Problem after update from34.0.0 to 34.0.1
    • v34.0.2
    • Ubuntu 24.04.4
    • Apache 2.4.58
    • php8.3-apcu-5.1.22
    • PHP 8.3
    • No just sines upgrade to v34.0.1
    • upgrade to v34.0.1
    • direct from menu
after upgrading to V34.0.1 i can’t upgrade apps i can’t sync between workstation and cloud i can’t upload to cloud by web interface
  1. upgrade apps
  2. sync between PC and cloud
  3. upload to cloud
{"reqId":"T8S3IJVEf79tUeP7oH46","level":3,"time":"2026-07-26T20:00:36+00:00","remoteAddr":"192.168.2.70","user":"nemj","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/nemj/NEM_Printer_Support/Leverand%C3%B8r/Tilsted/2026/06/Bilag272_postering_2026-06-30-02.00.54.034132.pdf","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Linux) mirall/3.11.0git (Nextcloud, ubuntu-7.0.0-28-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"34.0.2.1","clientReqId":"c2742a8e-2b8d-4c21-989b-1f101d7772b5","exception":{"Exception":"RedisException","Message":"Connection refused","Code":0,"Trace":\[{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":98,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":141,"function":"create","class":"OC\\RedisFactory","type":"->","args":\["\*\*\* sensitive parameters replaced ***"\]},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":64,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":244,"function":"getCache","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":43,"function":"getTTL","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":67,"function":"getTTL","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Common.php","line":692,"function":"acquireLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2087,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2192,"function":"lockPath","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":366,"function":"lockFile","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":124,"function":"acquireLock","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":\["*** sensitive parameters replaced ***"\]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":\["*** sensitive parameters replaced \*\*\*"\]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":215,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":432,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/remote.php","line":152,"args":\["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"\],"function":"require_once"}\],"File":"/var/www/html/nextcloud/lib/private/RedisFactory.php","Line":98,"message":"Uncaught exception","exception":"{"class":"RedisException","message":"Connection refused","code":0,"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php:98","trace":"#0 /var/www/html/nextcloud/lib/private/RedisFactory.php(98): Redis->pconnect()\\n#1 /var/www/html/nextcloud/lib/private/RedisFactory.php(141): OC\\RedisFactory->create()\\n#2 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(64): OC\\RedisFactory->getInstance()\\n#3 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(244): OC\\Memcache\\Redis->getCache()\\n#4 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(43): OC\\Memcache\\Redis->getTTL()\\n#5 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(67): OC\\Lock\\MemcacheLockingProvider->getTTL()\\n#6 /var/www/html/nextcloud/lib/private/Files/Storage/Common.php(692): OC\\Lock\\MemcacheLockingProvider->acquireLock()\\n#7 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Common->acquireLock()\\n#8 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#9 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#10 /var/www/html/nextcloud/lib/private/Files/View.php(2087): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#11 /var/www/html/nextcloud/lib/private/Files/View.php(2192): OC\\Files\\View->lockPath()\\n#12 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php(366): OC\\Files\\View->lockFile()\\n#13 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php(124): OCA\\DAV\\Connector\\Sabre\\Node->acquireLock()\\n#14 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(1098): OCA\\DAV\\Connector\\Sabre\\Directory->createFile()\\n#15 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\\DAV\\Server->createFile()\\n#16 /var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpPut()\\n#17 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(472): Sabre\\DAV\\Server->emit()\\n#18 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php(215): Sabre\\DAV\\Server->invokeMethod()\\n#19 /var/www/html/nextcloud/apps/dav/lib/Server.php(432): OCA\\DAV\\Connector\\Sabre\\Server->start()\\n#20 /var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php(25): OCA\\DAV\\Server->exec()\\n#21 /var/www/html/nextcloud/remote.php(152): require_once('...')\\n#22 {main}"}","CustomMessage":"Uncaught exception"},"id":"6a666af1c8fae"}
