Problem after latest udpate 33.0.2
    • 33.0.2
    • MacoOS latest update
    • after updation to 33.0.2
    • Docker stack
    • Cloudflare tunnel
Summary of the issue:
Since updating Nextcloud to 33.0.2, every time I install and app i end up with a 502 Bad Gateway error.
The core instance is still running, and normal access to Nextcloud is possible, but app installation fails systematically after the update. The issue did not exist before moving to 33.0.2.
I backed up my data and made a fresh new deployment but the same issue is reproduced again. Then I tried with downgrading to older version and surprisingly has the same issue, which I never had before.
  1. Go to my nextcloud page
  2. Install any app
  3. 502 Bad Gateway error
0.5 Safari/605.1.15"
172.19.0.14 - - [08/Apr/2026:11:58:05 +0000] "POST /settings/apps/enable HTTP/1.1" 200 806 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/60.5 Safari/605.1.15"
172.19.0.14 - - [08/Apr/2026:11:58:20 +0000] "GET /apps/files/ HTTP/1.1" 200 11669 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/60.5 Safari/605.1.15"
[Wed Apr 08 11:58:22.615575 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 70 exit signal Segmentation fault (11)
[Wed Apr 08 11:58:22.615981 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 80 exit signal Segmentation fault (11)
[Wed Apr 08 11:58:23.619639 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 65 exit signal Segmentation fault (11)
[Wed Apr 08 11:58:23.619848 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 81 exit signal Segmentation fault (11)
[Wed Apr 08 11:58:29.662937 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 69 exit signal Segmentation fault (11)
[Wed Apr 08 11:58:29.663100 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 71 exit signal Segmentation fault (11)
[Wed Apr 08 12:03:19.033266 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 61 exit signal Segmentation fault (11)
[Wed Apr 08 12:03:20.047845 2026] [core:notice] [pid 1:tid 1] AH00052: child pid 75 exit signal Segmentation fault (11)
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
            "0.0.0.0:8080",
            "localhost:8080",
            "mydomaine.com",
        "dbtype": "mysql",
        "version": "33.0.2.2",
        "overwrite.cli.url": "https:\/\/mydomaine.com",
        "overwriteprotocol": "https",
        "mysql.utf8mb4": true,
        "default_phone_region": "FR",
        "maintenance_window_start": 0,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "enable_previews": true,
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\Movie",
            "OC\\Preview\\PDF",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\MP4"
activity: 6.0.0
bruteforcesettings: 6.0.0
calendar: 6.2.2
circles: 33.0.0
cloud_federation_api: 1.17.0
comments: 1.23.0
contactsinteraction: 1.14.1
dashboard: 7.13.0
dav: 1.36.0
federatedfilesharing: 1.23.0
federation: 1.23.0
files: 2.5.0
files_downloadlimit: 5.1.0
files_pdfviewer: 6.0.0
files_reminders: 1.6.0
files_sharing: 1.25.2
files_trashbin: 1.23.0
files_versions: 1.26.0
firstrunwizard: 6.0.0
logreader: 6.0.0
lookup_server_connector: 1.21.0
nextcloud_announcements: 5.0.0
notifications: 6.0.0
oauth2: 1.21.0
password_policy: 5.0.0
photos: 6.0.0
privacy: 5.0.0
profile: 1.2.0
provisioning_api: 1.23.0
recommendations: 6.0.0
related_resources: 4.0.0
serverinfo: 5.0.0
settings: 1.16.0
sharebymail: 1.23.0
support: 5.0.0
survey_client: 5.0.0
systemtags: 1.23.0
text: 7.0.0
theming: 2.8.0
twofactor_backupcodes: 1.22.0
twofactor_totp: 15.0.0
updatenotification: 1.23.0
user_status: 1.13.0
viewer: 6.0.0
weather_status: 1.13.0
webhook_listeners: 1.5.0
workflowengine: 2.15.0
admin_audit: 1.23.0
app_api: 33.0.0 (installed 33.0.0)
encryption: 2.21.0
files_external: 1.25.1
suspicious_login: 11.0.0
testing: 1.23.0
twofactor_nextcloud_notification: 7.0.0
user_ldap: 1.24.0
Docker stack
services:
  nc:
    image: nextcloud:latest
    container_name: nc
    restart: unless-stopped
    networks:
      - cloudflare_tunnel_tunnel
    depends_on:
      - ncdb
      - redis
    ports:
      - 8080:80
    volumes:
      - /nc/html:/var/www/html
    environment:
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
      - MYSQL_PASSWORD=
      - MYSQL_HOST=ncdb
      - REDIS_HOST=redis
      - REDIS_HOST_PASSWORD=
  ncdb:
    image: mariadb:11.6
    container_name: ncdb
    networks:
    volumes:
      - /nc/ncdb:/var/lib/mysql
    environment:
      - TZ=Europe/Paris
      - MYSQL_RANDOM_ROOT_PASSWORD=true
      - MYSQL_PASSWORD=
  redis:
    image: redis:alpine
    container_name: redis
    healthcheck:
      test: [“CMD-SHELL”, “redis-cli ping || exit 1”]
    volumes:
      - /nc/redis:/data
    networks:
    command: redis-server --requirepass
  cron:
    container_name: nc_cron
    restart: always
    volumes:
    entrypoint: /cron.sh
    networks:
    depends_on:
      - ncdb
      - redis
networks:
  cloudflare_tunnel_tunnel:
    external: true
Some other users with ARM CPUs reported similar elsewhere on the forum.
What apps are you trying to enable. It is more likely on larger apps that use external resources (AI, Image generation/preview …) … on smaller “standard” apps it’s less likely.
With the Segmentation Fault, I’d also check if you are running very low on resources (RAM, disk space).
can confirm the issue. Just tried to update contacts and mail an NC 33.0.2 and after each update, NC crashes. Only a restart of the Docker container helps. After the restart, I also got the maintenance message and had to deactivate manually :frowning:
I’m running on an ARM VPS. Would be happy to get a solution :wink:
Issue still persists in NC 34.0.0. After app update, error 502 bad gateways occures. Only restart of docker container helps…
