I’m running a small nextcloud instance 28.0.2.5 on Debian GNU/Linux 12 in a docker container
and want to convert the existing mysql database to postgres.
The mysql database running on 192.168.7.44:13306 has no ssl configuration and can be reached via cli without problems.
from config.php:
'version' => '28.0.2.5',
'overwrite.cli.url' => 'http://mycloud.de',
'dbname' => 'nextcloud',
'dbhost' => '192.168.7.44:13306',
'dbuser' => 'nextcloud_db_user',
'dbpassword' => 'password',
Unfortunately:
php occ db:convert-type --password='password' --clear-schema pgsql nextcloud_db_user 192.168.7.44 nextcloud_db -v
This command gives me the error:
In Connection.php line 139:
[Doctrine\DBAL\Exception (7)]
Failed to connect to the database: An exception occurred in the driver: SQLSTATE[08006] [7] connection to server at "192.168.7.44", port 13306 failed
: received invalid response to SSL negotiation: q
Exception trace:
at /var/www/html/lib/private/DB/Connection.php:139
OC\DB\Connection->connect() at /var/www/html/3rdparty/doctrine/dbal/src/Connection.php:452
Doctrine\DBAL\Connection->getDatabasePlatformVersion() at /var/www/html/3rdparty/doctrine/dbal/src/Connection.php:410
Doctrine\DBAL\Connection->detectDatabasePlatform() at /var/www/html/3rdparty/doctrine/dbal/src/Connection.php:317
Doctrine\DBAL\Connection->getDatabasePlatform() at /var/www/html/3rdparty/doctrine/dbal/src/Schema/LegacySchemaManagerFactory.php:16
Doctrine\DBAL\Schema\LegacySchemaManagerFactory->createSchemaManager() at /var/www/html/3rdparty/doctrine/dbal/src/Connection.php:1682
Doctrine\DBAL\Connection->createSchemaManager() at /var/www/html/3rdparty/doctrine/dbal/src/Connection.php:1703
Doctrine\DBAL\Connection->getSchemaManager() at /var/www/html/core/Command/Db/ConvertType.php:279
OC\Core\Command\Db\ConvertType->getTables() at /var/www/html/core/Command/Db/ConvertType.php:261
OC\Core\Command\Db\ConvertType->clearSchema() at /var/www/html/core/Command/Db/ConvertType.php:188
OC\Core\Command\Db\ConvertType->execute() at /var/www/html/3rdparty/symfony/console/Command/Command.php:298
Symfony\Component\Console\Command\Command->run() at /var/www/html/3rdparty/symfony/console/Application.php:1040
Symfony\Component\Console\Application->doRunCommand() at /var/www/html/3rdparty/symfony/console/Application.php:301
Symfony\Component\Console\Application->doRun() at /var/www/html/3rdparty/symfony/console/Application.php:171
Symfony\Component\Console\Application->run() at /var/www/html/lib/private/Console/Application.php:206
OC\Console\Application->run() at /var/www/html/console.php:100
require_once() at /var/www/html/occ:11
The logs from the mysql says:
2024-02-18 17:03:28 101153 [Warning] Aborted connection 101153 to db: 'unconnected' user: 'unauthenticated' host: '172.17.0.1' (This connection closed normally without authentication)
Any idea?
