I just had to correct the last section where it tells nginx how to pass the php files to php-fpm.
Here is my final config for the moment:
server {
listen 443 ssl;
listen [::]:443 ssl;
ssl_certificate /etc/ssl/certs/clouddomain.ltdcrt;
ssl_certificate_key /etc/ssl/private/clouddomain.ltdkey;
set $root_path "/media/storage/nextcloud";
root $root_path;
index index.php;
set $socket "unix:/var/run/fpm-759c4785-ef9f904a4833.sock";
access_log /var/log/nginx/storage-access.log;
error_log /var/log/nginx/storage-error.log;
large_client_header_buffers 4 16k;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
# Set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
# Only use index.php for the index page
index index.php;
# Use pretty error pages
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
# If robots.txt is present, always allow access and serve it directly
# If it isn't, don't log the access attempt
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Deny access to the data and config directories, .ht* files,
# the README, and the database structure definition
location ~ ^/(data|config|\.ht|db_structure\.xml|README) {
deny all;
# Pretty URLs for WebDAV
location ~* \/remote\/(?:.*)$ {
rewrite ^ /remote.php last;
# Rewrite file preview requests and requests for the JS configuration file
# to the nextcloud front controller
location ~* \/core\/(?:js\/oc\.js|preview\.png).*$ {
rewrite ^ /index.php last;
# Main location block
# Most requests will fall into this block
location / {
# Specific rewrites for WebDAV/CalDAV/CardDAV and documentation
rewrite ^/caldav(.*)$ /remote.php/caldav$1 redirect;
rewrite ^/carddav(.*)$ /remote.php/carddav$1 redirect;
rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;
# The following 2 rules are only needed with webfinger
rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
rewrite ^/.well-known/carddav /remote.php/carddav/ redirect;
rewrite ^/.well-known/caldav /remote.php/caldav/ redirect;
rewrite ^(/core/doc/[^\/]+/)$ $1/index.html;
# Exclude static assets, specific PHP files, and Let's Encrypt verifications,
# then rewrite everything else to the ownCloud front controller
if ($uri !~* (?:\.(?:css|js|svg|gif|png|html|ttf|woff)$|^\/(?:remote|public|cron|status|ocs\/v1|ocs\/v2)\.php|^\/\.well-known\/acme-challenge\/.*$)){
# Set a long expires header on static assets, excluding files accessed through WebDAV
# This block will break uploads to WebDAV for the listed file extensions without the negative lookahead
location ~* ^(?!\/remote\.php)(?:.*)\.(?:jpg|jpeg|gif|bmp|ico|png|css|js|swf|html|svg|ttf|woff)$ {
expires 30d;
access_log off;
# Pass PHP files to PHP-FPM for processing
location ~ ^(.+?\.php)(/.*)?$ {
try_files $1 = 404;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$1;
fastcgi_param PATH_INFO $2;
fastcgi_param HTTPS on;
# Tell nextcloud we're rewriting URLs
fastcgi_pass $socket;
