Nextcloud version 11.0.1
Operating system and version : Centos 6.5
Apache or nginx version: Apache/2.2.15
PHP version :PHP 5.6.29
Is this the first time you’ve seen this error and can you replicate it?:
After performing the update of 10.0.2 to 11.0.1
Preshared files do not work after upgrade to 11.0.1
As you can see in the new link is not index.php and causes the error
https://mywebsite.com/s/TI1II80PtrwclnK
The output from the webserver:
Not Found
The requested URL /s/TI1II80PtrwclnK was not found on this server.
If I put index.php in the link it works without problems and showme de file to download:
https://mywebsite.com/index.php/s/TI1II80PtrwclnK
How can I fix it if I have many shared files and do not want to change it manually?
