 20 0 12592K 1656K piperd 7 0:00 0.00% wc
14538 www 1 20 0 615M 44828K select 7 0:00 0.00% httpd
14539 www 1 20 0 615M 44828K select 6 0:00 0.00% httpd
14768 www 1 20 0 615M 44828K lockf 5 0:00 0.00% httpd
14770 www 1 20 0 615M 44816K select 1 0:00 0.00% httpd
14545 www 1 20 0 615M 44816K select 3 0:00 0.00% httpd
14597 www 1 20 0 615M 44816K select 0 0:00 0.00% httpd
14536 www 1 20 0 615M 44816K select 0 0:00 0.00% httpd
14646 www 1 20 0 615M 44816K select 3 0:00 0.00% httpd
14643 www 1 20 0 615M 44816K select 7 0:00 0.00% httpd
14638 www 1 20 0 615M 44816K select 1 0:00 0.00% httpd
14542 www 1 20 0 615M 44816K select 0 0:00 0.00% httpd
ps -aux
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 14360 0.0 0.3 629336 44712 - SsJ 08:18 0:00.27 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14536 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14537 0.0 0.4 635608 60144 - SJ 08:20 0:00.38 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14538 0.0 0.3 629336 44828 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14539 0.0 0.3 629336 44828 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14540 0.0 0.4 633560 58824 - SJ 08:20 0:00.21 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14542 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14544 0.0 0.3 633560 55384 - DJ 08:20 0:00.07 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14545 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14546 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14547 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14548 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14549 0.0 0.3 629336 44828 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14550 0.0 0.3 629336 44828 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14552 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14553 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14554 0.0 0.3 631512 50484 - DJ 08:20 0:00.04 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14555 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14556 0.0 0.3 633560 56180 - SJ 08:20 0:00.09 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14557 0.0 0.3 629336 44816 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14558 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14585 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14594 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14595 0.0 0.3 629336 44816 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14597 0.0 0.3 629336 44816 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14598 0.0 0.3 633560 55772 - DJ 08:20 0:00.07 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14599 0.0 0.3 633560 56132 - SJ 08:20 0:00.09 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14600 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14629 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14638 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14639 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14640 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14641 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14642 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14643 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14646 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14647 0.0 0.3 633560 56256 - SJ 08:20 0:00.10 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14648 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14650 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14651 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14652 0.0 0.4 635608 58756 - SJ 08:20 0:00.28 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14653 0.0 0.3 633560 54492 - DJ 08:20 0:00.07 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14654 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14655 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14656 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14658 0.0 0.3 633560 56252 - SJ 08:20 0:00.08 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14659 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14660 0.0 0.3 