{"reqId":"T8S3IJVEf79tUeP7oH46","level":3,"time":"2026-07-26T20:00:36+00:00","remoteAddr":"192.168.2.70","user":"nemj","app":"webdav","method":"PUT","url":"/remote.php/dav/files/nemj/NEM_Printer_Support/Leverand%C3%B8r/Tilsted/2026/06/Bilag272_postering_2026-06-30-02.00.54.034132.pdf","scriptName":"/remote.php","message":"Connection refused","userAgent":"Mozilla/5.0 (Linux) mirall/3.11.0git (Nextcloud, ubuntu-7.0.0-28-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"34.0.2.1","clientReqId":"c2742a8e-2b8d-4c21-989b-1f101d7772b5","exception":{"Exception":"RedisException","Message":"Connection refused","Code":0,"Trace":\[{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":98,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":141,"function":"create","class":"OC\\RedisFactory","type":"->","args":\["\*\*\* sensitive parameters replaced ***"\]},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":64,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":244,"function":"getCache","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":43,"function":"getTTL","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":67,"function":"getTTL","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Common.php","line":692,"function":"acquireLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2087,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2192,"function":"lockPath","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":366,"function":"lockFile","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":124,"function":"acquireLock","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":\["*** sensitive parameters replaced ***"\]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":\["*** sensitive parameters replaced \*\*\*"\]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":215,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":432,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/remote.php","line":152,"args":\["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"\],"function":"require_once"}\],"File":"/var/www/html/nextcloud/lib/private/RedisFactory.php","Line":98,"message":"Connection refused","exception":"{"class":"RedisException","message":"Connection refused","code":0,"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php:98","trace":"#0 /var/www/html/nextcloud/lib/private/RedisFactory.php(98): Redis->pconnect()\\n#1 /var/www/html/nextcloud/lib/private/RedisFactory.php(141): OC\\RedisFactory->create()\\n#2 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(64): OC\\RedisFactory->getInstance()\\n#3 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(244): OC\\Memcache\\Redis->getCache()\\n#4 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(43): OC\\Memcache\\Redis->getTTL()\\n#5 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(67): OC\\Lock\\MemcacheLockingProvider->getTTL()\\n#6 /var/www/html/nextcloud/lib/private/Files/Storage/Common.php(692): OC\\Lock\\MemcacheLockingProvider->acquireLock()\\n#7 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Common->acquireLock()\\n#8 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#9 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#10 /var/www/html/nextcloud/lib/private/Files/View.php(2087): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#11 /var/www/html/nextcloud/lib/private/Files/View.php(2192): OC\\Files\\View->lockPath()\\n#12 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php(366): OC\\Files\\View->lockFile()\\n#13 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php(124): OCA\\DAV\\Connector\\Sabre\\Node->acquireLock()\\n#14 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(1098): OCA\\DAV\\Connector\\Sabre\\Directory->createFile()\\n#15 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\\DAV\\Server->createFile()\\n#16 /var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpPut()\\n#17 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(472): Sabre\\DAV\\Server->emit()\\n#18 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php(215): Sabre\\DAV\\Server->invokeMethod()\\n#19 /var/www/html/nextcloud/apps/dav/lib/Server.php(432): OCA\\DAV\\Connector\\Sabre\\Server->start()\\n#20 /var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php(25): OCA\\DAV\\Server->exec()\\n#21 /var/www/html/nextcloud/remote.php(152): require_once('...')\\n#22 {main}"}","CustomMessage":"Connection refused"},"id":"6a666af4d668f"}
