Hi all.
I migrate my onwcloud 9 to nextcloud 9 (or 10 can’t remember now) then update to nextcloud 11 then 12 few days ago.
And suddenly, today, My nextcloud is messed up, There is no css I can’t view my files due to that error in console I guess : previewplugin.js:122 Uncaught ReferenceError: OCA is not defined
and
previewplugin.js:122 Uncaught ReferenceError: OC is not defined
I have these errors in lot of js files.
I checked my files, I stilll have my data folders ans all the data inside.
BUt the error comes suddenly, without done anything. that’s pretty weird.
Thanks in advance.
edit : I tried to disconnect then reconnect, I can’t connect as the buton is disabled.
And I have these errors in the console on login page:
edit2 : I search the source of OC and OCA variable.
It’s in js/js file
But this file is not included in the pages of my nextcloud (The file exists in my nextcloud install folder, it’s just not included in the pages).
before the migration i made a mysqldump of owncloud db and create a nextcloud db with the dump
but when I connect nextcloud with the new nextcloud db it doesn’t work…
I checked the GRANT privilege and the user used for nextcloud has all the privileges on owncloud and nextcloud db so I don’t understand why it doesn’t work…
I wanted a clean installation but it messed up the whole thing ^^"
yep I tested another pc and browser but the problem were still the same.
Like I said, It seems to be db related.
I re-use my “owncloud” db (as i had owncloud before) but would like to use my “nextcloud” db to have a clean installation.
But it seems just a mysqldump doesn’t work.
Is there another way to rename a db or copy all the data/param of a db ?