629336 44816 - SJ 08:20 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14661 0.0 0.4 633560 58580 - SJ 08:20 0:00.12 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14768 0.0 0.3 629336 44828 - SJ 08:20 0:00.02 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14769 0.0 0.3 629336 44816 - SJ 08:21 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14770 0.0 0.3 629336 44816 - SJ 08:21 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 14998 0.0 0.3 629336 44816 - SJ 08:22 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 15120 0.0 0.3 629336 44816 - SJ 08:24 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 15883 0.0 0.3 629336 44816 - SJ 08:28 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 15906 0.0 0.3 629336 44816 - SJ 08:29 0:00.01 /usr/local/sbin/httpd -DNOHTTPACCEPT
www 15908 0.0 0.3 629336 44816 - SJ 08:29 0:00.00 /usr/local/sbin/httpd -DNOHTTPACCEPT
root 15998 0.0 0.0 14612 1840 - IJ 08:30 0:00.00 cron: running job (cron)
www 16041 0.0 0.3 565800 44256 - DsJ 08:30 0:00.17 /usr/local/bin/php -f /usr/local/www/apache24/data/nextcloud/cron.php
smmsp 16092 0.0 0.0 20604 4896 - IsJ 08:31 0:00.01 /usr/sbin/sendmail -FCronDaemon -odi -oem -oi -t
root 46667 0.0 0.0 10464 1600 - IsJ 01:59 0:00.03 /usr/sbin/syslogd -s
redis 46958 0.0 0.1 26368 8752 - SsJ 01:59 0:08.30 redis-server: /usr/local/bin/redis-server 127.0.0.1:0 (redis-server)
mysql 46968 0.0 0.0 13144 1796 - IsJ 01:59 0:00.01 /bin/sh /usr/local/bin/mysqld_safe --defaults-extra-file=/var/db/mysql/my.cnf --user=mysql --datadir=/var/db/mysql --pid-file=/var
mysql 47892 0.0 0.9 568888 156892 - IJ 01:59 0:26.77 /usr/local/libexec/mysqld --defaults-extra-file=/var/db/mysql/my.cnf --basedir=/usr/local --datadir=/var/db/mysql --plugin-dir=/us
root 48849 0.0 0.0 12564 1736 - SsJ 01:59 0:00.06 /usr/sbin/cron -s
root 64845 0.0 0.0 12564 1780 - IJ 03:01 0:00.00 cron: running job (cron)
root 64847 0.0 0.0 13144 1836 - IsJ 03:01 0:00.00 /bin/sh - /usr/sbin/periodic daily
root 64954 0.0 0.0 6244 1380 - IJ 03:01 0:00.00 lockf -t 0 /var/run/periodic.daily.lock /bin/sh /usr/sbin/periodic LOCKED daily
root 64965 0.0 0.0 13144 1836 - IJ 03:01 0:00.00 /bin/sh /usr/sbin/periodic LOCKED daily
root 65022 0.0 0.0 13144 1844 - IJ 03:01 0:00.00 /bin/sh /usr/sbin/periodic LOCKED daily
root 65023 0.0 0.0 8392 1552 - IJ 03:01 0:00.00 mail -E -s nextcloud_1 daily run output root
root 65439 0.0 0.0 13144 1868 - IJ 03:01 0:00.00 /bin/sh /etc/periodic/daily/440.status-mailq
root 65447 0.0 0.0 13144 1868 - IJ 03:01 0:00.00 /bin/sh /etc/periodic/daily/440.status-mailq
smmsp 65448 0.0 0.1 26732 12104 - DJ 03:01 0:05.54 mailq -Ac (sendmail)
root 65449 0.0 0.0 8292 1448 - SJ 03:01 0:00.49 tee /dev/stderr
root 65450 0.0 0.0 14796 1860 - SJ 03:01 0:00.16 egrep -v (mqueue is empty|Total requests)
root 65451 0.0 0.0 12592 1656 - SJ 03:01 0:00.03 wc -l
root 13557 0.0 0.0 19676 3132 0 SJ 08:10 0:00.03 /bin/csh -i
root 16154 0.0 0.0 21244 2120 0 R+J 08:31 0:00.00 ps -aux
root@nextcloud_1:/ # service apache24 stop
Stopping apache24.
Waiting for PIDS: 14360.
root@nextcloud_1:/ # clear
root@nextcloud_1:/ # ps -aux
www 16041 0.0 0.3 565864 48888 - DsJ 08:30 0:00.28 /usr/local/bin/php -f /usr/local/www/apache24/data/nextcloud/cron.php
root 16612 0.0 0.0 12564 1780 - DJ 08:35 0:00.00 cron: running job (cron)
root 16613 0.0 0.0 12564 1780 - DVsJ 08:35 0:00.00 cron: running job (cron)
root 46667 0.0 0.0 10464 1600 - SsJ 01:59 0:00.03 /usr/sbin/syslogd -s
redis 46958 0.0 0.1 26368 8752 - SsJ 01:59 0:08.35 redis-server: /usr/local/bin/redis-server 127.0.0.1:0 (redis-server)
mysql 47892 0.0 0.9 568888 156948 - IJ 01:59 0:26.83 /usr/local/libexec/mysqld --defaults-extra-file=/var/db/mysql/my.cnf --basedir=/usr/local --datadir=/var/db/mysql --plugin-dir=/us
smmsp 65448 0.0 0.1 26732 12104 - DJ 03:01 0:05.57 mailq -Ac (sendmail)
root 65449 0.0 0.0 8292 1448 - SJ 03:01 0:00.50 tee /dev/stderr
root 65450 0.0 0.0 14796 1860 - SJ 03:01 0:00.17 egrep -v (mqueue is empty|Total requests)
root 16552 0.0 0.0 21244 2056 0 R+J 08:34 0:00.00 ps -aux
I stopped the jail for now, any ideas of what cloud be the problem?
Thank you