{"reqId":"dl5ceBNthFwf0GhDy8MW","level":3,"time":"2026-07-26T20:00:36+00:00","remoteAddr":"192.168.2.70","user":"nemj","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/nemj/NEM_Printer_Support/Leverand%C3%B8r/Tilsted/2026/06/Bilag270_postering_2026-06-30-01.51.08.868152.pdf","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Linux) mirall/3.11.0git (Nextcloud, ubuntu-7.0.0-28-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"34.0.2.1","clientReqId":"c865f8e8-b4f0-4596-ab37-f352c1cb48d7","exception":{"Exception":"RedisException","Message":"Connection refused","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":98,"function":"pconnect","class":"Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/RedisFactory.php","line":141,"function":"create","class":"OC\\RedisFactory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":64,"function":"getInstance","class":"OC\\RedisFactory","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Memcache/Redis.php","line":244,"function":"getCache","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":43,"function":"getTTL","class":"OC\\Memcache\\Redis","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php","line":67,"function":"getTTL","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Common.php","line":692,"function":"acquireLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":362,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2087,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Files/View.php","line":2192,"function":"lockPath","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php","line":366,"function":"lockFile","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":124,"function":"acquireLock","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":215,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/lib/Server.php","line":432,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/html/nextcloud/remote.php","line":152,"args":["/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/nextcloud/lib/private/RedisFactory.php","Line":98,"message":"Uncaught exception","exception":"{\"class\":\"RedisException\",\"message\":\"Connection refused\",\"code\":0,\"file\":\"/var/www/html/nextcloud/lib/private/RedisFactory.php:98\",\"trace\":\"#0 /var/www/html/nextcloud/lib/private/RedisFactory.php(98): Redis->pconnect()\\n#1 /var/www/html/nextcloud/lib/private/RedisFactory.php(141): OC\\RedisFactory->create()\\n#2 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(64): OC\\RedisFactory->getInstance()\\n#3 /var/www/html/nextcloud/lib/private/Memcache/Redis.php(244): OC\\Memcache\\Redis->getCache()\\n#4 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(43): OC\\Memcache\\Redis->getTTL()\\n#5 /var/www/html/nextcloud/lib/private/Lock/MemcacheLockingProvider.php(67): OC\\Lock\\MemcacheLockingProvider->getTTL()\\n#6 /var/www/html/nextcloud/lib/private/Files/Storage/Common.php(692): OC\\Lock\\MemcacheLockingProvider->acquireLock()\\n#7 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Common->acquireLock()\\n#8 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#9 /var/www/html/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php(362): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#10 /var/www/html/nextcloud/lib/private/Files/View.php(2087): OC\\Files\\Storage\\Wrapper\\Wrapper->acquireLock()\\n#11 /var/www/html/nextcloud/lib/private/Files/View.php(2192): OC\\Files\\View->lockPath()\\n#12 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Node.php(366): OC\\Files\\View->lockFile()\\n#13 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php(124): OCA\\DAV\\Connector\\Sabre\\Node->acquireLock()\\n#14 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(1098): OCA\\DAV\\Connector\\Sabre\\Directory->createFile()\\n#15 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php(504): Sabre\\DAV\\Server->createFile()\\n#16 /var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php(89): Sabre\\DAV\\CorePlugin->httpPut()\\n#17 /var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php(472): Sabre\\DAV\\Server->emit()\\n#18 /var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Server.php(215): Sabre\\DAV\\Server->invokeMethod()\\n#19 /var/www/html/nextcloud/apps/dav/lib/Server.php(432): OCA\\DAV\\Connector\\Sabre\\Server->start()\\n#20 /var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php(25): OCA\\DAV\\Server->exec()\\n#21 /var/www/html/nextcloud/remote.php(152): require_once('...')\\n#22 {main}\"}","CustomMessage":"Uncaught exception"},"id":"6a666af4d66f2"}
