I have a truenas scale 22.02.4 + Nextcloud 24.05 And I want to use it behind a Nginx proxy manager 2.9.18 .
I have created my Nginx proxy host verry easly with the GUI like this :
I set the config.php for Nextcloud like this :
'overwritehost' => 'cloud.*******.fr:443',
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '192.168.1.67',
2 => '172.16.0.0/16',
Problem is, when I access to the url https://cloud.******.fr, I can see a 302 redirection to the /login page whith the nextcloud port instead the HTTPS port used by nginx.
I don’t understand if it is a problem of nginx not rewrinting url or nextcloud not using the “overwritehost” confguration. By the way if I set “overwritehost” whith a fake url it doesn’t seem to be used by the app.
Any Idea ?
