Problem accessing NCP WebUI through OpenWrt firewall
    • 31.0.2.1
    • Debian 12
    • replace me
    • replace me
    • 8.3
    • Yes
    • Once I put NCP behind the firewall. When it was not firewalled I had no problem.
    • Proxmox NCP lxc installation script
Well, the subject line is pretty self-explanatory. I did a new install of NCP and have not used it for anything thus far - i.e. the system is as it was installed. I did run through the NextCloudPi Wizard on the NCP Panel and said that I did want to access Nextcloud from outside my house (i.e. behind a firewall) and that I would config the firewall manually. I configured three forwarding rules on the OpenWrt firewall for NCP’s ports 80 (8080 → 80), 443 (8443 → 443) and 4443 (4443 → 4443). These are essentially the same as the port forwards I have for a bunch of other services running on my Proxmox host, all of which work perfectly.
If I try to get to NCP’s port 80, Firefox’s “Unable to connect” page comes up. However, when I try to connect to 443 NCP kics out the “Access through untrusted domain” page - i.e. the firewall forwarding rule does actually work. Interestingly, when I try connecting to the NPC Panel via port 4443 the connection works fine and I can login.
I read the documentation about trusted domains in config.php and then edited the file to add the ip address of my laptop - 192.168.1.123.
The trusted domains section of the config.php file is now as follows:
0 => ‘localhost’,
1 => ‘10.50.50.229’,
2 => ‘192.168.1.123’,
3 => ‘nextcloudpi’,
5 => ‘nextcloudpi.local’,
7 => ‘nextcloudpi’,
8 => ‘nextcloudpi.lan’,
11 => ‘89.92.2.142’,
14 => ‘nextcloud.ororke.net’,
You’d have thought that’s work but it didn’t. I still get nothing when trying to access port 80 and the “Access through untrusted domain” page when connecting via port 443.
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