Cannot load Zend OPcache - it was already loaded
PASTE HERE
PHP Warning:  Module "curl" is already loaded in Unknown on line 0
PHP Warning:  Module "ftp" is already loaded in Unknown on line 0
PHP Warning:  Module "gd" is already loaded in Unknown on line 0
PHP Warning:  Module "gmp" is already loaded in Unknown on line 0
PHP Warning:  Module "imap" is already loaded in Unknown on line 0
PHP Warning:  Module "intl" is already loaded in Unknown on line 0
PHP Warning:  Module "mbstring" is already loaded in Unknown on line 0
PHP Warning:  Module "sqlite3" is already loaded in Unknown on line 0
PHP Warning:  Module "zip" is already loaded in Unknown on line 0
            "sky.nemprinter.dk",
            "192.168.2.156",
            "85.184.160.207",
            "localhost"
        "dbtype": "mysql",
        "version": "34.0.2.1",
        "overwrite.cli.url": "https:\/\/sky.nemprinter.dk\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "sendmail",
        "mail_sendmailmode": "pipe",
        "default_phone_region": "DK",
        "theme": "",
        "loglevel": 2,
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "app_install_overwrite": [
            "richdocumentscode"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "redis": {
            "port": 0,
            "timeout": 0
    "apps": {
        "activity": {
            "enabled": "yes",
            "installed_version": "7.0.0",
            "notify_email_calendar": "0",
            "notify_email_calendar_event": "0",
            "notify_email_calendar_todo": "0",
            "notify_email_circles_as_member": "0",
            "notify_email_circles_as_moderator": "1",
            "notify_email_circles_as_non_member": "0",
            "notify_email_comments": "0",
            "notify_email_contacts": "0",
            "notify_email_file_changed": "0",
            "notify_email_group_settings": "1",
            "notify_email_public_links": "0",
            "notify_email_public_links_upload": "0",
            "notify_email_remote_share": "0",
            "notify_email_shared": "0",
            "notify_email_spreed": "0",
            "notify_email_systemtags": "0",
            "notify_notification_calendar": "0",
            "notify_notification_calendar_event": "0",
            "notify_notification_calendar_todo": "0",
            "notify_notification_circles_as_member": "0",
            "notify_notification_circles_as_moderator": "0",
            "notify_notification_circles_as_non_member": "0",
            "notify_notification_comments": "0",
            "notify_notification_contacts": "0",
            "notify_notification_favorite": "0",
            "notify_notification_file_changed": "0",
            "notify_notification_file_favorite_changed": "0",
            "notify_notification_group_settings": "0",
            "notify_notification_personal_settings": "0",
            "notify_notification_public_links": "0",
            "notify_notification_public_links_upload": "0",
            "notify_notification_remote_share": "0",
            "notify_notification_security": "0",
            "notify_notification_shared": "0",
            "notify_notification_spreed": "0",
            "notify_notification_systemtags": "0",
            "notify_notification_twofactor_totp": "0",
            "notify_setting_batchtime": "3600",
            "notify_setting_self": "0",
            "notify_setting_selfemail": "0",
            "types": "filesystem"
        "admin_audit": {
            "enabled": "yes",
            "installed_version": "1.24.0",
            "types": "logging"
        "app_api": {
            "enabled": "no",
            "installed_version": "34.0.0",
            "types": "",
            "default_daemon_config": "harp_proxy_host"
        "appstore": {
