Nextcloud version (eg, 29.0.5): 29.0.0-ls321 Build-date:- 2024-05-21T11:52:31+00:00
Operating system and version (eg, Ubuntu 29.04): Raspian - Bullseye
Apache or nginx version (eg, Apache 2.4.25): NGINX 2.11.2 / 1.21.4.3 PHP version _(eg, 8.3)_:
8.3.8
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Y
- No Clue how or why
can't get into the nextcloud to pull it
Can not figure out how to get it in here
❯ Configuring npm user ...
useradd warning: npm's uid 0 outside of the UID_MIN 1000 and UID_MAX 60000 range.
❯ Configuring npm group ...
❯ Checking paths ...
❯ Setting ownership ...
❯ Dynamic resolvers ...
❯ IPv6 ...
Enabling IPV6 in hosts in: /etc/nginx/conf.d
- /etc/nginx/conf.d/include/block-exploits.conf
- /etc/nginx/conf.d/include/assets.conf
- /etc/nginx/conf.d/include/ip_ranges.conf
- /etc/nginx/conf.d/include/letsencrypt-acme-challenge.conf
- /etc/nginx/conf.d/include/force-ssl.conf
- /etc/nginx/conf.d/include/proxy.conf
- /etc/nginx/conf.d/include/ssl-ciphers.conf
- /etc/nginx/conf.d/include/resolvers.conf
- /etc/nginx/conf.d/production.conf
- /etc/nginx/conf.d/default.conf
Enabling IPV6 in hosts in: /data/nginx
- /data/nginx/proxy_host/1.conf
❯ Docker secrets ...
_ _ ____ __ __
| \ | | _ \| \/ |
| \| | |_) | |\/| |
| |\ | __/| | | |
|_| \_|_| |_| |_|
User: npm PUID:0 ID:0 GROUP:0
Group: npm PGID:0 ID:0
❯ Starting nginx ...
❯ Starting backend ...
[6/23/2024] [10:25:40 PM] [Global ] › ℹ info Using Sqlite: /data/database.sqlite
[6/23/2024] [10:25:41 PM] [Migrate ] › ℹ info Current database version: none
[6/23/2024] [10:25:41 PM] [Setup ] › ℹ info Logrotate Timer initialized
[6/23/2024] [10:25:41 PM] [Global ] › ⬤ debug CMD: logrotate /etc/logrotate.d/nginx-proxy-manager
[6/23/2024] [10:25:41 PM] [Setup ] › ℹ info Logrotate completed.
[6/23/2024] [10:25:41 PM] [IP Ranges] › ℹ info Fetching IP Ranges from online services...
[6/23/2024] [10:25:41 PM] [IP Ranges] › ℹ info Fetching https://ip-ranges.amazonaws.com/ip-ranges.json
[6/23/2024] [10:25:42 PM] [IP Ranges] › ℹ info Fetching https://www.cloudflare.com/ips-v4
[6/23/2024] [10:25:42 PM] [IP Ranges] › ℹ info Fetching https://www.cloudflare.com/ips-v6
[6/23/2024] [10:25:42 PM] [SSL ] › ℹ info Let's Encrypt Renewal Timer initialized
[6/23/2024] [10:25:42 PM] [SSL ] › ℹ info Renewing SSL certs expiring within 30 days ...
[6/23/2024] [10:25:42 PM] [IP Ranges] › ℹ info IP Ranges Renewal Timer initialized
[6/23/2024] [10:25:42 PM] [Global ] › ℹ info Backend PID 163 listening on port 3000 ...
[6/23/2024] [10:25:42 PM] [SSL ] › ℹ info Completed SSL cert renew process
can not get it
