Nextcloud version 10.0.3
Operating system and version: nethserver (CentOS 7)
PHP version: 5.4
Is this the first time you’ve seen this error?: Yes
Hello Forum,
I’ve recently installed Nextcloud (through nethserver). I’ve been a long time user of ownCloud whereby I point my ownCloud external storage to a NAS (connecting using SMB/Cifs) to serve up a folders of PDF docs. This is working perfectly in my ownCloud version 8.1.1, but I’m having trouble achieving the same in my Nextcloud version 10.0.3?
I’ve added in the app for external storage.
I’ve successfully added my external storage in my Admin panel in Nextcloud. I have a green dot beside the Folder Name so I know I’m using the right credentials.
I’ve ensured that the user I’m using (Admin) has access to use this new external storage
I go back to my Files and I don’t see the new folder in my All Files like I do in my ownCloud. But I do see the external folder under an External Folder section. I go there and left click on the folder. My screen flashes for a moment and I’m immediately brought back to my All files folder. My attempt to access this shared storage folder has failed with no apparent error or reason?
Has anyone experienced this before in Nextcloud? I’m not aware of setting up anything ‘special’ when I did this in my older version of ownCloud?
Any advice or next steps I can take to fix this or flush out why it’s happening would be greatly appreciated.
Thank you.