            "enabled": "yes",
            "installed_version": "1.0.0",
            "types": ""
        "backgroundjob": {
            "lastjob": "62436369312972800"
        "bruteforcesettings": {
            "enabled": "yes",
            "types": ""
        "calendar": {
            "enabled": "yes",
            "installed_version": "6.5.1",
            "types": ""
        "circles": {
            "enabled": "yes",
            "loopback_tmp_path": "\/",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1785098402,\"2\":1785098714,\"1\":1785098714}",
            "migration_22": "1",
            "migration_run": "0",
            "types": "filesystem,dav",
            "remove_share_tokens_done": true
        "cloud_federation_api": {
            "enabled": "yes",
            "installed_version": "1.18.0",
        "comments": {
            "enabled": "yes",
            "types": "logging"
        "contacts": {
            "enabled": "yes",
            "installed_version": "8.7.4",
            "types": "dav"
        "contactsinteraction": {
            "enabled": "yes",
            "installed_version": "1.15.0",
            "types": "dav"
        "core": {
            "backgroundjobs_mode": "cron",
            "emailTestSuccessful": "1",
            "files_metadata_installed": "1",
            "installed.bundles": "[\"CoreBundle\"]",
            "installedat": "1658661181.1159",
            "lastcron": 1785098715,
            "lastupdateResult": "[]",
            "lastupdatedat": 1785096705,
            "metadataGenerationDone": true,
            "moveavatarsdone": "yes",
            "previewMovedDone": true,
            "previewsCleanedUp": "1",
            "public_files": "files_sharing\/public.php",
            "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
            "theming.variables": "32ef7dc01a3ffbcbbaf8fb9483f9bd03",
            "vendor": "nextcloud",
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-gps": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-place": {
                    "value": null,
                    "type": "string",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "cbe18d352b5b87cdba6f315299c23cd1",
                    "indexed": false,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "enabled": "yes",
            "installed_version": "7.14.0",
            "types": ""
        "dav": {
            "buildCalendarReminderIndex": "yes",
            "buildCalendarSearchIndex": "yes",
            "builtSocialSearchIndex": "yes",
            "checked_for_classified_activity": true,
            "chunks_migrated": "1",
            "enabled": "yes",
            "installed_version": "1.39.0",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
        "federatedfilesharing": {
            "enabled": "yes",
            "types": ""
        "federation": {
            "enabled": "yes",
            "types": "authentication"
        "files": {
            "enabled": "yes",
            "installed_version": "2.6.0",
            "mimetype_version": "33.0.0.16",
        "files_downloadlimit": {
            "enabled": "yes",
            "installed_version": "5.2.0",
            "types": ""
        "files_lock": {
            "enabled": "yes",
            "installed_version": "34.0.1",
        "files_pdfviewer": {
            "enabled": "yes",
            "installed_version": "7.0.0-dev.0",
            "types": ""
        "files_reminders": {
            "enabled": "yes",
            "installed_version": "1.7.0",
            "types": ""
        "files_rightclick": {
            "enabled": "no",
            "installed_version": "1.6.0",
            "types": ""
        "files_sharing": {
            "enabled": "yes",
            "installed_version": "1.26.0",
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.27.0",
        "fileslibreofficeedit": {
            "enabled": "yes",
            "installed_version": "2.0.1",
            "types": ""
        "firstrunwizard": {
            "enabled": "yes",
            "types": ""
        "gpxpod": {
            "enabled": "no",
            "installed_version": "8.2.1",
            "maptiler_api_key": "***REMOVED SENSITIVE VALUE***",
            "reset304": "1",
            "resetPics404": "1",
            "types": ""
        "integration_google": {
            "enabled": "yes",
            "installed_version": "4.4.0",
            "types": ""
        "logreader": {
            "enabled": "yes",
            "types": "logging"
        "lookup_server_connector": {
            "enabled": "yes",
            "installed_version": "1.22.0",
        "mail": {
            "enabled": "yes",
            "installed_version": "5.10.9",
            "types": ""
        "maps": {
            "enabled": "no",
            "installed_version": "1.7.1",
            "osrmDEMO": "on",
        "music": {
            "enabled": "yes",
            "installed_version": "3.1.1",
        "news": {
            "enabled": "no",
            "installed_version": "28.6.0",
            "types": ""
        "nextcloud_announcements": {
            "enabled": "yes",
            "installed_version": "6.0.0",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
            "types": "logging"
        "notes": {
            "enabled": "yes",
            "installed_version": "6.0.1",
            "types": ""
        "notifications": {
            "enabled": "yes",
            "installed_version": "7.0.0-dev.1",
            "types": "logging",
            "webpush_vapid_privkey": "***REMOVED SENSITIVE VALUE***",
            "webpush_vapid_pubkey": "BA7_kFsIk2CWGqk4pLdpKrTsMcg1SQZ2mcG0wS4rBu_oMdXVkCH97e6o9hLJOyJiGNFporivUOe9zm4SxSgFMcA"
        "oauth2": {
            "enabled": "yes",
        "office": {
            "enabled": "yes",
            "types": ""
        "password_policy": {
            "enabled": "yes",
            "installed_version": "6.0.0-dev.0",
        "photos": {
            "enabled": "yes",
            "lastPlaceMappedUser": "Vanina_Kimmi",
            "lastPlaceMappingDone": "true",
            "types": "authentication,dav"
        "privacy": {
            "enabled": "yes",
            "installed_version": "6.0.0-dev.1",
            "readableLocation": "dk",
            "types": ""
        "profile": {
            "enabled": "yes",
            "installed_version": "1.3.0",
            "types": ""
        "provisioning_api": {
            "enabled": "yes",
            "types": "prevent_group_restriction"
        "recommendations": {
            "enabled": "yes",
            "types": ""
        "related_resources": {
            "enabled": "yes",
            "installed_version": "5.0.0-dev.0",
            "types": ""
        "richdocuments": {
            "disable_certificate_verification": "yes",
            "enabled": "yes",
            "installed_version": "11.0.1",
            "types": "filesystem,prevent_group_restriction",
            "wopi_url": "https:\/\/sky.nemprinter.dk\/apps\/richdocumentscode\/proxy.php?req="
        "richdocumentscode": {
            "enabled": "no",
            "installed_version": "26.4.104",
            "types": ""
        "serverinfo": {
            "cached_count_appdata_files": 326244,
            "cached_count_filecache": 544233,
            "cached_count_storages": "6",
            "enabled": "yes",
            "size_appdata_storage": -1,
            "types": ""
        "settings": {
            "enabled": "yes",
            "installed_version": "1.17.0",
            "types": ""
        "sharebymail": {
            "enabled": "yes",
        "spreed": {
            "default_group_notification": 2,
            "enabled": "yes",
            "installed_version": "24.0.2",
            "project_access_invalidated": "1",
            "signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***",
            "types": "dav,prevent_group_restriction"
        "support": {
            "SwitchUpdaterServerHasRun": "yes",
            "enabled": "yes",
            "types": "session"
        "survey_client": {
            "enabled": "yes",
            "last_sent": 1783252214,
            "types": "",
            "last_report": "{\"id\":\"ocqtqocc4t3n\",\"items\":[[\"server\",\"version\",\"34.0.1.2\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"none\"],[\"server\",\"memcache.distributed\",\"none\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"cron\"],[\"php\",\"version\",\"8.3.6\"],[\"php\",\"memory_limit\",-1],[\"php\",\"max_execution_time\",0],[\"php\",\"upload_max_filesize\",2097152],[\"database\",\"type\",\"mysql\"],[\"database\",\"version\",\"10.6.20\"],[\"database\",\"size\",989413376],[\"apps\",\"activity\",\"7.0.0\"],[\"apps\",\"admin_audit\",\"1.24.0\"],[\"apps\",\"app_api\",\"34.0.0\"],[\"apps\",\"appstore\",\"1.0.0\"],[\"apps\",\"bruteforcesettings\",\"7.0.0\"],[\"apps\",\"calendar\",\"6.5.0\"],[\"apps\",\"circles\",\"34.0.0\"],[\"apps\",\"cloud_federation_api\",\"1.18.0\"],[\"apps\",\"comments\",\"1.24.0\"],[\"apps\",\"contacts\",\"8.7.2\"],[\"apps\",\"contactsinteraction\",\"1.15.0\"],[\"apps\",\"dashboard\",\"7.14.0\"],[\"apps\",\"dav\",\"1.39.0\"],[\"apps\",\"federatedfilesharing\",\"1.24.0\"],[\"apps\",\"federation\",\"1.24.0\"],[\"apps\",\"files\",\"2.6.0\"],[\"apps\",\"files_downloadlimit\",\"5.2.0-dev.0\"],[\"apps\",\"files_lock\",\"34.0.0\"],[\"apps\",\"files_pdfviewer\",\"7.0.0-dev.0\"],[\"apps\",\"files_reminders\",\"1.7.0\"],[\"apps\",\"files_rightclick\",\"disabled\"],[\"apps\",\"files_sharing\",\"1.26.0\"],[\"apps\",\"files_trashbin\",\"1.24.0\"],[\"apps\",\"files_versions\",\"1.27.0\"],[\"apps\",\"fileslibreofficeedit\",\"2.0.1\"],[\"apps\",\"firstrunwizard\",\"7.0.0-dev.0\"],[\"apps\",\"gpxpod\",\"disabled\"],[\"apps\",\"integration_google\",\"4.4.0\"],[\"apps\",\"logreader\",\"7.0.0\"],[\"apps\",\"lookup_server_connector\",\"1.22.0\"],[\"apps\",\"mail\",\"5.10.3\"],[\"apps\",\"maps\",\"disabled\"],[\"apps\",\"music\",\"3.1.0\"],[\"apps\",\"news\",\"disabled\"],[\"apps\",\"nextcloud_announcements\",\"6.0.0\"],[\"apps\",\"notes\",\"6.0.1\"],[\"apps\",\"notifications\",\"7.0.0-dev.1\"],[\"apps\",\"oauth2\",\"1.22.0\"],[\"apps\",\"office\",\"1.0.0\"],[\"apps\",\"password_policy\",\"6.0.0-dev.0\"],[\"apps\",\"photos\",\"7.0.0\"],[\"apps\",\"privacy\",\"6.0.0-dev.1\"],[\"apps\",\"profile\",\"1.3.0\"],[\"apps\",\"provisioning_api\",\"1.24.0\"],[\"apps\",\"recommendations\",\"7.0.0\"],[\"apps\",\"related_resources\",\"5.0.0-dev.0\"],[\"apps\",\"richdocuments\",\"11.0.0\"],[\"apps\",\"richdocumentscode\",\"disabled\"],[\"apps\",\"serverinfo\",\"6.0.0\"],[\"apps\",\"settings\",\"1.17.0\"],[\"apps\",\"sharebymail\",\"1.24.0\"],[\"apps\",\"spreed\",\"24.0.0\"],[\"apps\",\"support\",\"6.0.0\"],[\"apps\",\"survey_client\",\"6.0.0-dev.0\"],[\"apps\",\"systemtags\",\"1.24.0\"],[\"apps\",\"tasks\",\"disabled\"],[\"apps\",\"text\",\"8.0.0\"],[\"apps\",\"theming\",\"2.9.0\"],[\"apps\",\"twofactor_backupcodes\",\"1.23.0\"],[\"apps\",\"twofactor_totp\",\"16.0.0\"],[\"apps\",\"updatenotification\",\"1.24.0\"],[\"apps\",\"user_status\",\"1.14.0\"],[\"apps\",\"viewer\",\"7.0.0-dev.0\"],[\"apps\",\"weather_status\",\"1.14.0\"],[\"apps\",\"webhook_listeners\",\"1.6.0\"],[\"apps\",\"workflow_ocr\",\"disabled\"],[\"apps\",\"workflowengine\",\"2.16.0\"],[\"stats\",\"num_files\",544241],[\"stats\",\"num_users\",5],[\"stats\",\"num_storages\",6],[\"stats\",\"num_storages_local\",1],[\"stats\",\"num_storages_home\",5],[\"stats\",\"num_storages_other\",0],[\"stats\",\"num_comments\",165],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",1],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",148],[\"files_sharing\",\"num_shares_user\",31],[\"files_sharing\",\"num_shares_groups\",0],[\"files_sharing\",\"num_shares_link\",64],[\"files_sharing\",\"num_shares_link_no_password\",64],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"files_sharing\",\"permissions_0_1\",2],[\"files_sharing\",\"permissions_3_4\",2],[\"files_sharing\",\"permissions_4_4\",1],[\"files_sharing\",\"permissions_3_17\",48],[\"files_sharing\",\"permissions_4_17\",24],[\"files_sharing\",\"permissions_0_19\",25],[\"files_sharing\",\"permissions_4_19\",21],[\"files_sharing\",\"permissions_3_21\",3],[\"files_sharing\",\"permissions_0_23\",1],[\"files_sharing\",\"permissions_3_23\",1],[\"files_sharing\",\"permissions_0_31\",3],[\"files_sharing\",\"permissions_3_31\",10],[\"files_sharing\",\"permissions_4_31\",7],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}"
        "systemtags": {
            "enabled": "yes",
            "types": "logging"
        "tasks": {
            "enabled": "no",
            "installed_version": "0.18.0",
            "types": ""
        "text": {
            "enabled": "yes",
            "installed_version": "8.0.0",
            "types": "dav"
        "theming": {
            "cachebuster": "5",
            "enabled": "yes",
            "faviconMime": "image\/vnd.microsoft.icon",
            "installed_version": "2.9.0",
            "logoDimensions": "200x120",
            "logoMime": "image\/png",
            "logoheaderMime": "image\/png",
            "name": "Sky.nemprinter.dk",
            "types": "logging",
            "url": "***REMOVED SENSITIVE VALUE***"
        "twofactor_backupcodes": {
            "enabled": "yes",
            "installed_version": "1.23.0",
            "types": ""
        "twofactor_totp": {
            "enabled": "yes",
            "installed_version": "16.0.0",
            "types": ""
        "updatenotification": {
            "calendar": "6.5.1",
            "contacts": "8.7.4",
            "core": "33.0.6.2",
            "enabled": "yes",
            "fileslibreofficeedit": "2.0.1",
            "integration_google": "4.3.1",
            "mail": "5.10.9",
            "maps": "1.0.2",
            "music": "3.1.1",
            "news": "21.2.0",
            "notes": "6.0.1",
            "richdocuments": "11.1.0",
            "richdocumentscode": "23.5.1001",
            "spreed": "24.0.3",
            "tasks": "0.16.0",
            "types": "",
            "update_check_errors": 0,
            "workflow_ocr": "1.33.1"
        "user_status": {
            "enabled": "yes",
            "installed_version": "1.14.0",
            "types": ""
        "viewer": {
            "enabled": "yes",
            "types": ""
        "weather_status": {
            "enabled": "yes",
            "types": ""
        "webhook_listeners": {
            "enabled": "yes",
        "workflow_ocr": {
            "enabled": "no",
            "installed_version": "1.33.1",
        "workflowengine": {
            "enabled": "yes",
            "installed_version": "2.16.0",
Hi @nemprinter,
both log lines are the same thing:
RedisException: Connection refused from Redis->pconnect() in RedisFactory.php.
The second one only carries the webdav tag because it happened to fire during an upload, it is not a separate problem. Your Nextcloud simply cannot reach its Redis server.
Redis is your file locking and memcache backend, so while it is down nothing that needs a lock will work: no app updates, no desktop sync, no uploads, all at once. This is not caused by the 34.0.0 to 34.0.1 point release either, that does not touch Redis. It just means redis-server is not running or not listening where your config points, most likely stopped around the update or a reboot.
And do not get sidetracked by port 0, that is the correct value when the host is a unix socket, Nextcloud sets it itself in that case. The port is fine, the server behind it is what is missing.
Get Redis back up and reachable and everything comes back on its own. Quick check on the server: is the service running, and does redis-cli ping answer PONG.
h.t.h.
ernolf
Thanks on your advice now i change port to 0 and it will not let redis-server run on this port if i change it to 6379 it works redis but not nextcloud i need to mention that i have also upgraded to latest redis with out any luck
Port 0 is not actually a networking port. As the comment in /etc/redis/redis.conf explains:
# Accept connections on the specified port, default is 6379 (IANA #815344).
# If port 0 is specified Redis will not listen on a TCP socket.
port 0
This means that if you’ve set Redis to port 0, you also need to configure a Unix socket in redis.conf, for example:
# Unix socket.
# Specify the path for the Unix socket that will be used to listen for
# incoming connections. There is no default, so Redis will not listen
# on a Unix socket unless one is specified.
unixsocket /var/run/redis/redis-server.sock
That, in turn, means your Nextcloud config.php should not contain an FQDN, localhost, or an IP address for the Redis host. Instead, it should point to the Unix socket path, for example:
'redis' =>
  'port' => 0,
  'dbindex' => 1,
  'timeout' => 0.5,
If you actually want Nextcloud to connect to Redis over TCP (e.g. via localhost / 127.0.0.1 or another host), then Redis needs to listen on a TCP port (typically 6379) instead of 0.
now sync is working only thing is APP part it says “it down at the moment please try later” but no error is coming in nextcloud log
and also MEMCACHED need to be configured
it still says “Could not update the app. Please try again later.” where is the right log to look in to
after some time my status is everything working around Redis-server i have now latest ver. of this but then it need to be set to port support else every time it get an update it have overwrite config file.
about app was not write possible it have been fix by latest update to v34.0.3 so everything is running
